Thread: Fuel Pump Relay Removed Truck still runs
Results 1 to 11 of 11
    Dec 2007
    Canada
    Hey all,
    96 Cheyenne with 305 Vortec.
    So I was cleaning out my injectors with that apparatus that connects to a compressor and the test valve on the fuel rail to burn off a can of that special injector cleaner stuff. Of course to do this, the fuel pump has to be disabled.
    I took the fuel pump relay out, and the fuel pump still ran. I had to unplug the power right from the harness going to the pump.
    I looked all over the truck for a fuel pump fuse and didn't find any. There was no air going to the apparatus at the time and it was holding the usual 50-60 psi of pressure.
    So it seems it runs without this relay in, so what exactly does this relay do? Is it just for priming? It ran for about 10 mins before I realised the pump was still running.
    Anyone have any ideas?
    Thanks!
    Dec 2004
    Elkhart IN
    Re: Fuel Pump Relay Removed Truck still runs
    probably pulled the wrong relay, since the same relay is used for several other things on the truck.
    FSC SOUTHEAST CHAPTER kirk's Avatar
    Douglasville, GA
    X2
    It can't run without the relay, since it won't run the fuel pump. There should be a picture on the fuse panel lid showing what each relay and fuse is for.
    01 SFA 1500: project truck, in pieces again
    87 Jeep Cherokee: trail rig, slowly getting built
    03 Buick LeSabre: fully loaded daily driver
    84 M1009: constantly broken money pit, finally gone
    TN
    Fuel pump relay will either be in the panel under the hood, or in the side of the dash when you open the drivers side door.
    05 Cavalier
    SWBLS12B long&low's Avatar
    Aug 2001
    Wichita, Kansas
    What kept it running was the fuel pump oil pressure switch.
    When you build enough oil pressure this switch makes and
    passes 12v to the fuel pump.
    88 Ext. cab longbed TPI 350
    99 Suburban LS Vortec 350
    90 SWB Silverado 5.3l and 4l60e 4 sale will part out
    2003 Z66 Avalanche
    Dec 2007
    Canada
    Thats what I thought but I double and triple checked the relay against the fuse and relay map on the underside of the cover.
    Thats what I thought too.
    I got this relay from under the dash. Driver side, big relay and fuse box.
    Now this is interesting. It would make sense since there are several wires going to this switch.
    Thanks for all the info!:rocking:
    I LOVE THE SNOW!!! GIMECHANIC_454's Avatar
    Auburn, NY
    you could have tunred the key on and and pulled the relays out untill the fuel pump shut off
    JUST REMEBER IF YOUR GONA DO ALOT OF DAMAGE..DON'T STOP TILL IT SOUNDS EXSPENCIVE
    :fsc:
    Member of the :fsc: 200,000 mile club :rocking:
    somewhere else
    Not only will the truck run with the relay pulled, it will START with the relay pulled. Don't believe me, go try it! It will spin over for a long time until your oil pressure comes up enough for the oil pressure switch to power up the fuel pump circuit. Check the wiring diagrams, or just go out and try it.
    Anyway, correct relay for the later OBS (95-up with the underhood convenience center on the driver's fender well) would be the one at the very front corner of the panel. (It seems like a while back I posted "front corner facing the driver's side" but I decided this morning to take my worthless 4 hours worth of sleep self outside and check one just now, and saw that's the side the maxi-fuses are on...)
    Richard
    Woodstock Ontario Canada
    I agree, my truck will start and run with the fuel pump relay removed. I was trying to dry up the cylinder by removing the pump relay and cranking the engine, this didnt work as the fuel pump still operates even with the relay removed.
    Mines a 1997 model.
    peace
    PAuly
    Jan 2007
    philly
    Yeah mine runs with it pulled too. I never understodd why until now.
    1998 Chevy K1500- Used, Abused, and Sold 1989 Camaro Iroc-Z 5.0, auto....- Sold
    1987 Dodge Dakota 2bbl, 5 spd, v6, 4x4, -scrap
    1993 Honda CBR600 F2- DD when nice out 1987 k5 blazer- bad ass
    Aug 2001
    Wichita, Kansas
    Thats why the book tells you to remove the f/p fuse.
    2003 Z66 Avalanche
