Thread: 4L60e vs. 4L80e
Results 1 to 20 of 21
    Registered User nicholasbrown59's Avatar
    Nov 2007
    Greenville N.C.
    4L60e vs. 4L80e
    What is the difference betweent the two which one is better overall?
    "Let the music be your master". Led Zeppelin
    2500 6.0 vortec
    Dec 2007
    naples,FL
    Re: 4L60e vs. 4L80e
    4l80e is a way stronger trans. hold way more hp then the 4160e also. First gear on the 4l80e is a lower ratio then the 4l60 for towing reasons.
    Ohio
    Re: 4L60e vs. 4L80e
    what are you planning on doing with your truck. They have their advantages. 4l80E much stronger and lower first whereas the 60 is a lot lighter, requires less enginge to push, but is weaker
    1997 3/4ton 454 5.38s Detroit 38.5's. Thorleys Tuned PCM etc
    1997 4Link Build Thread
    http://www.fullsizechevy.com/forum/p...ml#post5907531
    Registered User Stevens07's Avatar
    Mar 2003
    Bellefonte, Pa
    Re: 4L60e vs. 4L80e
    4L60-E 3.06 1.62 1.00 0.70 Light duty
    4L80-E 2.48 1.48 1.00 0.75 Heavy duty
    2007 GMC Sierra SLT Vmax 4.10 gears, Boss MT100 20x8.5 wheels/Cooper Zeon LTZ tires, Extang Bed cover,
    GMC Bedrug, Line of Fire, Denali Grill, GM Performance Intake, Corsa Sport Dual Exhaust, and DiabloSport Predator.
    May 2008
    Troy,Ohio
    Re: 4L60e vs. 4L80e
    4l80e actually has a [I]higher[I] first gear, but it does allow the engine to build torque without overpowering the output shaft or the rear diff.
    Manbearpig
    Re: 4L60e vs. 4L80e
    6l80e IMO
    Kiowa, KS
    Re: 4L60e vs. 4L80e
    Quote Originally Posted by Heavytruck
    1st gear is physically higher but numerically it is a lower number.
    Basically no comparison other then they are both 4 speed autos. A 4L80E with a shift kit is about twice as strong as a fairly built 4L60E, at least according to transgo it is.
    345 Horse Hemi Killa
    Jun 2008
    Virginia
    Re: 4L60e vs. 4L80e
    anyone know what the ratios are on the 4l70e?
    2006 Chevrolet Silverado Ext. Cab Vortec Max LT3, 6.0(LQ9), black, K&N intake,
    40 series Flowmaster, Line-x bed liner. SS Instrument Cluster, Corvette servo.
    Leveled with 295/70/17 Terra Grapplers.
    93 blackbear tune.
    1996 Saturn sl1 5spd 4cyl. 100hp of pure aggression
    May 2004
    Marietta, Ga.
    Re: 4L60e vs. 4L80e
    Quote Originally Posted by bad2006z71
    Same as the 60e.
    2000 RCSB, forged ls1, 4l80e, t76
    10.93@124mph 1.58 60'
    Woodstock Ontario Canada
    Re: 4L60e vs. 4L80e
    Quote Originally Posted by Quicksilverado
    Same as the 60e.
    Correct, the 4l70e is slightly strengthened 4l65e, which is a slightly strengthened 4l60e, which is and electronically controlled 4l60, which is a renamed 700r4 trans which dates back to the early 80's.
    I actually dont like the 6l80e/6l90e as the rpm drop between drop netween 1st and 2nd gear is HUGE, even worse than the 4l60e series of trans.
    First:4.02
    Second: 2.36
    Third:1.53
    Fourth: 1.15
    Fifth:0.85
    Sixth 0.67
    I do like its high 0.67:1 6th gear.
    I do like the 6l80e/6l90e transmissions torque capacity
    4l80e 440 lb/ft torque rating
    4l85e 460 lb/ft torque rating
    6l80e 469 hp,439 lb/ft torque rating
    6l90e 452 hp truck, 531 lb/ft truck, 555hp car, 550 lb/ft car.
    Another great feature of the 6l80e/6l90e transmissions is that they use a clutch to clutch arrangement, no more BANDS. Yeehaw.
    The best trans IMO would be a 4l80e with a 0.6:1 OD ratio.
    My favourite GM trans as far as automatic goes, is the thm 200r4.
    1st 2.74,
    2nd 1.57,
    3rd 1.00
    OD .67,
    R 2.29
    It has a slightly deeper 1st to get the car off the line, and a higher OD ratio to keep high rpms down.
    peace
    Pauly
    Kiowa, KS
    Re: 4L60e vs. 4L80e
    Pauly
    Do what? Over drive on the 4L80E is .75:1 which I don't particularly love but its worth it for the added strength of the transmission.
    Re: 4L60e vs. 4L80e
    I was speaking hypothetically, that the best trans for me woudl be a 4l80e BUT with a 0.6:1 OD ratio. Obviously not good for towing, but would work well for my purposes.
    peace
    PAuly
    Registered User 96SLT350's Avatar
    Sep 2006
    Ontario
    Re: 4L60e vs. 4L80e
    L60-e done me no harm behind an l31 for 286 000kms well beaten on. Mind you i have the tow package and it helps keep the tranny cooler. It is very close to it's death, But i have been saying that for 2 years now.
    Can't be a bad transmission at all. I can only imagine the added benefits of the 5 pinion planetary gears on the 4l65 and the "beast" sun shell. I am definately sticking to a properly built 4L60-e with all the goodies. I am definately regearing to 3.90 or 4.10 ratio because of the excessive loss of power and torque from 1st to second gear. It will help alot over 3.42.
    Re: 4L60e vs. 4L80e
    If you want to swap rear gears, I suggest the 4.10's if you allready have 3.42's. I went 3.08's to 4.10's. It made a difference, but it wasnt as crazy as I thought it would be.
    peace
    PAuly
    Kiowa, KS
    Re: 4L60e vs. 4L80e
    peace
    PAuly
    I went from 3.08s to 3.73s and other then being able to feel the corvette servo on the 1-2 shift and running more rpms at highway speeds I really didn't feel much difference.
    Sep 2006
    Ontario
    Re: 4L60e vs. 4L80e
    peace
    PAuly
    Did the milage go down the drain aswell?
    Oct 2011
    Pensacola, Fl
    Re: 4L60e vs. 4L80e
    With all the troubles people seem to have with the 4L60E...Id never have one. I had a V spec TH700R4 in my 85 vette and beat on it for 154K miles and it never faltered. But most everyone I know with a 4L60 has had a sun shell failure, shift problems, OD problems...ugh
    4L80E for me.
    Not so Crazy anymore... joe_too_crazy22's Avatar
    Sep 2003
    Re: 4L60e vs. 4L80e
    I have regeared my 99 nbs to 4:10 gears. I love the better acceleration and better "in town" driving gas milage. The part that suck is running at 2600 rpm's at 80 mph on my way to work. It leaves me wanting to swap to a tranny with another gear. Can a auto 5spd be swapped into a 99 4wd?
    What is "free time?" I used to know..... I think?
    I Hate You All, Equally.
    Hell, Frozen Over.
    Re: 4L60e vs. 4L80e
    It should also be mentioned, even though it may be common knowledge to some, is that the 4L60E and the 4L80E are not similar in any way.
    The way GM names these transmissions only denotes it's gears (4), Style of trans (Longitudinal or Transverse for FWD), A Useless Torque Capacity number (higher number is stronger) and finally if the transmission is electrically operated (E)
    The 4L80E is a bigger, heavier transmission, with much heavier larger components and a rock solid support for the gears and shafts. Nothing is shared with the 4L60E in terms of actual components.
    Born-Again Member
    Bladenboro, NC
    Re: 4L60e vs. 4L80e
    With a higher stalled 4L80E, would it take off alot better when compared to a factory stalled? I'm contemplating putting a higher stall torque convertor in mine but I'm scared that I will lose my normal driveability.
    93 Chevy S10 ext. cab. 4.3 5 speed 4wd -> Carbed 350 Vortec with LT4 hotcam in progress
    07 Saturn Outlook XR
