Thread: Rock Sliders
Page 1 of 3 123 LastLast
Results 1 to 20 of 54
    Aug 2007
    louisiana
    Rock Sliders
    Im planning on making some rock sliders and im looking for some input as to what material and thikness to use. Also how many frame connections and the distance from the rocker panel. this is what i have as far as design. The round tube will stick out further than the body pannels so i can pusf off of trees.
    Also im looking for some pics for maybe some different ideas.
    98 2 door z71 tahoe, leveled with 33" BFG Mud Terrains, KC Light Bar, Kicker CVR 12's, RF Power 250.2(old school), Alpine R-Type Components
    Snap-On Whore LPG PWRD's Avatar
    Dec 2007
    Medina, OH
    Re: Rock Sliders
    Kyle's sliders
    DD: 2001 Silverado 1500 ECSB 5.3L
    Project: '94 GMC ECSB - SAS resto project
    Wheeler
    Jun 2004
    Houghton Mi
    Re: Rock Sliders
    2x3 3/16 wall for the rectangle. 3 frame supports. The round tube is 1.25 .120 wall.
    And unless you make them stick out a longgggg ways they wont allow you to really push off trees unless you are on perfectly flat ground. As soon as you get on an angle the roof sticks out a ways.
    CENTEXOFFROAD LiftedVictory's Avatar
    Nov 2007
    Waco, TX
    Re: Rock Sliders
    Yeah, at least 3/16 wall, and I would put 4 points to mount to the frame.
    ***Current***
    '97 ecsb z71, 6" RCX, 3" PA BL, 35x12.50x15 procomp, other mods.
    Quote Originally Posted by HawgWyld
    The difference between a 4x4 and a penis is that with a 4x4, you actually go look for bigger holes to put it in.
    USMC
    BigRed05
    Re: Rock Sliders
    I will take a picture of mine this weekend I made. They are 1.75 HERW .120.
    Wheeler
    Jun 2004
    Houghton Mi
    Re: Rock Sliders
    Quote Originally Posted by LiftedVictory
    He has a 2 door tahoe what is the need for 4 attachment points?
    Aug 2007
    louisiana
    Re: Rock Sliders
    im fine with overkill. I mean what would be the disadvantage of doing more? also where do yall order steel from?
    Dec 2007
    Medina, OH
    Re: Rock Sliders
    no disadvantage, your local steel yard
    Wheeler
    Jun 2004
    Houghton Mi
    Re: Rock Sliders
    No disadvantage, just a matter of fitting them all in there. I have 3 supports and have little deflection when lifting the truck up.
    Aug 2007
    louisiana
    Re: Rock Sliders
    how much do yall think these will cost? just raw steel. i can do all the fab myself.
    Wheeler
    Jun 2004
    Houghton Mi
    Re: Rock Sliders
    A lot depends on what material you use for the round stock. If you go with a DOM tube it is more pricey than HERW.
    Going to weld them directly to the frame or bolt them on? If you bolt them on like I did then you need plate to bolt to.
    BigRed05
    Re: Rock Sliders
    Where are you in Louisiana. In Hammond they have Tangy industrial, thats where I get all my steel from. I order DOM from Ballistic Fab.
    Aug 2007
    louisiana
    Re: Rock Sliders
    im in baton rouge. Whats the difference in dom and herw?
    Registered User DirtyGmc's Avatar
    New England
    Re: Rock Sliders
    i only have two mounts, bolted on with 1/2" plates and i can jack my truck up with them with minimal deflection. The material i used was 2.5" 3/16 wall square tubing and 2" .125 wall DOM. I havent really dropped my truck on them though, but ive dragged the bottom quite a bit and they havent fail yet.
    In hindsite i would definitely add some more bracing and maybe another mount. Im sure if i dropped of a rock onto them (i dont rock climb so im not too worried) they would bend/break. Also, in your drawing in the first post, i would definitely box the tube in on the ends to keep crap out. (im sure you were anyway).
    1998 GMC K1500
    2009 VW Jetta TDizzle
    My Flickr
    Registered User bggrnchvy's Avatar
    Apr 2004
    Bay Area, CA
    Re: Rock Sliders
    Quote Originally Posted by ahilto3
    Process and yield strength as well as surface hardness.
    My round tube is 1-1/2 HREW and it's yielded in the middle of the span under the passenger door. It's only about an inch, and it took a hard hit but it did fail technically. I'm not planning to replace it however.
    Both DOM and HREW will deflect the same amount under the same load. The question is at what point will they not return to their original shape (yield point). DOM will elastically deform past the point HREW will yield meaning it can absorb more impact before you will see visual result from the load after the fact. With steel's fatigue life it's a very nice extra bit to have.
    As of November ~20th 1-3/4" .120 DOM was $3.23/ft IIRC and HREW in the same size was ~$2/ft (my HREW was free so I can't be 100% of the $/ft amount).
    1997 K1500 ECSB LQ9/80e/241/D60f/C14FF
    2006 Dodge 2500 610CTD/G56/271/AAM9.25/AAM11.5
    Gearhead! BIGGMC's Avatar
    Oct 2008
    Peoria, AZ
    Re: Rock Sliders
    im also planning on making a set... anyone add hi-lift jacking points on rock sliders?
    6 inch pro comp lift, 3 inch PA body lift, 38x15.50R20 Nitto Mud Grapplers
    Custom quick disconnect plexi mudflaps, Front sway bar quick disconnects
    Build Thread
    Wheeler
    Jun 2004
    Houghton Mi
    Re: Rock Sliders
    Quote Originally Posted by BIGGMC
    You mean like the entire length of tubing.....
    Oct 2008
    Peoria, AZ
    Re: Rock Sliders
    Quote Originally Posted by chevytaHOE5674
    let me rephrase. do you need to do anything special to keep the hi-lift drom sliding... like add flat spots or something
    Build Thread
    Wheeler
    Jun 2004
    Houghton Mi
    Re: Rock Sliders
    My highlift doesnt slide on the round tube unless your at an angle.
    Oct 2008
    Peoria, AZ
    Re: Rock Sliders
    thx, that was my only concern.
    what u do when your at an angle.
    Build Thread
