Thread: u joint for 14 bolt swap
Results 1 to 18 of 18
    Registered User illholla's Avatar
    Oct 2008
    nc
    ok just got my 14 bolt on and seen my u joint is too small will the uj off a 2500 fit on my 1500?
    thanks
    Dec 2004
    Elkhart IN
    Re: u joint for 14 bolt swap
    Neapco 2-1153
    Oct 2008
    nc
    where from?
    Oct 2008
    nc
    i found it at advanced thanks for the fast reply
    Oct 2008
    nc
    i went and got that u joint and it wont fit in my drive shaft am i suppose to do something different
    CENTEXOFFROAD LiftedVictory's Avatar
    Nov 2007
    Waco, TX
    are you sure that you don't have it backwards, there is 2 larger bearing cups and 2 smaller cups.
    ***Current***
    '97 ecsb z71, 6" RCX, 3" PA BL, 35x12.50x15 procomp, other mods.
    Quote Originally Posted by HawgWyld
    The difference between a 4x4 and a penis is that with a 4x4, you actually go look for bigger holes to put it in.
    USMC
    DBG
    Sep 2005
    San Luis Obispo, CA
    It's gonna depend on your body and drivetrain configuration. 4wd vs2wd. ext cab vs reg cab. They have different drive shafts. Look at napa.com and each ujoint lists the size specifications. Look up your truck model then look up a c2500 light duty with 14 bolt s/f. Or, best bet is to bring the 14 bolt ujoint and your stock one to the parts store with you and figure it out. If the center section of the ujoints have the same diameter you might be able to swap caps.
    Darren
    89 RCSB Dana 60/14 Bolt 4-lnk frnt/rr, 39.5's/14" Welds, 5.13, Truetrac/Detroit, AEM Intake, Holley 670 TBI, Holley Mnfld, Shorties, 40 series, no cat. 98 2wd 355, lt4 hotcam, 1.6 rllr rckrs
    Project Pics:
    http://community.webshots.com/album/366426764ygYniE
    Oct 2008
    nc
    yea my factory uj is just a little smaller then the 2 smaller caps on the neapco 2-1153 guess i need send that one back and hit up napa
    Dec 2004
    Elkhart IN
    get a pair of dial calipers, or a micrometer, then look here. i did a bunch of research on ujoints.
    http://www.fullsizechevy.com/forums/...info-pics.html
    Oct 2008
    nc
    thanks for the info
    i read it should be one of these
    S44 to 1350 is Neapco PN 2-1153
    1310 to 1350 is Neapco PN 3-3140
    1330 to 1350 is Neapco PN 2-3050
    soo ill figure it out this week sometime been watchin trucks gone wild and it makes me want to go break something
    Dec 2004
    Elkhart IN
    Quote Originally Posted by illholla
    thanks for the info
    which one? my buddy Coop is in TGW4, i didnt even know it until i got a copy, and there he was.
    Oct 2008
    nc
    i got 456 where at in 4 was he wife gotem for me for christmas
    Sep 2008
    ontario
    i had the same problem and i ended up taking the yoke off the old diff. and put it on the 14 inch
    Smokin 38s SuperChevy17's Avatar
    Sep 2006
    Southeast Texas
    I had same problem on my swap. Measure the size of the caps you need and width of the U-joint cap-to-cap, both directions. Take those dimensions to oreily or napa or wherever. They should have a book with U-joint dimensions, cap sizes, etc. Whatever u-joint fits those dimensions is the one you'll need. Keep the box or at least the part with the number on it so you wont have to do all that again when you break it. Keep it in the glovebox.
    95 Chevy 2wd TBI Vortec 350 5spd. *Ultimate Budget Engine Swap*
    Engine: 98 4-bolt Vortec 350|Scat Crank|LT4 Production Cam|1.6 Proform Full Roller Rockers|Edelbrock EPS Intake|454 Throttle Body|Hedman Elite 69840 LT|ZOOM Perfection Clutch|Custom Tune by TBIChips
    98 ecsb 4x4 38" TSLs
    S/C Z71
    Just swap the yoke.
    Dec 2004
    Elkhart IN
    Quote Originally Posted by SuperChevy17
    if its not stock, most $7/hr parts guys dont have a clue how to find it. if your local parts store has guys who actually know how to look up something non-stock, you're VERY lucky. fortunately, i have already done the work to determine which joint it is, all you have to do is measure it, and match up the part numbers to the link i posted.
    swapping the yoke isnt something for anybody to do, you'll have to install a new crush sleeve and set it properly or you'll probably screw up the gears, most of the time they will just whine, but they could fail if the setup is far enough off.
    S/C Z71
    True enough.
    Sep 2006
    Southeast Texas
    Yes I was so lucky that I had to buy 4 U-joints before somebody pulled the book out and looked at every u-joint listed to find the right one. You're right, most of the parts store guys don't have a clue how to find the right parts or even what some of the parts are. Every time I go into that store there are different people working. Good thing we have experts here with access to all the right information.
