Thread: Head gasket torque specs on a 2000 5.3
Results 1 to 7 of 7
    massachusetts
    Hello All,
    I pull the head on my 2000 5.3 because of a broken exhaust bolt on the drivers side. Im ready to start reassembly but have a few questions. They are listed below. Also is it worth pulling the other head and installing a new gasket. The truck has 92,000 on it.
    Thanks all
    1. Head torque spec and sequence. I have new bolts coming.
    2. exhaust bolt torque spec. Would you use Grade 8 instead?
    3. rocker arm torque spec.
    4. Intake bolt torque spec.
    S.E. Wi.
    Re: Head gasket torque specs on a 2000 5.3
    Fastener Tightening Specifications
    Application
    Specification
    Metric
    English
    Accelerator Control Cable Bracket Bolt
    10 Nm
    89 lb in
    Accessory Drive Belt Tensioner Bolt
    50 Nm
    37 lb ft
    Air Conditioning (A/C) Belt Tensioner Bolt
    50 Nm
    37 lb ft
    Air Injection Reaction (AIR) Pipe-to-Exhaust Manifold Nuts
    25 Nm
    18 lb ft
    AIR Pipe-to-Exhaust Manifold Studs
    5 Nm
    45 lb in
    Automatic Transmission Oil Level Indicator Tube Nut
    18 Nm
    13 lb ft
    Battery Cable Channel Bolt
    12 Nm
    106 lb in
    Camshaft Position (CMP) Sensor Bolt
    25 Nm
    18 lb ft
    Camshaft Retainer Bolt
    25 Nm
    18 lb ft
    Camshaft Sprocket Bolts
    35 Nm
    26 lb ft
    Clutch Pressure Plate Bolt
    70 Nm
    52 lb ft
    Connecting Rod Bolts - First Pass
    20 Nm
    15 lb ft
    Connecting Rod Bolts - Final Pass
    85 degrees
    Coolant Temperature Gage Sensor
    20 Nm
    15 lb ft
    Crankshaft Balancer Bolt (Installation Pass-to Ensure the Balancer is Completely Installed)
    330 Nm
    240 lb ft
    Crankshaft Balancer Bolt (First Pass-Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes)
    50 Nm
    37 lb ft
    Crankshaft Balancer Bolt (Final Pass)
    140 degrees
    Crankshaft Bearing Cap Bolts (Inner Bolts - First Pass in Sequence)
    20 Nm
    15 lb ft
    Crankshaft Bearing Cap Bolts (Inner Bolts - Final Pass in Sequence)
    80 degrees
    Crankshaft Bearing Cap Side Bolts
    25 Nm
    18 lb ft
    Crankshaft Bearing Cap Studs (Outer Studs - First Pass in Sequence)
    20 Nm
    15 lb ft
    Crankshaft Bearing Cap Studs (Outer Studs - Final Pass in Sequence)
    51 degrees
    Crankshaft Oil Deflector Nut
    25 Nm
    18 lb ft
    Crankshaft Position (CKP) Sensor Bolt
    25 Nm
    18 lb ft
    Crossbar Bolt
    100 Nm
    74 lb ft
    Cylinder Head Bolt (First Pass all M11 Bolts in Sequence)
    30 Nm
    22 lb ft
    Cylinder Head Bolt (Second Pass all M11 Bolts in Sequence)
    90 degrees
    Cylinder Head Bolt (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head)
    90 degrees
    Cylinder Head Bolt (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence)
    50 degrees
    Cylinder Head Bolt (M8 Inner Bolts in Sequence)
    30 Nm
    22 lb ft
    Cylinder Head Coolant Plug
    20 Nm
    15 lb ft
    Drive Belt Idler Pulley Bolt
    50 Nm
    37 lb ft
    Engine Block Coolant Drain Plugs
    60 Nm
    44 lb ft
    Engine Block Heater
    40 Nm
    30 lb ft
    Engine Block Oil Gallery Plugs
    60 Nm
    44 lb ft
    Engine Coolant Air Bleed Pipe and Cover Bolts
    12 Nm
    106 lb in
    Engine Flywheel Bolts (First Pass)
    20 Nm
    15 lb ft
    Engine Flywheel Bolts (Second Pass)
    50 Nm
    37 lb ft
    Engine Flywheel Bolts (Final Pass)
    100 Nm
    74 lb ft
    Engine Front Cover Bolt
    25 Nm
    18 lb ft
    Engine Mount Bolt
    50 Nm
    37 lb ft
    Engine Mount Bracket Bolt
    75 Nm
    55 lb ft
    Engine Mount-to-Engine Mount Bracket Bolt
    50 Nm
    37 lb ft
    Engine Rear Cover Bolt
    30 Nm
    22 lb ft
    Engine Service Lift Bracket (M10 Bolt)
    50 Nm
    37 lb ft
    Engine Service Lift Bracket (M8 Bolt)
    25 Nm
    18 lb ft
    Engine Shield Bolt
    20 Nm
    15 lb ft
    Engine Sight Shield Bolt (4.8 L, 5.3 L, and 6.0 L without RPO's Y91 and Z88)
    10 Nm
    89 lb in
    Engine Sight Shield Bolt (6.0 L with RPO's Y91 and Z88)
    9 Nm
    80 lb in
    Engine Sight Shield Bracket Bolts
    5 Nm
    45 lb in
    Engine Sight Shield Retainer Bolt
    5 Nm
    44 lb in
    Engine Valley Cover Bolt
    25 Nm
    18 lb ft
    Engine Wiring Harness Bracket Nut
    5 Nm
    44 lb in
    Evaporative Emission (EVAP) Purge Solenoid Bolt
    10 Nm
    89 lb in
    Exhaust Gas Recirculation (EGR) Valve Bolts (First Pass)
    10 Nm
    89 lb in
    EGR Valve Bolts (Final Pass)
    30 Nm
    22 lb ft
    EGR Valve Pipe-to-Cylinder Head Bolt
    50 Nm
    37 lb ft
    EGR Valve Pipe-to-Exhaust Manifold Bolt
    30 Nm
    22 lb ft
    EGR Valve Pipe-to-Intake Manifold Bolt
    10 Nm
    89 lb in
    Exhaust Manifold AIR Pipe Studs
    5 Nm
    45 lb in
    Exhaust Manifold Bolts (First Pass)
    15 Nm
    11 lb ft
    Exhaust Manifold Bolts (Final Pass)
    20 Nm
    15 lb ft
    Exhaust Manifold Heat Shield Bolts
    9 Nm
    80 lb in
    Fuel Rail Bolts
    10 Nm
    89 lb in
    Fuel Rail Cover Bolt
    9 Nm
    80 lb in
    Fuel Rail Crossover Tube Bolts
    3.8 Nm
    34 lb in
    Fuel Rail Stop Bracket Bolt
    50 Nm
    37 lb ft
    Generator Bracket Bolt
    50 Nm
    37 lb ft
    Generator Output Terminal Nut
    9 Nm
    80 lb in
    Harness Ground Bolt
    25 Nm
    18 lb ft
    Harness Ground Bolt (at Rear of Block)
    16 Nm
    12 lb ft
    Hood Hinge Bolt
    25 Nm
    18 lb ft
    Ignition Coil-to-Bracket Bolts
    8 Nm
    71 lb in
    Ignition Coil Bracket-to-Valve Rocker Arm Cover Studs
    12 Nm
    106 lb in
    Intake Manifold Bolt (First Pass in Sequence)
    5 Nm
    44 lb in
    Intake Manifold Bolt (Final Pass in Sequence)
    10 Nm
    89 lb in
    Intake Manifold Wiring Harness Stud
    10 Nm
    89 lb in
    Knock Sensor
    20 Nm
    15 lb ft
    Oil Filter
    30 Nm
    22 lb ft
    Oil Filter Fitting
    55 Nm
    40 lb ft
    Oil Level Indicator Tube Bolt
    25 Nm
    18 lb ft
    Oil Level Sensor
    13 Nm
    115 lb in
    Oil Pan Baffle Bolts
    12 Nm
    106 lb in
    Oil Pan Closeout Cover Bolt (Left Side)
    9 Nm
    80 lb in
    Oil Pan Closeout Cover Bolt (Right Side)
    9 Nm
    80 lb in
    Oil Pan Cover Bolts
    12 Nm
    106 lb in
    Oil Pan Drain Plug
    25 Nm
    18 lb ft
    Oil Pan M8 Bolts (Oil Pan-to-Engine Block and Oil Pan-to-Front Cover)
    25 Nm
    18 lb ft
    Oil Pan M6 Bolts (Oil Pan-to-Rear Cover)
    12 Nm
    106 lb in
    Oil Pan Skid Plate Bolt
    20 Nm
    15 lb ft
    Oil Pressure Sensor
    20 Nm
    15 lb ft
    Oil Pump-to-Engine Block Bolts
    25 Nm
    18 lb ft
    Oil Pump Cover Bolts
    12 Nm
    106 lb in
    Oil Pump Relief Valve Plug
    12 Nm
    106 lb in
    Oil Pump Screen Nut
    25 Nm
    18 lb ft
    Oil Pump Screen-to-Oil Pump Bolt
    12 Nm
    106 lb in
    Positive Battery Cable Clip Bolt
    9 Nm
    80 lb in
    Power Steering Pump Rear Bolt
    50 Nm
    37 lb ft
    Secondary Air Injection (AIR) Pipe Bolt
    25 Nm
    18 lb ft
    Spark Plugs - New
    20 Nm
    15 lb ft
    Spark Plugs - All Subsequent Installations
    15 Nm
    11 lb ft
    Throttle Body Nuts
    10 Nm
    89 lb in
    Throttle Body Studs
    6 Nm
    53 lb in
    Transmission Bolt/Stud
    50 Nm
    37 lb ft
    Transmission Cover Bolt
    12 Nm
    106 lb in
    Valve Lifter Guide Bolt
    12 Nm
    106 lb in
    Valve Rocker Arm Bolt
    30 Nm
    22 lb ft
    Valve Rocker Arm Cover Bolt
    12 Nm
    106 lb in
    Water Inlet Housing Bolts
    15 Nm
    11 lb ft
    Water Pump Bolts (First Pass)
    15 Nm
    11 lb ft
    Water Pump Bolts (Final Pass)
    30 Nm
    22 lb ft
    Water Pump Cover Bolts
    15 Nm
    11 lb ft
    Registered User gmsuv's Avatar
    Michigan
    Quote Originally Posted by doug1991
    Hello All,
    Thanks all
    massachusetts
    That looks like the Main bearing torque guide. Is that right?
    I need the Cylinder head torque sequence
    May 2002
    Nebraska
    For God sakes people post something usefull.
    Tighten the M11 cylinder head bolts a first pass in sequence to 30 Nm (22 lb ft).
    Tighten the M11 cylinder head bolts a second pass in sequence to 90 degrees using J 36660-A .
    Tighten the M11 cylinder head bolts (1, 2, 3, 4, 5, 6, 7, 8) to 90 degrees and the M11 cylinder head bolts (9 and 10) to 50 degrees a final pass in sequence using J 36660-A .
    Tighten the M8 cylinder head bolts (11, 12, 13, 14, 15) to 30 Nm (22 lb ft). Begin with the center bolt (11) and alternating side-to-side, work outward tightening all of the bolts.
    Intake 89 inch pounds
    Rockers 22 ft pounds
    Exhaust 18 pounds, bolts are metric thread. At least put all new ones in.
    Nick
    Supporting Member
    WI
    Quote Originally Posted by 71 CREWCAB
    I got something useful out of that post. I found I've been way overtightening my oil pan drain plug. Good info Mudbuddy.
    massachusetts
    thanks for the info guys. The head is on the truck and the exhaust noise is gone. Again i appreciate everyones help.
