Thread: Which spark plugs for Vortec headed Tbi
Results 1 to 20 of 23
    Jun 2008
    Union, Missouri
    I have searched and searched but can't find the answer I want.
    With my vortec head swap(mods and truck in sig) which sparkplugs will work the best and fit the best with headers?
    I do mostly city driving like 6 miles one way so Im not sure whether to use a hotter or colder plug?
    I have read use either the ACDelco R44LTS or R44XLS but not sure.
    Thanks
    Devin
    S/C Z71
    Re: Which spark plugs for Vortec headed Tbi
    Stock heat range. NGK or ACDelco.
    Austin Texas
    x2, I use ACDelco and recommend it to everyone that drives a GM. Any spark plug will work fine, some brands are better than others.
    Jun 2008
    Union, Missouri
    i was going to use ACDelco's but what part number should I use.
    because I know I can't just use any plug I pick.
    Thanks
    Devin
    S/C Z71
    Use whatever is stock for a 350 vortec. Not sure of the part number.
    Registered User haulinit's Avatar
    ottumwa,ia
    Dont use ACCEL U-Groove header plugs i made that mistake, my truck started missing and dying at stop lights. As soon as I changed them back to delco's it ran like a champ.
    98 silverado 4wd 3.73gears,5.7l,headers,under drive pulleys,78mm ported and polished tb, k&n fipk,catback, zz4 cam, roller rockers, lt4 valve springs, 411 swap tuning by me.
    Quote Originally Posted by Redneck Rebel View Post
    fsc demo derby time. Would've been a better disposal system than the Cash4Clunkers BS
    Oct 2005
    Kentucky
    I use the R44LTS
    Kiowa, KS
    Quote Originally Posted by S/C Z71
    Those cost too much.
    In 96 they started using platinum or iridium long life plugs. They are fine, just cost too much for my tastes. I put NGK TR5 GP plugs in mine. That would be a platinum plug, 2.40 ish a plug vs about 4 for the AC Delco's and just as good, maybe better.
    Jun 2008
    Union, Missouri
    thanks guys that helps a lot. What kind of gap are you guys running with the ACdelco's and NGK's?
    I will have taylor wires and an MSD high output coil with mods in sig.
    Also Oldred95 I know you did the vortec head swap so is there any little tips or tricks that would help me out cause I'm doin the swap over christmas.
    I'm going to keep the stock throttle body with ultimate TBI mods and injector spacer will this be enough air to feed this thing to 5000RPM?
    Also what would be a good fuel psi to start with? I'm using the stock 61LB/HR. injectors
    Sorry for all the questions
    Thanks
    Devin
    S/C Z71
    You're right. I use copper core NGK TR6's. I won't but platinums or iridiums again. Besides copper is a better conductor. What do you run for a gap oldred? I'd think .035-.040 would be good.
    Kiowa, KS
    It may be a better conductor initially but it doesn't last forever and only gets worse with age. Chrysler uses, or did use copper plugs in everything up until a year or so ago and every 30k they need plugs and are always burnt to a crisp.
    The platinums came gapped at .040 and there is no real safe way to open the gap without risk of damaging the electrode and .040 is good so I left them at that. That was the recommended gap for the plugs also. Now the AC Delco plugs are supposed to gap to .060.
    Jun 2008
    Union, Missouri
    Thanks
    Devin
    S/C Z71
    Yeah you definately need to change them more often than platinum or iridium.
    Jun 2008
    Union, Missouri
    bump
    S/C Z71
    What's up?
    Jun 2008
    Union, Missouri
    i had a couple questions in my post 3 posts back and didn't getany answers but I think that they just got over looked so no biggie I was just gonna see if you or anybody else had any input on my questions.
    and to add one more question, I am doing this rebuild on the stock bottom end with about 160000 miles and was just wondering when I get it apart if I should hone the bores and replace the main and rod bearings along with a set of new rings.
    Thanks
    Devin
    S/C Z71
    Not too sure on the fuel pressure (13-15maybe) but your TB should easily be good to 5000. As for the honing, bearings and rings......I would. It's cheap insurance.
    Jun 2008
    Union, Missouri
    Thank you very much. I found the bearings and rings for about
    100$ so that isn't to bad considering what I would save if I had to get a new shortblock. I just wanted some opinions so I probably will.
    I'm gonna try about 25 psi to start but not sure, I was hoping someone that did the head swap would tell me but I will just have to play with it.
    Thanks
    Jun 2008
    Union, Missouri
    Can I use the stock intake bolts with my new manifold with the vortec heads?
    Thanks
    Devin
    S/C Z71
    I'd buy new ones.
