Thread: Negative side of coil?
Results 1 to 9 of 9
    Dec 2007
    Taxis River, NB Canada
    I have a 1990 C1500 305 with no factory tach that I wan't too put a aftermarket one in and I'm confused as too where the negative side of the coil is. Because there is no terminal like the old external coil's and the book say's there's 2 lives going in and it's grounded from the motor. How or where would I find where too hook the tach wire up?
    Diesel Nut justy's Avatar
    Minnesota
    Re: Negative side of coil?
    I think on some chevys, if you look at the distributor there's a brown wire hanging loose. Seems to me that was used for a tach.
    2007 3500HD NBS Duramax
    Registered User mnstrjim's Avatar
    Sep 2008
    Chillicothe Texas
    The tach signal wire should be connected to the tach terminal on the distributor cap. On your distributor cap, locate the place where the electrical plug attaches. You will see that the plug attaches to the back pair of terminals on the cap that feed the ignition coil inside the cap. There are 2 other terminals in this same area; connect the tach wire to the one on the left front. You may need to take the cap off and turn it over to see these terminals.
    1984 K5 blazer. Corp 14 ff with disc brakes and mini spool, Corp 10 bolt in front with detroit locker and Chromoly axles with CTM joints , 4:88 gears, T350-NP205, hydro assist steering, full cage, 383 stroker with 770 offroad avenger carb. 38.5 boggers
    go here for wiring diagram:
    http://www.fullsizechevy.com/forums/...3&d=1206741675
    pink wire is from ignition.
    Matching Ninja 500r
    Dec 2004
    Elkhart IN
    Quote Originally Posted by mnstrjim
    he has small cap remote mounted coil HEI, this info wont help him any. its for big cap, in cap mounted coil.
    Dec 2007
    That's my problem.
    Jul 2007
    Missouri
    there is a wire in the harness somewhere...that is a white wire with a connector on the end..that doesnt go anywhere its the tach test spot..use it.
    Dec 2007
    Thank's for the info I'll look for it when I get time sorry for the late reply I couldn't get too a coumputer for a while.
    May 2008
    Troy,Ohio
    I couldn't find a tach lead for my 02 van either. I had to locate the negative coil wire and scotch-lock to it. I installed 2-1/16 inch Nordskog digital tach and tranny temp guages.
