Thread: help!!! push clutch in and theres no pedal no nothing!!!!
Results 1 to 20 of 24
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    hey guys finally got my truck running decent, well i pulled in my drive way and parked.
    got in to start it up, i pushed clutch in, and pop, all the pedal pressure dissapears and cant shift out of gear clutch pedal does nothing!!!!
    what could this be??? slave cylinder, and master, are relatively new??? im stumped, theres no clutch pedal at all, its just free moving, and does nothing.
    355 coming back out!
    :bowtie:
    JUGS Racing SuperStepside's Avatar
    Jun 2007
    Miami, FL
    Re: help!!! push clutch in and theres no pedal no nothing!!!!
    Check for leaks. Is there fluid in the resevoir?
    1995 350 "Tool Box Injection"
    Going 4/6 with 20" Billet Specialties
    Registered User bigtfw2000420's Avatar
    Oct 2005
    south tx
    this happened to my 93 went to sonic, and left was going home pushed in clutch and tried to shift nuttin happened they made the clutch line out of plastic. its a bitch to bleed the clutch
    :fsg: 98 k1500 5.7 Magnaflow exhaust BBK 80 mm throttle body AEM brute force CAI nelson performance tune 93 octane RC 6" 285/70/17 BFG KM2 4 14 bolt sf disk brakes 4l60e fully built
    Lanark, Ontario
    Quote Originally Posted by bigtfw2000420
    The master and slave are plastic too... I nearly took out a row of parked cars before I figure out wtf was going on when it happened to me.
    I ended up replacing the line and slave, only to replace the master 2 weeks later.
    Soap, Ballot, Ammo
    Aug 2008
    Clinton, MO
    Sounds like a snapped rod. Look under the dash at the pedal near the pivot.
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    ill check all that, the slave and stuff looked good but i could see up under the dash, the rod seemed to be workin on the clutch master cylinder, theres still fluid in my line, and resovoir for the most part. thats why confused it was a snapping sound
    :bowtie:
    TN
    Did it sound like it was toward the tranny.
    Thought, maybe the clutch fork, or throwout bit it.
    Actually I don't know if you have a clutch fork.
    Anyway, it's a thought.
    05 Cavalier
    Mundelein
    souds liek maybe something by the tranny went try replacing the clutch and see of you see anything
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    i was thinking its a shift fork maybe, i dont know where it came from. its a nv3500 tranny. the clutch is brand new. so its not clutch. i know that. so i dont know. thanks for the replies so far
    :bowtie:
    Soap, Ballot, Ammo
    Aug 2008
    Clinton, MO
    Just work through it methodically. Start at the pedal and work your way from cylinder to cylinder down to the throwout bearing and pressure plate. The way you described the pedal having no resistance left me thinking snapped rod. If all was well from pedal to slave cylinder you should have at least a little resistance.
    May 2006
    Alberta Canada
    just what year and truck are we talkin here?...my first thought was a snaped fork..know some of the older models had issues and if it feels like free say that would be my first bet
    [Stole/FOUND 13/03/08 :O)
    70 fury 3
    71 sport fury GT
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    its a 93 with a nv3500 tranny heavy half ton silverado.
    :bowtie:
    Aug 2002
    Slapoutoftown, AL
    your slave or master could have went bad. if you lose a seal in one of those you will have a limp pedal. you need to figure out if it's a disconnected pedal (sounds like the linkage snapped somewhere with the sound you said it had) or if it's hydraulic. if it's hydraulic and you still have fluid and no leaks, you suffered an internal failure of either a master or slave...they are cheap enough, i'd just replace 'em both...
    Registered User 951500's Avatar
    atlantic canada
    Quote Originally Posted by FordeatinZ71
    I'd say the same thing , I would look at the master for sure. I had a bad master one time and i had NO pedal at all.all i can do is spring my pedal up and down like nothing there , so i took the internal piston & spring out of my master and replaced it with one out of a used one i had in my yard and it worked excellent.
    "Shake and bake" kidwithwrench86's Avatar
    Dec 2008
    Hopatcong, NJ
    and just because your parts are brand new doesnt mean anything. i got a new brake master, put it in, and a month later it was leaking from the secondary seal. things like that happen, your problem def sounds hydraulic.
    kids with wrenches 4x4 - hopatcong, NJ.
    proud member of the oobs and obs hood wacker clubs
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    im just gonna replace them both, is there any tips to bleeding the system easier?? i was pumping up my clutch all day yesterday, caus ei had air in my line, and then it broke when i got home. so i know it was under extra abuse.
    :bowtie:
    93 silv 4x4355 5spd
    Dec 2005
    pittsburgh pa
    problem solved thanks guys! love this site, changed them both had pedal almost immediately, works great now.
    :bowtie:
    Lanark, Ontario
    Quote Originally Posted by nobrand
    By "both" you mean master and slave?
    Did you replace the plastic line? It s prone to getting tiny pinholes in it over time and will allow air into the system.
    Aug 2002
    Slapoutoftown, AL
    Congrats on getting it fixed! But like q said, if you didn't replace the line you might want to.
    May 2006
    Alberta Canada
    little more info on what ya fixed for others and future refrence
    70 fury 3
    71 sport fury GT
