Thread: 1989 chevy 4.3L wont start
Results 1 to 13 of 13
    FSC's french Canadian shane_k1500's Avatar
    CANADA! LE NORD BLANC!
    Well, i went outside and tried to start my truck this morning and nothing. after opening and closing the door from getting in and out the truck, the lights would come on. IT's almost most as if my batterie is dead but it's fully charged. I was thinking I might have a short somewhere. Now the lights wont come on at all. Anyone know know where I should start? I did a quick check and nothing seems to be grounding and shorting out. A bad ground maybe?
    -1993 chevrolet k1500 ext.cab (5" lift with 33 BFG A/T's)
    -1984 chevrolet scottsdale 3/4 ton HD (7" lift with 38's)
    truck fixing time in the maritimes!
    WideTurn ssw/t's Avatar
    Aug 2007
    Northern MN
    Re: 1989 chevy 4.3L wont start
    check your battery connections - i had some issues this summer with my pos terminal on my 92
    Drop A Gear
    And Keep The Oily Side Down
    TN
    X2.
    Take them off clean them, and make sure they are tight.
    05 Cavalier
    10-4 will do tonight
    From Mini to Fullsize.... Hotwheelz's Avatar
    Oct 2005
    Jasper, Indiana
    sounds like a bad ground to me... definately a good place to start.
    2009 GMC SIERRA | SLAMMED 5/7 | 22" BOSS 330'S | ASE MASTER CERTIFIED
    Quote Originally Posted by Hotwheelz
    battery posts are A-1. Truck still wont start. Where should I start looking for a bad ground? How to I do this? Anyone know where to start?
    Oct 2005
    Jasper, Indiana
    has this problem started since you pulled the bed? or added your BL? that BL could be could have stretched a ground wired out.
    i installed the body lift about 4-5 months ago, this just started to happen
    S.E. Wi.
    Check and clean all ends of all the battery cables, it sounds like one or more is corroded or loose. Make sure you check at the starter also.
    Quote Originally Posted by mudbuddy
    ok that would make sense because I just changed the starter. Maybe I forgot to tighten something. Thanks a lot guys. What ever it is it's not much. Just a pain in the a.s.s to find the probleme! haha
    TN
    You should have a ground from the engine to the body, I think one engine to frame, and I want to say a third.
    Unless they have been changed they will be the flat flex stuff.
    Except for the neg battery cable, make sure the other end of that is tight and clean too.
    Might want to check to see if the alt's grounding too.
    Did you by chance check the battery yet?
    05 Cavalier
    Quote Originally Posted by kcb37
    Battery is A-1, I just bought it and tested it
    Apr 2004
    Portland, TX
    I'm going to say that it sounds like the wire on your starter has come loose
