Thread: How to make your driveline brake.
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 112
    Snap-On Whore LPG PWRD's Avatar
    Dec 2007
    Medina, OH
    I contacted High angle driveline about their driveline brake and was in for a world of hurt. Their website is kinda missleading, says $299 for the brake kit. Read a little further, then you need a patented flange. Then call then and you will also need a u-joint flange. Well when all is said and done you will have $300 for the rotor and caliper, $100 for their patented flange, and another $80 for the u-joint flange.... Grand total of $480 on top of the price of the $320 SYE kit you need to run this.
    Way I found around it:
    Get the tcase output patent flange from HAD $100
    Get the caliper from TSM for $100
    Ujoint flange spicer PN# 3-2-1579 from local custom driveline place, mine was $45
    Go to local machine shop and have a 10" (depnding on clearance) 1/4" thick rotor made w/ a 2" bore and 4.25 bolt circle diameter w/ 1/2" holes, should be less than $100 (mine was free )
    I can get specs if you need anything...
    DD: 2001 Silverado 1500 ECSB 5.3L
    Project: '94 GMC ECSB - SAS resto project
    Aug 2007
    Internets
    Re: How to make your driveline brake.
    I have absolutely no use for a driveline brake, however I'd love to see pictures of yours mounted up when you have it done. I think they're cool. Is the brake an emergency brake type thing or does it just plumb into the existing brake system?
    FSC's french Canadian shane_k1500's Avatar
    CANADA! LE NORD BLANC!
    Quote Originally Posted by DarkCharisma
    i was wondering the same thing, id love to see pics too.
    -1993 chevrolet k1500 ext.cab (5" lift with 33 BFG A/T's)
    -1984 chevrolet scottsdale 3/4 ton HD (7" lift with 38's)
    truck fixing time in the maritimes!
    Wheeler
    Jun 2004
    Houghton Mi
    Its an emergency brake.
    Plan on building one for a driveline e-brake when i SYE my 241.
    Registered User bggrnchvy's Avatar
    Apr 2004
    Bay Area, CA
    What are you doing for a caliper bracket? I've got HAD's and it looks pretty simple, just curious what you came up with.
    1997 K1500 ECSB LQ9/80e/241/D60f/C14FF
    2006 Dodge 2500 610CTD/G56/271/AAM9.25/AAM11.5
    Easily annoyed by FNG's Tank's Avatar
    Jun 2002
    backwoods of arkansas
    That's good to know, I have looked into HAD's kit myself for when I do the 14SF install, and have too wondered if I could fab one myself with just trying to buy the SYE kit.
    Wheeler
    Jun 2004
    Houghton Mi
    Quote Originally Posted by Tank
    Why not run an ebrake setup on the 14b SF?
    Jun 2002
    I'd like to convert to the larger discs like I have up front, and I use my e-brake almost every time I park and with the things I have seen on disc setup parking brakes not working, I would feel much more secure using the drive line brake and taking advantage of the gearing. I have yet to see a parking brake on a disc not fade and go out after a while of use, plus I pull some larger trailers (6-10k) and the mechanical advantage I think is well worth it when parking on a hill. Just my opinion though.
    Wheeler
    Jun 2004
    Houghton Mi
    Why not try to run a stock rear disk setup, with the drum in hat style.
    Jun 2002
    Because those setups are the ones that I've seen go out, I know it can be done, I just like the advantage you get from the gearing in the rear end. Plus it's also kinda a cool factor, how many street trucks do you see or hear of running around with a drive line parking brake? Around here the number is 0, and I like to differentiate myself from the crowd.
    Dec 2007
    Medina, OH
    Quote Originally Posted by chevytaHOE5674
    If you are asking me to build you a rotor, just let me know, we have a huge chunk of 10.5" 4150 that I got my piece from.
    Dec 2007
    Medina, OH
    Quote Originally Posted by bggrnchvy
    I have not got that part yet since I have not yet cross drilled the rotor or turned it down to the correct size. Looks stupid easy to make though.
    Dec 2004
    Elkhart IN
    i have the flange, and the SYE kit already installed. now where did i plant that damn money tree.
    Dec 2007
    Medina, OH
    tell me about it... you find that tree you let me know
    tcase-300
    sye kit-320
    driveline brake- 350
    total just in tcase- 970
    Quote Originally Posted by LPG PWRD
    tcase-300
    sye kit-320
    jesus......
    Blinded' by tha Light' Big~Kenny's Avatar
    Jul 2008
    Nanaimo, BC, Canada
    Quote Originally Posted by shane_k1500
    jesus......
    1991 GMC |350 V8| 2 Alpine S-10's |Kenwood X792 |Pioneer D1200M Amp |Polk 6's |6000K HID's | CB Vortex | 20% Tint | 33x10.50 BFG on 15x8 Eagle 058 | 94+ Grill
    '89 GMC RCSB | Sold 05/08/09
    '91 VW Passat
    '00 VW Jetta - DD
    Apr 2004
    Bay Area, CA
    Go price out a 241 Box4Rocks, 6 bolt 32 spline input, 32 spline Ford output, fixed rear yoke 205 with HAD e-brake out back.
    Or just go price out a 3 speed Stak or a 4 Speed Atlas.
    Less than $1k isn't bad.
    Dec 2007
    Medina, OH
    I know, but I could have saved a ton by not running rear discs. BTW, why are your rear calipers soo damn low mounted?
    Broke ass highschool kid bigwhite93's Avatar
    Jan 2008
    Surrounded by corn in, Indiana
    1993 Chevy Full size Blazer
    1991.0 Dodge Cummins (non i/c) W350 4x4 5spd
    As always, murder comes at a price. If you want this fluffy little hitman to do your dirtywork, make an offer.
    Dec 2007
    Medina, OH
    its a cable operated parking brake, when you rear disc a 14bff you use front 3/4 ton brakes that have no provisions for parking brakes.
