Thread: How to Adjust Toe-in....
Results 1 to 19 of 19
    Registered User Bullitt1672's Avatar
    So. Indiana
    How to Adjust Positive Camber
    Well i can see my tires taking a toll on the cranked TB's. My tires have positive camber, and i want to know how to adjust it myself. In know, i know i should just take it to be aligned, but i just need to do something temp. until i can get it into the shop. So can someone tell me how to move to the top of the wheel in and the bottom out? thanks.
    -2002 Chevy Silverado, LS, 4x4, - 16x10 Eagle 186 - 305-70-16 Mastercraft MT's - True Dual Straits w/ Magnaflow X-pipe - K&N 77 Series CAI, Ford Keys + 4" Block...sold
    -96 Sonoma with 4.3 liters of fury rolling on 15's
    Registered User DV2000NJ's Avatar
    Aug 2008
    NJ
    Re: How to Adjust Toe-in....
    You're asking two different things. It sounds like your camber is what's off, not your toe.
    This picture explains what caster/camber/toe are better than I could, but basically camber is the vertical in/out adjustment, and toe is the horizontal in/out adjustment.
    EDIT: while you can probably visually tell that your camber is off, your toe probably is off too. When I cranked my torsion bars, my camber was actually still in the acceptable range, but my toe was way off. Toe is adjustable with the tie rods, but I'd definitely suggest getting the truck aligned as soon as possible.
    | 2006 LQ4 | 216/224 .561/.568 114 | 44lb. injectors | OBX LTs | Magnaflow Hi-Flow cats | 3" Borla XR1 | Yank TT3000 | FLT Level 5 4L65 | 3/6 drop |
    Track video:13.163 @ 100.08 | 1.793 60'
    Flickr
    So. Indiana
    Yeah its the camber that's off, sorry bout that. My truck has to much positive camber...
    Aug 2008
    NJ
    I would just get it aligned as soon as possible. Toe is what causes abnormal tire wear more so than caster or camber.
    Flickr
    formerly 1978_Chevy_4x4 Baden's Avatar
    Nov 2006
    Spoklahoma, Washington
    Something you want to make sure is that you have around 1/4"-0" toe in so that your vehicle drives straight and smooth so that your vehicle tires are working together and not fighting the ruts driving down the road. When schwab aligned mine they toed them out, causing excessive tire wear and really crappy driving. So we jacked it up and did it ourselves by taking some measurements and getting it adjusted through the tie rods. Make sure you have some toe in while your at it. Just my two cents.
    * 2007 Silverado Classic CCSB * Duramax *
    * 1996 K1500 Silverado * 350 Vortec, AT * Magnaflow *
    * 3" PA Body Lift * 3/4 Ton Springs * 33x12.50x15 Cooper STT's, siped *
    Drinking Sailor Jerry's Pewter-Q's Avatar
    Jan 2004
    Louisiana
    Definitely get it aligned by a reputable shop, that's the easiest way to get your geometry right without having to learn A LOT of information and buy some pricey tools...
    Built tranny sitting in the bed waiting to go in. Good things to come...
    Dec 2004
    Elkhart IN
    sockets are pricy now? the only thing that i can think of that you might need is a tie rod claw, but i've never had a situation where i havent been able to get by without one.
    Nov 2004
    Thunder Bay Ontario
    Yeah, tie rod claw AKA pipe wrench ;)
    Expensive tools list :
    2 - 21mm wrench
    1/2 (13mm) wrench
    1/2 (13mm) socket
    3/8 rachet
    Pipe wrench
    Measure tape (just for show)
    95 Silverado RCLB Z71 3/4 ton
    6" ProComp 3" BL
    38x15.50x20 Nitto Mud Grapplers on 20x10 Eagle Alloy 064 Series
    06 LQ9 6.0L, NV3500, 14SF with 4.88's
    True Duals, Mangaflow Dual-in Dual out with 45's
    CENTEXOFFROAD LiftedVictory's Avatar
    Nov 2007
    Waco, TX
    and a 6 pack
    ***Current***
    '97 ecsb z71, 6" RCX, 3" PA BL, 35x12.50x15 procomp, other mods.
    Quote Originally Posted by HawgWyld
    The difference between a 4x4 and a penis is that with a 4x4, you actually go look for bigger holes to put it in.
    USMC
    Ol' Red
    Harrod, Ohio
    hell you dont need a 6 pack to adjust it. maybe a tall boy....a good fifteen minutes and it should be done.
    89 Chevy 6 inch Superlift, 3 inch PA body lift, Super Swamper 37x12.50x15 SSR's, 5:13's, Flowmasters, Hooker headers..thanks 454SS
    Dec 2004
    Elkhart IN
    you guys forgot about the can of skoal, or cigarettes. yeesh.
    Aug 2007
    Internets
    Have fun doing it yourself, but you'll need to grab a 19mm wrench and socket (?) and adjust the two camber plates on the UCA simultaneously.
    Nov 2004
    Thunder Bay Ontario
    Mine are 21mm , I changed them all with Dana ones when I did the lift :P
    6" ProComp 3" BL
    Nov 2004
    Thunder Bay Ontario
    The women my friend, the women ! You cant f*ck a cigarette !
    6" ProComp 3" BL
    Dec 2004
    Elkhart IN
    you ever try to smoke or chew a woman? THEY HATE THAT!
    Jan 2004
    Louisiana
    And they get really mad when you spit 'em out!
    Nov 2007
    Waco, TX
    this thread went to **** when i posted...yay for me ruining a thread
    ***Current***
    USMC
    Registered User iallen4190's Avatar
    Mar 2006
    Windham, Maine (home) Orono, Maine (school)
    for just temporary, loosen the 2 nuts on the upper control and spin the bolts, this will adjust your camber.
    03 Silverado RCSB LS, 5.3, Whipple Supercharger @ 10psi, Long Tubes, ORY, Dynomax, Tuned by Justin @ Blackbear Performace
    Nov 2007
    Waco, TX
    As long as you do both of them the same.
    ***Current***
    USMC
