Thread: Can someone please decode my VIN?
Page 1 of 14 12311 ... LastLast
Results 1 to 20 of 271
    Registered User shanerocks's Avatar
    Jan 2008
    Winnipeg
    Looking for whatever youcan get. Claim History too if possible.
    Thanks
    1GCEK14V1XE140499
    S.E. Wi.
    Re: Can someone please decode my VIN?
    VIN : 1GCEK14V1XE140499
    VEHICLE INFORMATION
    Merchandising Model : CK15903 Warranty Start Date : 09/03/1999
    BARS Order Type : 70 - RETAIL - STOCK
    Delivering Dealer : MURRAY CHEVROLET HUMMER LTD PARTNERSHIP
    1700 WAVERLEY STREET
    WINNIPEG , MB R3T5V7
    (204) 261-6200
    Selling Source : 14 - GM OF CANADA
    Site Code : 84271
    Business Associate Code : 121680
    Service Contract : Yes Branded Title : No Warranty Block : No PDI Status : Paid
    REQUIRED FIELD ACTIONS
    Type Number Description Posted Date Status
    RC 00024 FRONT BRAKE HOSE ABRASION N/A Closed
    RC 00045 FRONT SAFETY BELT COMPLIANCE N/A Closed
    RC 00093 FRONT BRAKE PIPE CONTACT WITH BODY CROSS SILL N/A Closed
    RC 06019 TAILGATE SUPPORT CABLE REPLACEMENT N/A Closed
    SERVICE INFORMATIONAL ITEMS
    Vehicle Has No Current Record Of Outstanding Service Information
    ON STAR AND XM SATELLITE RADIO INFORMATION
    Vehicle Has No Associated On Star or XM Radio Information.
    APPLICABLE WARRANTIES
    Description Effective Date Effective Odometer End Date End Odometer
    36/60000 BUMPER TO BUMPER LIMITED WARRANTY 09/03/1999 209 kilometres 09/03/2002 60209 kilometres
    72/160000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 09/03/1999 209 kilometres 09/03/2005 160209 kilometres
    96/130000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 09/03/1999 209 kilometres 09/03/2007 130209 kilometres
    36/60000 FEDERAL EMISSION 09/03/1999 209 kilometres 09/03/2002 60209 kilometres
    CLAIM HISTORY
    R.O Date R.O Number Type Labor Operation Odometer Reading
    05/07/2007 274555 # V1462 - 06019 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 169910 kilometres
    11/07/2003 330296 0 L1200 - FUEL TANK FUEL PUMP MODULE REPLACEMENT 108626 kilometres
    11/07/2003 330296 0 T2020 - TOWING 108626 kilometres
    11/07/2003 330296 0 Z7901 - 1-DAY COURTESY TRANSPORTATION 108626 kilometres
    02/24/2003 294790 0 J3480 - WATER PUMP REPLACEMENT 96684 kilometres
    02/24/2003 294790 0 J5670 - MASS AIRFLOW SENSOR REPLACEMENT 96684 kilometres
    02/24/2003 294790 0 Z7902 - 2-DAY COURTESY TRANSPORTATION 96684 kilometres
    02/24/2003 294790 # L2300 - CONVERTER, OXIDATION CATALYTIC - REPLACE 96684 kilometres
    10/19/2002 278810 0 E2927 - UPPER CONTROL ARM BALL JOINT REPLACEMENT - BOTH SIDES 95198 kilometres
    10/19/2002 278810 0 E2937 - LOWER CONTROL ARM BALL JOINT REPLACEMENT - BOTH SIDES 95198 kilometres
    10/19/2002 278810 0 E8047 - STEERING LINKAGE INNER TIE ROD REPLACEMENT - BOTH SIDES 95198 kilometres
    10/19/2002 278810 0 K7285 - REACTION GEAR SET AND/OR REACTION SUN SHELL - REPLACE 95198 kilometres
    10/19/2002 278810 0 Z7904 - 4-DAY COURTESY TRANSPORTATION 95198 kilometres
    04/03/2002 252233 0 R0830 - CD (COMPACT DISC) PLAYER (REMOTE) - REMOVE AND REPLACE CD 90879 kilometres
    04/03/2002 252233 1 R0830 - CD (COMPACT DISC) PLAYER (REMOTE) - REMOVE AND REPLACE CD 90879 kilometres
    03/21/2002 250722 0 C0183 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - LEFT SIDE 90820 kilometres
    03/21/2002 250722 0 K4123 - TRANSFER CASE SHIFT CONTROL SWITCH REPLACEMENT 90820 kilometres
    03/21/2002 250722 # V0523 - REPLACE DRIVERS & PASS SEAT BELT RETRACTORS 90820 kilometres
    03/21/2002 250722 # V0609 - INSPECT BRAKE PIPE & INSTALL SPACER CLIP 90820 kilometres
    02/14/2001 145869 0 F1002 - UNIVERSAL JOINT, REAR PROPELLER SHAFT - FRONT - REPLACE 70485 kilometres
    02/14/2001 145869 0 F1447 - SEALS, FRONT DIFFERENTIAL OUTPUT SHAFT - FRONT - BOTH - RE 70485 kilometres
    02/14/2001 145869 0 F2022 - SEAL, PINION SHAFT OIL - FRONT DIFFERENTIAL - REPLACE 70485 kilometres
    02/14/2001 145869 0 J1000 - PAN AND/OR GASKET, OIL - REPLACE 70485 kilometres
    02/14/2001 145869 0 Z7902 - 2-DAY COURTESY TRANSPORTATION 70485 kilometres
    07/19/2000 184312 # H2480 - BRAKE PRESSURE MODULATOR VALVE REPLACEMENT 42013 kilometres
    07/19/2000 184312 # Z7905 - 5-DAY COURTESY TRANSPORTATION 42013 kilometres
    07/19/2000 184312 # H2505 - ELECTRONIC BRAKE AND TRACTION CONTROL MODULE REPLACEMENT 42013 kilometres
    07/19/2000 184312 # J0547 - SPRING, CAP AND/OR SEAL, VALVE - ONE CYL - BOTH BANKS - RE 42013 kilometres
    07/05/2000 182671 # B7010 - EMBLEM AND/OR NAMEPLATE - ONE - REPLACE 40204 kilometres
    07/05/2000 182671 # Z7901 - 1-DAY COURTESY TRANSPORTATION 40204 kilometres
    06/21/2000 181006 # B7010 - EMBLEM AND/OR NAMEPLATE - ONE - REPLACE 38709 kilometres
    06/21/2000 181006 # B8290 - REAR WHEEL OPENING FLARE REPLACEMENT - RIGHT SIDE 38709 kilometres
    06/21/2000 181006 # C0182 - FRONT SIDE DOOR WINDOW REGULATOR REPLACEMENT - RIGHT SIDE 38709 kilometres
    06/21/2000 181006 # E7700 - SHAFT, STEERING INTERMEDIATE - REPLACE 38709 kilometres
    06/21/2000 181006 # V0486 - 1999-00 CV & GMC C/K 1/2T P/U - INSTALL NOTICE LABEL 38709 kilometres
    11/03/1999 158565 # C6011 - ADJUSTER ASSEMBLY, FRONT SEAT MANUAL - BUCKET SEAT - DRIVE 8914 kilometres
    11/03/1999 158565 # Z7901 - 1-DAY COURTESY TRANSPORTATION 8914 kilometres
    02/01/1999 134757 # J4226 - SPARK PLUG REPLACEMENT 12 kilometres
    12/07/1998 A40499 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 kilometres
    S.E. Wi.
    VIN 1GCEK14V1XE140499
    VEHICLE BUILD
    Gross Vehicle Weight Rating : 2906 kg (6408 lb) Order Number : M49418
    Build Date : 12/04/1998 Build Plant : 1XE03
    OPTION CODES
    AE7 AN4
    AU0 AU3
    A31 B30
    B32 B85
    C49 C60
    C7H DK7
    DL8 EVA
    E63 FE9
    FK2 FK3
    GMC GT4
    G80 JC5
    K05 K34
    K47 K68
    LR4 M30
    NF2 NP5
    NP8 NZZ
    PF9 QGC
    R7K SLM
    UN0 UQ3
    U19 VB3
    VG3 VXS
    V22 V73
    XGC X88
    YD3 YD6
    YE9 YGC
    ZGC ZY2
    Z49 Z71
    1SC 11L
    41U 6WY
    7WY 92D
    92I
    Austin Texas
    Hey mudbuddy, that is awesome, you must work at a dealership, could you do me a huge favor and run mine as well? I want to know everything I can about my truck. Thanks a bunch in advance.
    1GCDC14Z9MZ207236
    Jan 2008
    Winnipeg
    Thanks a lot that's great. Keep up the good work!
    S.E. Wi.
    hornsfan recheck the vin you gave me this is what I got back when I ran it.
    Select VIN to see detail information.
    No Vehicle Identification Number or Associated Open Campaign Information matching your entry was found.
    The Vehicle Identification Number you entered is : 1GCDC14Z9MZ207236 ; please VERIFY the entry you made.
    S.E. Wi.
    Knoxy here is yours
    VIN : 2GCEK19T441352740
    VEHICLE INFORMATION
    Merchandising Model : CK15753 -2004 SILVERADO LS SHORT BOX 4WD Warranty Start Date : 05/13/2004
    Delivering Dealer : LAKEWOOD CHEVROLET LTD.
    9150 - 34TH AVENUE
    EDMONTON , AB T6E5P2
    (780) 462-5959
    Site Code : 82106
    Business Associate Code : 120508
    Service Contract : No Branded Title : No Warranty Block : No PDI Status : Paid
    Vehicle Has No Current Record Of Outstanding Campaigns
    36/60000 BUMPER TO BUMPER LIMITED WARRANTY 05/13/2004 45 kilometres 05/13/2007 60045 kilometres
    72/160000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 05/13/2004 45 kilometres 05/13/2010 160045 kilometres
    96/130000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 05/13/2004 45 kilometres 05/13/2012 130045 kilometres
    36/60000 FEDERAL EMISSION 05/13/2004 45 kilometres 05/13/2007 60045 kilometres
    CLAIM HISTORY
    08/23/2004 178791 # B5940 - STRIKER, LIFTGATE - RIGHT - REPLACE 22982 kilometres
    04/05/2004 A52740 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 kilometres
    VIN 2GCEK19T441352740
    VEHICLE BUILD
    Gross Vehicle Weight Rating : 2906 kg (6408 lb) Order Number : M82107
    Build Date : 04/05/2004 Build Plant : 24153
    OPTION CODES
    AE7 - 40/20/40 FRONT SPLIT BENCH SEAT
    AG1 - 6-WAY POWER DRIVER'S SEAT
    AJ1 - DEEP TINTED REAR GLASS
    AL0
    AM7 - 60/40 SPLIT FOLDING REAR SEAT
    AU0 - REMOTE KEYLESS ENTRY SYSTEM
    AU3 - POWER DOOR LOCKS
    A31 - POWER WINDOWS AND DOOR LOCKS
    BVE - TUBULAR SIDE STEPS, CHROME
    B30 - FLOOR CARPETING
    B32 - FRONT AND REAR FLOOR MATS
    B33 - REAR FLOOR MATS
    B71 - FENDER FLARE MOULDINGS
    B85 - BODY SIDE MOULDINGS
    CJ3 - AIR CONDITIONING, DUAL ZONE
    C49 - REAR WINDOW DEFOGGER
    C7H - GVWR: 2903 KG (6400 LB)
    DF5 - ELECTROCHROMIC ISRV MIRROR
    DK7 DL8 - DUAL ELECTRIC HEATED MIRRORS
    DNR EVA
    E63 - FLEETSIDE BODY OPTION
    FE9 - FEDERAL CERTIFICATION EMISSION
    FK2 FK3
    GT4 - 3.73 REAR AXLE RATIO
    G80 - AXLE - LOCKING DIFFERENTIAL
    JC3 JJG
    KNP - TRANSMISSION FLUID COOLER
    KUP - ENGINE PTO CONTROL VARIABLE SPEED
    K05 - HEATER - ENGINE BLOCK
    K34 - CRUISE CONTROL
    K47 - HIGH CAPACITY AIR CLEANER
    K68 - 105 AMP DELCOTRON GENERATOR
    LM7 - VORTEC 5300 SFI V8 ENGINE
    M30 - 4-SP ELECTRONIC AUTO/OVERDRIVE
    NP5 - LEATHER WRAPPED STEERING WHEEL
    NP8 - AUTOTRAC - AUTOMATIC 4WD
    NT8
    NZZ - OFF-ROAD SKID PLATE PACKAGE
    OSG P25 - 17" 5-SPOKE ALUMINUM WHEELS (4)
    QJP - TIRES - P265/70R-17" OOR BW (4) R5C
    R6M - SILVERADO SPECIAL EDITION
    R7K - EQUIPMENT ADJUSTMENT - SPARE TIRE LOCK NOT AVAILABLE
    R7M - DEALER INVOICE CREDIT
    R9Z
    SAF - SPARE TIRE LOCK SLM
    TR3 - COLOUR-KEYED GRILLE
    T96 - FOG LAMPS
    UB0 - RADIO - CD PLAYER,
    RDS, ATC UK3 - STEERING WHEEL MOUNTED CONTROLS
    UQ3 - PERFORMANCE ENHANCED AUDIO 6 SPEAKER SYSTEM
    U19 - KILO SPEEDOMETER
    VB3 - CHROME REAR STEP BUMPER VCG
    VG3 - CHROME FRONT BUMPER
    VR4 - WGHT DIST. PLATFORM TRLER HITCH
    VXS V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
    XJP X88
    YD3 YD6 - REAR SPRING BASE EQUIPMENT
    YE9 YJP
    ZGC ZY1 - SOLID PAINT
    Z31 - PRELIMINARY INVOICE
    Z49 - CANADIAN BASE EQUIPMENT
    Z71 - OFF-ROAD CHASSIS EQUIPMENT
    Z82 - H.D. TRAILERING EQUIPMENT
    1SD - PREFERRED EQUIPMENT GROUP
    6YH
    62U - DARK GRAY METALLIC
    69D - DARK CHARCOAL
    69I 7YH
    Registered User hotrod_suburban's Avatar
    Nov 2008
    o`fallon mo.
    thats pretty cool, how far back does it go? ive got a 95 , if its not tomuch trouble could you do mine?
    1GNEC16K2SJ352870
    1982 Toyota Celica Supra, 5 speed
    Registered User Knoxy's Avatar
    Jun 2008
    Edmonton, AB, Canada
    THANK YOU SO SO MUCH!
    looks like my truck is in as good of shape that the guy said... i guess there are truthful people out there!
    thanks again! you are the MAN!!!!
    2004 Chev Silverado ECSB NBS 5.3 L 4X4
    Mods: Billet Grille, K&N 77 Series CAI Kit, Trans Dapt TBS,Painted Emblem, Pioneer AVH-P4000 Double Din DVD Deck, 2- 10" JBL GTO series Subwoofers, 1- 700 W JBL mono AMP, Smoked LED Tail Lights, and much more to come! suggestions are welcome!
    S.E. Wi.
    Your welcome knoxy,
    Hotrod this is what I got when I ran yours
    The Vehicle Identification Number you entered is : 1GNEC16K2SJ352870 ; please VERIFY the entry you made.
    Nov 2008
    o`fallon mo.
    hmmm thats weird , the vin is correct because i just ran it through carfax . guess its to old
    Aug 2003
    edmonton alberta canada
    I just bought a 99 tahoe and would love to know all i can about it could you please do mine?? thanks!
    IGNEK13R7XJ381132
    Jul 2007
    Missouri
    mudbuddy will you run mine aswell?
    1GCDC14H5MZ144319 - right off the title..
    Registered User slickmainer's Avatar
    May 2008
    Auburn Maine
    very cool mudbuddy, and thanks for the cost info on the other thread. would you mind running my vin so i can see what the guy might have had done before I got it. the carfax says it sat jumped from dealer to dealer for a couple of years. i'll send a seperate email.
    1999 Tahoe LT 4x4
    CarDomain Photos of Tahoe
    1983 Suburban C10- 2wd,350,700r4-sold
    S.E. Wi.
    I will do them as I have time but I don't pm the info there is to much and it takes 3 pm's to get it all thru, so if you don't want your vin and the info on the thread I can't help you out.
    May 2008
    Auburn Maine
    1GNEK13R3XJ473886
    if you have time, if not then no biggie.
    thanks in advance.
    1999 Tahoe LT 4x4
    May 2008
    Auburn Maine
    sure you can post it here
    1999 Tahoe LT 4x4
    Nov 2008
    Glasgow, MT
    Thats awesome! If it's no problem, could you do this one for me? You can post it here.
    2GCEK19ROT1212140
    I don't know if that is a 0 or an O between the R and the T.
    Thanks no hurry.
    S B0MB xx_ED_xx's Avatar
    Dec 2005
    ****ing, Austria
    Quote Originally Posted by raptr98
    2GCEK19ROT1212140
    Thanks no hurry.
    VIN 2GCEK19R0T1212140
    VEHICLE BUILD
    Merchandising Model : CK10753 -1996 EXT CAB SWB FLTSDE PICKUP 4WD
    Gross Vehicle Weight Rating : 2817 kg (6211 lb) Order Number : 687XF4
    Build Date : 05/08/1996 Build Plant : 2T153
    GMVIS is not the definitive source of GM Vehicle RPO information and is intended for service reference only. Should there be any questions about the vehicle's original build or RPO information please refer to the original vehicle invoice or window sticker.
    OPTION CODES
    AG9 - SIX-WAY POWER SEAT AJ1 - DEEP TINTED GLASS
    AM7 - FOLDING REAR SEAT AU0 - REMOTE KEYLESS ENTRY
    AU3 - POWER DOOR LOCK SYSTEM A20 - SWING OUT QUARTER WINDOWS
    A31 - POWER WINDOWS A95 - HIGH BACK RECLINING BUCKET SEATS WITH FLOOR CONSOLE
    BZY - BEDLINER B32 - FRONT COLOR-KEYED FLOOR MATS
    B33 - REAR COLOR-KEYED FLOOR MATS B85 - BRIGHT BODY SIDE MOLDINGS
    B96 - WHEEL OPENING MOLDINGS C49 - ELECTRIC REAR WINDOW DEFOGGER
    C60 - AIR CONDITIONING D48 - DUAL ELECT REMOTE CONT MIRRORS
    D55 - CONSOLE E24 - EASY ACCESS SYSTEM/THIRD DOOR
    E63 - FLEETSIDE BODY FE9 - 50 STATE EMISSIONS
    FK2 - TORSION BAR SPRING ADJUSTMENT FK3 - TORSION BAR SPRING ADJUSTMENT
    GU6 - REAR AXLE 3.42 RATIO JB5 - VAC POWER DISC/DRUM BRAKES
    KNP - HD AUXILIARY TRANSMISSION COOLING SYSTEM K05 - ENGINE BLOCK HEATER
    K34 - ELECTRONIC SPEED CONTROL K60 - 100 AMP DELCOTRON GENERATOR
    L31 - VORTEC 5700 V8 SFI ENGINE M30 - 4 SPEED ELECTRONIC AUTOMATIC TRANSMISSION WITH OVERDRIVE
    NA1 - LIGHT DUTY EMISSIONS NF2 - FEDERAL EMISSION SYSTEM
    NG5 - 50-STATE EMISSION CERT. REG. NP1 - ELECTRONIC SHIFT TRANSFER CASE
    NP5 - LEATHER WRAPPED STEERING WHEEL NRQ - CLOSE COUPLED EXHAUST
    N33 - COMFORTILT STEERING WHEEL OSG - OSHAWA PLANT
    PF4 - CAST ALUMINUM WHEELS Q4B - 6,200 LB GVW RATING
    RSA - PASSIVE AUTO FRT SEAT RESTRAINT R9Z - POMS AUTO SEQUENCE
    SLL - SOLD ORDERS UP0 - AM/FM STEREO W/CASS & CD PLAYER
    UQ3 - ENHANCED AUDIO SPEAKERS VB3 - CHROMED REAR STEP BUMPER WITH RUB STRIP
    VG3 - FRONT DELUXE CHROMED BUMPER WITH RUB STRIP VK3 - FRONT LICENSE PLATE MOUNT
    VXS - COMPLETE VEHICLE LABEL V10 - COLD-CLIMATE PACKAGE
    V22 - DELUXE FRONT APPEARANCE V73 - STATEMENT OF VEHICLE CERT.-U.S. /CANADA
    XGA - P245/75R 16 BW FRT TIRES X88 - CHEVROLET CONVERSION
    YD3 - BASE EQUIP FOR SCH GVW PL-FT AX YD6 - BASE REAR SPRING
    YE9 - SILVERADO YGA - P245/75R 16 BW REAR TIRES
    ZGA - P245/75R 16 BW SPARE TIRE ZQ3 - TILT STEERING AND SPEED CONTROL
    ZY1 - SOLID PAINT 1SB - PREFERRED EQUIPMENT GROUP REJECT
    1SZ - PREFERRED EQUIPMENT SAVINGS 26D - BLUE CUSTOM CLOTH TRIM
    26I - DARK BLUE INTERIOR 27U - LIGHT BLUE METALLIC
    6GH - FRONT SPRING SELECTOR LH 7GH - FRONT SPRING SELECTOR RH
    Dec 2005
    ****ing, Austria
    Quote Originally Posted by slickmainer
    1GNEK13R3XJ473886
    thanks in advance.
    Wow yours is wierd it list the rpo's but no info
    VIN 1GNEK13R3XJ473886
    VEHICLE BUILD
    Merchandising Model : CK10706
    Gross Vehicle Weight Rating : 3087 kg (6807 lb) Order Number : BHTSXM
    Build Date : 03/11/1999 Build Plant : 1XJ06 - JANESVILLE ASSEMBLY PLANT
    OPTION CODES
    AE7 AG9
    AJ1 AM7
    AU0 AU3
    AXP A31
    B32 B33
    B85 B96
    C49 C5U
    C60 DF5
    D48 EVA
    FK2 FK3
    GU6 JAN
    JB6 KC4
    KNP K34
    K60 L31
    M30 NA1
    NC7 NF2
    NG1 NP5
    NP8 N33
    PF4 QGB
    R8T SLM
    UP0 UQ3
    VGC VK3
    VR4 VXS
    V22 V54
    V73 XGB
    X88 YD3
    YD6 YE9
    YGB ZGB
    ZQ3 ZW9
    ZY1 Z82
    1SC 1SZ
    11U 52I
    522 6YB
    7YB
