Thread: Gm Diagnostic Trouble Codes
Results 1 to 20 of 28
    2WD MONSTER 2wdchevywt's Avatar
    Aug 2007
    Connecticut
    Not sure if anyone put this up yet...
    GM Motor Company Group - Diagnostic Trouble Codes - PART 1
    Here is the list of DTC's. This is a HUGE file so it's probably easiest to
    use your scroll function to locate the code you're looking for.
    The P0000 to P1000 are all EOBD Codes.
    First digit structure is as follows:
    Pxxxx for powertrain
    Bxxxx for body
    Cxxxx for chassis
    Uxxxx for future systems
    Second digit structure is:
    P0xxx Government required codes
    P1xxx Manufacturer codes for additional emission system function; not Required but reported to the government
    Third digit structure is:
    Px1xx measurement of air and fuel
    Px2xx measurement of air and fuel
    Px3xx ignition system
    Px4xx additional emission control
    Px5xx speed and idle regulation
    Px6xx computer and output signals
    Px7xx transmission
    Px8xx transmission
    Px9xx control modules, input and output signals
    The fourth and fifth digits designate the individual components and systems.
    P0001 Fuel Volume Reg Ctrl Circ/Open
    P0002 Fuel Volume Reg Ctrl Circ Range/Perf
    P0003 Fuel Volume Reg Ctrl Circ Low
    P0004 Fuel Volume Reg Ctrl Circ High
    P0005 Fuel Shutoff Valve A Ctrl Circ/Open
    P0006 Fuel Shutoff Valve A Ctrl Circ Low
    P0007 Fuel Shutoff Valve A Ctrl Circ High
    P0008 Engine Pos Sys Perf Bank1
    P0009 Engine Pos Sys Perf Bank2
    P0010 A Camshaft Pos Actuator Circ (bank 1)
    P0011 A Camshaft Pos Timing-Over-Advanced (bank 1)
    P0012 A Camshaft Pos Timing-Over-Retarded (bank 1)
    P0013 B Camshaft Pos Actuator Circ (bank 2)
    P0014 B Camshaft Pos Timing-Over-Advanced (bank 2
    P0015 B Camshaft Pos Timing-Over-Retarded (bank 2)
    P0016 Crank Pos-Camshaft Pos Correlation Bank1 SensorA
    P0017 Crank Pos-Camshaft Pos Correlation Bank1 SensorB
    P0018 Crank Pos-Camshaft Pos Correlation Bank2 SensorA
    P0019 Crank Pos-Camshaft Pos Correlation Bank2 SensorB
    P0020 A Camshaft Pos Actuator Circ (bank2)
    P0021 A Camshaft Pos Timing-Over-Advanced (bank2)
    P0022 A Camshaft Pos Timing-Over-Retarded (bank2)
    P0023 B Camshaft Pos Actuator Circ (bank2)
    P0024 B Camshaft Pos Timing-Over-Advanced (bank2)
    P0025 B Camshaft Pos Timing-Over-Retarded (bank2)
    P0026 Intake Valve Ctrl Solenoid Circ Range/Perf Bank1
    P0027 Exhaust Valve Ctrl Solenoid Circ Range/Perf Bank1
    P0028 Intake Valve Ctrl Solenoid Circ Range/Perf Bank2
    P0029 Exhaust Valve Ctrl Solenoid Circ Range/Perf Bank2
    P0030 HO2S Heater Ctrl Circ (bank1, Sensor
    P0031 HO2S Heater Ctrl Circ Lo (bank1, Sensor
    P0032 HO2S Heater Ctrl Circ Hi (bank1, Sensor
    P0033 Turbo Charger Bypass Valve Ctrl Circ
    P0034 Turbo Charger Bypass Valve Ctrl Circ Lo
    P0035 Turbo Charger Bypass Valve Ctrl Circ Hi
    P0036 HO2S Heater Ctrl Circ (bank1, Sensor2)
    P0037 HO2S Heater Ctrl Circ Lo (bank1, Sensor2)
    P0038 HO2S Heater Ctrl Circ Hi (bank1, Sensor2)
    P0039 T/S Charger Bypass Valve Ctrl Circ Range/Perf
    P0040 O2 Sensor Signals Swapped Bank1 Sensor 1/ Bank2 Sensor 1
    P0041 O2 Sensor Signals Swapped Bank1 Sensor 2/ Bank2 Sensor 2
    P0042 HO2S Heater Ctrl Circ (bank1, Sensor 3)
    P0043 HO2S Heater Ctrl Circ Lo (bank1, Sensor 3)
    P0044 HO2S Heater Ctrl Circ Hi (bank1, Sensor 3)
    P0045 T/S Charger Boost Ctrl Solenoid Circ/Open
    P0046 T/S Charger Boost Ctrl Solenoid Circ Range/Perf
    P0047 T/S Charger Boost Ctrl Solenoid Circ Low
    P0048 T/S Charger Boost Ctrl Solenoid Circ High
    P0049 T/S Charger Turbine Overspeed
    P0050 HO2S Heater Ctrl Circ (bank2, Sensor 1)
    P0051 HO2S Heater Ctrl Circ Lo (bank2, Sensor 2)
    P0052 HO2S Heater Ctrl Circ Hi (bank2, Sensor 2)
    P0053 HO2S Heater Resistance (Bank1 Sensor 1)
    P0054 HO2S Heater Resistance (Bank1 Sensor 2)
    P0055 HO2S Heater Resistance (Bank1 Sensor 2)
    P0056 HO2S Heater Ctrl Circ (bank2, Sensor2)
    P0057 HO2S Heater Ctrl Circ Lo (bank2, Sensor2)
    P0058 HO2S Heater Ctrl Circ Hi (bank2, Sensor2)
    P0059 HO2S Heater Resistance Bank2 Sensor 1
    P0060 HO2S Heater Resistance Bank2 Sensor 2
    P0061 HO2S Heater Resistance Bank2 Sensor 3
    P0062 HO2S Heater Ctrl Circ (bank2, Sensor 3)
    P0063 HO2S Heater Ctrl Circ Lo (bank2, Sensor 3)
    P0064 HO2S Heater Ctrl Circ Hi (bank2, Sensor 3)
    P0065 Air Assisted Injector Ctrl Range/Perf
    P0066 Air Assisted Injector Ctrl Circ/Circ Lo
    P0067 Air Assisted Injector Ctrl Circ Hi
    P0068 MAP/MAF-Throttle Pos Correlation
    P0069 MAP-Barometric Press Correlation
    P0070 Ambient Air Temp Sensor Circ
    P0071 Ambient Air Temp Sensor Range/Perf
    P0072 Ambient Air Temp Sensor Circ Lo Input
    P0073 Ambient Air Temp Sensor Circ Hi Input
    P0074 Ambient Air Temp Sensor Circ Interm
    P0075 Intake Valve Ctrl Circ (bank 1)
    P0076 Intake Valve Ctrl Circ Lo (bank 1)
    P0077 Intake Valve Ctrl Circ Hi (bank 1)
    P0078 Exhaust Valve Ctrl Circ (bank 1)
    P0079 Exhaust Valve Ctrl Circ Lo (bank 1)
    P0080 Exhaust Valve Ctrl Circ Hi (bank 1)
    P0081 Intake Valve Ctrl Circ (bank 2)
    P0082 Intake Valve Ctrl Circ Lo (bank 2)
    P0083 Intake Valve Ctrl Circ Hi (bank 2)
    P0084 Exhaust Valve Ctrl Circ (bank 2)
    P0085 Exhaust Valve Ctrl Circ Lo (bank 2)
    P0086 Exhaust Valve Ctrl Circ Hi (bank 2)
    P0087 Fuel Rail/Sys Pres-Too Lo
    P0088 Fuel Rail/Sys Pres-Too Hi
    P0089 Fuel Pres Reg Perf
    P0090 Fuel Pres Reg Ctrl Circ
    P0091 Fuel Pres Reg Ctrl Circ Lo
    P0092 Fuel Pres Reg Ctrl Circ Hi
    P0093 Fuel Sys Leak Detected-Large Leak
    P0094 Fuel Sys Leak Detected-Small Leak
    P0095 Intake Air Temp Sensor 2 Circ
    P0096 Intake Air Temp Sensor 2 Circ Range/Perf
    P0097 Intake Air Temp Sensor 2 Circ Low
    P0098 Intake Air Temp Sensor 2 Circ High
    P0099 Intake Air Temp Sensor 2 Circ Interm/Erratic
    P0100 Mass/Volume Air Flow Circ Error
    P0101 Mass/Volume Air Flow Circ Range/Perf
    P0102 Mass/Volume Air Flow Circ Lo Input
    P0103 Mass/Volume Air Flow Circ Hi Input
    P0104 Mass/Volume Air Flow Circ Interm
    P0105 MAP/Baro Pres Circ Error
    P0106 MAP/Baro Pres Circ Range/Perf
    P0107 MAP/Baro Pres Circ Lo Input
    P0108 MAP/Baro Pres Circ Hi Input
    P0109 MAP/Baro Pres Circ Interm
    P0110 Intake Air Temp Circ Error
    P0111 Intake Air Temp Circ Range/Perf
    P0112 Intake Air Temp Circ Lo Input
    P0113 Intake Air Temp Circ Hi Input
    P0114 Intake Air Temp Circ Interm
    P0115 Eng Coolant Temp Circ Error
    P0116 Eng Coolant Temp Circ Range/Perf
    P0117 Eng Coolant Temp Circ Lo Input
    P0118 Eng Coolant Temp Hi Input
    P0119 Eng Coolant Temp Interm
    P0120 Throttle Pos Sensor/Switch A Circ Error
    P0121 Throttle Pos Sensor/Switch A Circ Range/Perf
    P0122 Throttle Pos Sensor/Switch A Circ Lo Input
    P0123 Throttle Pos Sensor/Switch A Circ Hi Input
    P0124 Throttle Pos Sensor/Switch A Circ Interm
    P0125 Insuff Coolant Temp for Closed Loop Fuel Ctrl
    P0126 Insuff Coolant Temp Stable Operation
    P0127 Intake Air Temp Too Hi
    P0128 Coolant Temp below Thermostat
    P0129 Barometric Press Too Low
    P0130 Oxy Sensor Circ (bank1, Sensor 2)
    P0131 Oxy Sensor Circ Lo Voltage (bank1, Sensor 2)
    P0132 Oxy Sensor Circ Hi Voltage (bank1, Sensor 2)
    P0133 Oxy Sensor Circ Slow Response (bank1, Sensor 2)
    P0134 Oxy Sens Circ No Activity Detected (bank1 Sensor 2)
    P0135 Oxy Sensor Heater Circ (bank1, Sensor 2)
    P0136 Oxy Sensor Circ (bank1, Sensor 2)
    P0137 Oxy Sensor Circ Lo Voltage (bank1, Sensor 2)
    P0138 Oxy Sensor Circ Hi Voltage (bank1, Sensor 2)
    P0139 Oxy Sensor Circ Slow Response (bank1, Sensor 2)
    P0140 Oxy Sens Circ No Activity Detected (bank1Sensor 2)
    P0141 Oxy Sensor Heater Circ (bank1, Sensor2)
    P0142 Oxy Sensor Circ (bank1, Sensor 3)
    P0143 Oxy Sensor Circ Lo Voltage (bank1, Sensor 3)
    P0144 Oxy Sensor Circ Hi Voltage (bank1, Sensor 3)
    P0145 Oxy Sensor Circ Slow Response (bank1, Sensor 3)
    P0146 Oxy Sensor Circ No Activity Detected (bank1 Sens3)
    P0147 Oxy Sensor Heater Circ (bank1, Sensor 3)
    P0148 Fuel Delivery Error
    P0149 Fuel Timing Error
    P0150 Oxy Sensor Circ (bank2, Sensor 2)
    P0151 Oxy Sensor Circ Lo Voltage (bank2, Sensor 2)
    P0152 Oxy Sensor Circ Hi Voltage (bank2, Sensor 2)
    P0153 Oxy Sensor Circ Slow Response (bank2, Sensor 2)
    P0154 Oxy Sensor Circ No Activity Detected (bank2 Sensor 2)
    P0155 Heated Oxy Sensor Heater Circ (bank2, Sensor 2)
    P0156 Oxy Sensor Circ (bank2, Sensor2)
    P0157 Oxy Sensor Circ Lo Voltage (bank2, Sensor2)
    P0158 Oxy Sensor Circ Hi Voltage (bank2, Sensor2)
    P0159 Oxy Sensor Circ Slow Response (bank2, Sensor2)
    P0160 Oxy Sensor Circ No Activity Detected (bank2 Sensor 2)
    P0161 Heated Oxy Sensor Heater Circ (bank2, Sensor2)
    P0162 Oxy Sensor Circ (bank2, Sensor 3)
    P0163 Oxy Sensor Circ Lo Voltage (bank2, Sensor 3)
    P0164 Oxy Sensor Circ Hi Voltage (bank2, Sensor 3)
    P0165 Oxy Sensor Circ Slow Response (bank2, Sensor 3)
    P0166 Oxy Sensor Circ No Activity Detected (bank2 Sens3)
    P0167 Heated Oxy Sensor Heater Circ (bank2, Sensor 3)
    P0168 Eng Fuel Temp Hi
    P0169 Incorrect Fuel ComPos
    P0170 Fuel Trim Error (bank
    P0171 Sys too Lean (bank
    P0172 Sys too Rich (bank
    P0173 Fuel Trim Error (bank 2)
    P0174 Sys too Lean (bank 2)
    P0175 Sys too Rich (bank 2)
    P0176 Fuel ComPos Sensor Circ Error
    P0177 Fuel ComPos Sensor Circ Range/Perf
    P0178 Fuel ComPos Sensor Circ Lo Input
    P0179 Fuel ComPos Sensor Circ Hi Input
    P0180 Fuel Temp SensorA Circ Error
    P0181 Fuel Temp SensorA Circ Range/Perf
    P0182 Fuel Temp SensorA Circ Lo Input
    P0183 Fuel Temp SensorA Circ Hi Input
    P0184 Fuel Temp SensorA Circ Interm
    P0185 Fuel Temp SensorB Circ Error
    P0186 Fuel Temp SensorB Circ Range/Perf
    P0187 Fuel Temp SensorB Circ Lo Input
    P0188 Fuel Temp SensorB Circ Hi Input
    P0189 Fuel Temp SensorB Circ Interm
    P0190 Fuel Rail Pres Sensor Circ Error
    P0191 Fuel Rail Pres Sensor Circ Range/Perf
    P0192 Fuel Rail Pres Sensor Circ Lo Input
    P0193 Fuel Rail Pres Sensor Circ Hi Input
    P0194 Fuel Rail Pres Sensor Circ Interm
    P0195 Eng Oil Temp Sensor Error
    P0196 Eng Oil Temp Sensor Range/Perf
    P0197 Eng Oil Temp Sensor Circ Lo Input
    P0198 Eng Oil Temp Sensor Circ Hi Input
    P0199 Eng Oil Temp Sensor Interm
    P0200 Injector Circ Error
    P0201 Injector Circ Error-Cyl1
    P0202 Injector Circ Error-Cyl2
    P0203 Injector Circ Error-Cyl3
    P0204 Injector Circ Error-Cyl4
    P0205 Injector Circ Error-Cyl5
    P0206 Injector Circ Error-Cyl6
    P0207 Injector Circ Error-Cyl7
    P0208 Injector Circ Error-Cyl8
    P0209 Injector Circ Error-Cyl9
    P0210 Injector Circ Error-Cyl10
    P0211 Injector Circ Error-Cyl11
    P0212 Injector Circ Error-Cyl12
    P0213 Cold Start Injector 1 Error
    P0214 Cold Start Injector 2 Error
    P0215 Eng Shutoff Solenoid Error
    P0216 Inj Timing Ctrl Circ Error
    P0217 Eng Over temp Condition
    P0218 Tran Over temp Condition
    P0219 Throttle Sw B Circ Error/Eng Over speed Condition
    P0220 Throttle Pos Sensor/Switch B Circ Error
    P0221 Throttle Pos Sensor/Switch B Circ Range/Perf
    P0222 Throttle Pos Sensor/Switch B Circ Lo Input
    P0223 Throttle Pos Sensor/Switch B Circ Hi Input
    P0224 Throttle Pos Sensor/Switch B Circ Interm
    P0225 Throttle Pos Sensor/Switch C Circ Error
    P0226 Throttle Pos Sensor/Switch C Circ Range/Perf
    P0227 Throttle Pos Sensor/Switch C Circ Lo Input
    P0228 Throttle Pos Sensor/Switch C Circ Hi Input
    P0229 Throttle Pos Sensor/Switch C Circ Interm
    P0230 Fuel Pump Relay Dvr Fail
    P0231 Fuel Pump Relay Dvr Circ Fail On
    P0232 Fuel Pump Relay Dvr Circ Fail Off
    P0233 Fuel Pump Relay Dvr Interm
    P0234 Eng Over boost Condition
    P0235 Turbo Boost SensorA Circ Error
    P0236 Turbo Boost SensorA Circ Perf
    P0237 Turbo Boost SensorA Circ Lo Input
    P0238 Turbo Boost SensorA Circ Hi Input
    P0239 Turbo Boost SensorB Circ Error
    P0240 Turbo Boost SensorB Circ Perf
    P0241 Turbo Boost SensorB Circ Lo Input
    P0242 Turbo Boost SensorB Circ Hi Input
    P0243 Turbo Wastegate Solenoid A Error
    P0244 Turbo Wastegate Solenoid A Range/Perf
    P0245 Turbo Wastegate Solenoid A Lo
    P0246 Turbo Wastegate Solenoid A Hi
    P0247 Turbo Wastegate Solenoid A Error
    P0248 Turbo Wastegate Solenoid A Range/Perf
    P0249 Turbo Wastegate Solenoid A Lo
    P0250 Turbo Wastegate Solenoid A Hi
    P0251 Inj Pump Fuel Metering Ctrl A Error
    P0252 Inj Pump Fuel Metering Ctrl A Range/Perf
    P0253 Inj Pump Fuel Metering Ctrl A Lo
    P0254 Inj Pump Fuel Metering Ctrl A Hi
    P0255 Inj Pump Fuel Metering Ctrl A Interm
    P0256 Inj Pump Fuel Metering Ctrl A Error
    P0257 Inj Pump Fuel Metering Ctrl A Range/Perf
    P0258 Inj Pump Fuel Metering Ctrl A Lo
    P0259 Inj Pump Fuel Metering Ctrl A Hi
    P0260 Inj Pump Fuel Metering Ctrl A Interm
    P0261 Injector Circ Lo-Cyl1
    P0262 Injector Circ Hi-Cyl1
    P0263 Cyl1 Contribution/Balance Fault
    P0264 Injector Circ Lo-Cyl 2
    P0265 Injector Circ Hi-Cyl 2
    P0266 Cyl2 Contribution/Balance Fault
    P0267 Injector Circ Lo-Cyl 3
    P0268 Injector Circ Hi-Cyl 3
    P0269 Cyl3 Contribution/Balance Fault
    P0270 Injector Circ Lo-Cyl 4
    P0271 Injector Circ Hi-Cyl 4
    P0272 Cyl4 Contribution/Balance Fault
    P0273 Injector Circ Lo-Cyl 5
    P0274 Injector Circ Hi-Cyl 5
    P0275 Cyl5 Contribution/Balance Fault
    P0276 Injector Circ Lo-Cyl 6
    P0277 Injector Circ Hi-Cyl 6
    P0278 Cyl6 Contribution/Balance Fault
    P0279 Injector Circ Lo-Cyl 7
    P0280 Injector Circ Hi-Cyl 7
    P0281 Cyl7 Contribution/Balance Fault
    P0282 Injector Circ Lo-Cyl 8
    P0283 Injector Circ Hi-Cyl 8
    P0284 Cyl8 Contribution/Balance Fault
    P0285 Injector Circ Lo-Cyl 9
    P0286 Injector Circ Hi-Cyl 9
    P0287 Cyl9 Contribution/Balance Fault
    P0288 Injector Circ Lo-Cyl 10
    P0289 Injector Circ Hi-Cyl 10
    P0290 Cyl10 Contribution/Balance Fault
    P0291 Injector Circ Lo-Cy l11
    P0292 Injector Circ Hi-Cyl 11
    P0293 Cyl11 Contribution/Balance Fault
    P0294 Injector Circ Lo-Cyl 12
    P0295 Injector Circ Hi-Cyl 12
    P0296 Cyl12 Contribution/Balance Fault
    P0297 Vehicle Overspeed Condition
    P0298 Eng Oil Over temp Condition
    P0299 T/S Charger Underboost
    2004 SILVERADO 1500 5.3, 37X13.5 TOYO MT, 18X9 XD MONSTERS, 6K HIDS, CUSTOM TUNE, AFE CAI, 6" RCX, 3" BL, RCX KICKER BRACES, COGNITO PITMAN AND IDLER SUPPORT BRACKETS, COGNITO UCA, COGNITO LIMIT STRAPS, PROCOMP AAL, TRUETRAC, 4.88 GEARS
    Aug 2007
    Connecticut
    Re: Gm Diagnostic Trouble Codes
    P0300 Random/Multiple Cylinder Misfire Detected
    P0301 Fault Cylinder A-Misfire Detected (CYL1)
    P0302 Fault Cylinder B-Misfire Detected (CYL2)
    P0303 Fault Cylinder D-Misfire Detected (CYL3)
    P0304 Fault Cylinder E-Misfire Detected (CYL4)
    P0305 Fault Cylinder F-Misfire Detected (CYL5)
    P0306 Fault Cylinder G-Misfire Detected (CYL6)
    P0307 Fault Cylinder C-Misfire Detected (CYL7)
    P0308-Fault Cylinder H-Misfire Detected (CYL8)
    P0309 Fault Cylinder I-Misfire Detected (CYL9)
    P0310 Fault Cylinder J-Misfire Detected (CYL10)
    P0311 Fault Cylinder K-Misfire Detected (CYL11)
    P0312 Fault Cylinder L-Misfire Detected (CYL12)
    P0313 Misfire Detected with Lo Fuel
    P0314 1 Cylinder Misfire (Cylinder not specific)
    P0315 Crank Pos Sys Variation Not Learned
    P0316 Engine Misfire Detected on Startup (First 1000Revs)
    P0317 Rough Road Hardware Not Present
    P0318 Rough Road SensorA Signal Circ
    P0319 Rough Road SensorB
    P0320 Ign/Distributor Eng Speed Input Circ Error
    P0321 Ign/Distributor Eng Speed Input Circ Range/Perf
    P0322 Ign/Distributor Eng Speed Input Circ No Signal
    P0323 Ign/Distributor Eng Speed Input Circ Interm
    P0324 Knock Ctrl Sys Error
    P0325 Knock Sensor1 Circ Error (bank1/ Sensor 1)
    P0326 Knock Sensor1 Circ Range/Perf (bank1/ Sensor 1)
    P0327 Knock Sensor1 Circ Lo Input (bank1/ Sensor 1)
    P0328 Knock Sensor1 Circ Hi Input (bank1/ Sensor 1)
    P0329 Knock Sensor1 Circ Interm (bank1/ Sensor 1)
    P0330 Knock Sensor2 Circ Error (bank2/ Sensor 1))
    P0331 Knock Sensor2 Circ Range/Perf (bank2/ Sensor 1)
    P0332 Knock Sensor2 Circ Lo Input (bank2/ Sensor 1)
    P0333 Knock Sensor2 Circ Hi Input (bank2/ Sensor 1)
    P0334 Knock Sensor2 Circ Interm (bank2/ Sensor 1)
    P0335 Crank Pos SensorA Circ Error
    P0336 Crank Pos SensorA Circ Range/Perf
    P0337 Crank Pos SensorA Circ Lo Input
    P0338 Crank Pos SensorA Circ Hi Input
    P0339 Crank Pos SensorA Circ Interm
    P0340 Camshaft Pos Sensor Circ Error (bank1/Sensor 1)
    P0341 Camshaft Pos Sensor Circ Perf (bank1/ Sensor 1)
    P0342 Camshaft Pos Sensor Circ Lo Input (bank1/Sensor 1)
    P0343 Camshaft Pos Sensor Circ Hi Input (bank1/Sensor 1)
    P0344 Camshaft Pos Sensor Circ Interm (bank1/ Sensor 1)
    P0345 Camshaft Pos Sensor Circ Error (bank2)
    P0346 Camshaft Pos Sensor Circ Perf (bank2)
    P0347 Camshaft Pos Sensor Circ Lo Input (bank2)
    P0348 Camshaft Pos Sensor Circ Hi Input (bank2)
    P0349 Camshaft Pos Sensor Circ Interm (bank2)
    P0350 Ignition Coil Pri/Sec Circ Error
    P0351 Ignition Coil A Pri/Sec Circ Error
    P0352 Ignition Coil B Pri/Sec Circ Error
    P0353 Ignition Coil C Pri/Sec Circ Error
    P0354 Ignition Coil D Pri/Sec Circ Error
    P0355 Ignition Coil E Pri/Sec Circ Error
    P0356 Ignition Coil F Pri/Sec Circ Error
    P0357 Ignition Coil G Pri/Sec Circ Error
    P0358 Ignition Coil H Pri/Sec Circ Error
    P0359 Ignition Coil I Pri/Sec Circ Error
    P0360 Ignition Coil J Pri/Sec Circ (Glow Plug) Error
    P0361 Ignition Coil K Pri/Sec Circ (Glow Plug Indicator)Error
    P0362 Ignition Coil L Pri/Sec Circ Error
    P0363 Misfire Detected-Fueling Disabled
    P0364 Reserved
    P0365 Crank Pos SensorB Circ Error (bank
    P0366 Crank Pos SensorB Circ Range/Perf (bank
    P0367 Crank Pos SensorB Circ Lo Input (bank
    P0368 Crank Pos SensorB Circ Hi Input (bank
    P0369 Crank Pos SensorB Circ Interm (bank
    P0370 Timing Ref Hi Res Signal A Error
    P0371 Timing Ref Hi Res Signal A Too Many Pulses
    P0372 Timing Ref Hi Res Signal A Too Few Pulses
    P0373 Timing Ref Hi Res Signal A Interm/Erratic Pulses
    P0374 Timing Ref Hi Res Signal A No Pulses
    P0375 Timing Ref Hi Res Signal B Error
    P0376 Timing Ref Hi Res Signal B Too Many Pulses
    P0377 Timing Ref Hi Res Signal B Too Few Pulses
    P0378 Timing Ref Hi Res Signal B Interm/Erratic Pulses
    P0379 Timing Ref Hi Res Signal B No Pulses
    P0380- Glow Plug Circ Error Circ A
    P0381 Glow Plug Indicator Circ Error
    P0382 Glow Plug Circ Error Circ B
    P0383 P0384 Reserved by document
    P0385 Crank Pos SensorB Circ Error
    P0386 Crank Pos SensorB Circ Range/Perf
    P0387 Crank Pos SensorB Circ Lo Input
    P0388 Crank Pos SensorB Circ Hi Input
    P0389 Crank Pos SensorB Circ Interm
    P0390 Crank Pos SensorB Circ Error (bank2)
    P0391 Crank Pos SensorB Circ Range/Perf (bank2)
    P0392 Crank Pos SensorB Circ Lo Input (bank2)
    P0393 Crank Pos SensorB Circ Hi Input (bank2)
    P0394 Crank Pos SensorB Circ Interm (bank2)
    P0400 Exhaust Gas Recirculation Flow Error
    P0401 Exhaust Gas Recirculation Flow Insuff Detected
    P0402 Exhaust Gas Recirculation Flow ExcessiveDetected
    P0403 Exhaust Gas Recirculation Circ Error
    P0404 Exhaust Gas Recirculation Circ Range/Perf
    P0405 Exhaust Gas Recirculation SensorA Circ Lo
    P0406 Exhaust Gas Recirculation SensorA Circ Hi
    P0407 Exhaust Gas Recirculation SensorB Circ Lo
    P0408 Exhaust Gas Recirculation SensorB Circ Hi
    P0409 Exhaust Gas Recirculation SensorA Circ
    P0410 Sec Air Inj Sys Error
    P0411 Sec Air Inj Sys Incorrect Flow Detected
    P0412 Sec Air Inj Sys Switching Valve A Circ Error
    P0413 Sec Air Inj Sys Switching Valve A Circ Open
    P0414 Sec Air Inj Sys Switching Valve A Circ Shorted
    P0415 Sec Air Inj Sys Switching Valve B Circ Error
    P0416 Sec Air Inj Sys Switching Valve B Circ Open
    P0417 Sec Air Inj Sys Switching Valve B Circ Shorted
    P0418 Sec Air Inj Sys Relay A Circ Error
    P0419 Sec Air Inj Sys Relay B Circ Error
    P0420 Catalyst Sys Efficiency below Threshold (bank 1)
    P0421 Warm Up Catalyst Efficiency below Thresh (bank 1)
    P0422 Main Catalyst Efficiency below Threshold (bank 1)
    P0423 Heated Catalyst Efficiency below Threshold (bank 1)
    P0424 Heated Catalyst Temp below Threshold (bank 1)
    P0425 Catalyst Temp Sensor (bank 1)
    P0426 Catalyst Temp Sensor Range/Perf (bank 1)
    P0427 Catalyst Temp Sensor Lo Input (bank 1)
    P0428 Catalyst Temp Sensor Hi Input (bank 1)
    P0429 Catalyst Heater Ctrl Circ (bank 1)
    P0430 Catalyst Sys Efficiency below Threshold (bank2)
    P0431 Warm Up Catalyst Efficiency below Thresh(bank2)
    P0432 Main Catalyst Efficiency below Threshold (bank2)
    P0433 Heated Catalyst Efficiency below Threshold (bank2)
    P0434 Heated Catalyst Temp below Threshold (bank2)
    P0435 Catalyst Temp Sensor (bank2)
    P0436 Catalyst Temp Sensor Range/Perf (bank2)
    P0437 Catalyst Temp Sensor Lo Input (bank2)
    P0438 Catalyst Temp Sensor Hi Input (bank2)
    P0439 Catalyst Heater Ctrl Circ (bank2)
    P0440 Evap Emission Ctrl Sys Error
    P0441 Evap Emission Ctrl Sys Incorrect Purge Flow
    P0442 Evap Emission Ctrl Sys Leak Detected (smallleak)
    P0443 Evap Emission Ctrl Sys Purge Ctrl Valve CircError
    P0444 Evap Emission Ctrl Sys Purge Ctrl Valve CircOpen
    P0445 Evap Emission Ctrl Sys Purge Ctrl Valve CircShorted
    P0446 Evap Emission Ctrl Sys Vent Ctrl Circ Error
    P0447 Evap Emission Ctrl Sys Vent Ctrl Circ Open
    P0448 Evap Emission Ctrl Sys Vent Ctrl Circ Shorted
    P0449 Evap Emission Ctrl Sys Vent Valve/Solenoid CircError
    P0450 Evap Emission Ctrl Sys Pres Sensor Error
    P0451 Evap Emission Ctrl Sys Pres Sensor Range/Perf
    P0452 Evap Emission Ctrl Sys Pres Sensor Lo Input
    P0453 Evap Emission Ctrl Sys Pres Sensor Hi Input
    P0454 Evap Emission Ctrl Sys Pres Sensor Interm
    P0455 Evap Emission Ctrl Sys Gross Leak Detected
    P0456-Evap Emission Ctrl Sys Very Small LeakDetected)
    P0457 Evap Emission Ctrl Sys Leak (fuel cap loose/off)
    P0458 Evaporative Emission Sys Purge Ctrl Valve Circ Low
    P0459 Evaporative Emission Sys Purge Ctrl Valve CircHigh
    P0460 Fuel Tank Level Indicator Circ Error
    P0461 Fuel Level Sensor Circ Range/Perf
    P0462 Fuel Level Sensor Circ Lo Input
    P0463 Fuel Level Sensor Circ Hi Input
    P0464 Fuel Level Sensor Circ Interm
    P0465 EVAP Purge Flow Sensor Circ
    P0466 EVAP Purge Flow Sensor Circ Range/Perf
    P0467 EVAP Purge Flow Sensor Circ Lo Input
    P0468 EVAP Purge Flow Sensor Circ Hi Input
    P0469 EVAP Purge Flow Sensor Circ Interm
    P0470 Exhaust Back Pres Sensor Circ Error
    P0471 Exhaust Back Pres Sensor Circ Perf
    P0472 Exhaust Back Pres Sensor Circ Lo Input
    P0473 Exhaust Back Pres Sensor Circ Hi Input
    P0474 Exhaust Back Pres Sensor Interm
    P0475 Exhaust Pres Ctrl Valve Error
    P0476 Exhaust Pres Ctrl Valve Range/Perf
    P0477 Exhaust Pres Ctrl Valve Lo Output
    P0478 Exhaust Pres Ctrl Valve Hi Input
    P0479 Exhaust Pres Ctrl Valve Interm
    P0480 Cooling Fan 1 Ctrl Circ Error
    P0481 Cooling Fan 2 Ctrl Circ Error
    P0482 Cooling Fan 3 Ctrl Circ Error
    P0483 Cooling Fan Rationality Check Error
    P0484 Cooling Fan Circ over Current
    P0485 Cooling Fan Power/Ground Circ Error
    P0486 EGR SensorB Circ
    P0487 EGR Throttle Pos Ctrl Circ
    P0488 EGR Throttle Pos Ctrl Range/Perf
    P0489 Exhaust Gas Recirculation Ctrl Circ Low
    P0490 Exhaust Gas Recirculation Ctrl Circ High
    P0491 Sec Air Inj Sys (bank1)
    P0492 Sec Air Inj Sys (bank2)
    P0493 Fan Overspeed
    P0494 Fan Speed Low
    P0495 Fan Speed High
    P0496 Evaporative Emission Sys High Purge Flow
    P0497 Evaporative Emission Sys Low Purge Flow
    P0500 Vehicle Speed Sensor (VSS) Error
    P0501 Vehicle Speed Sensor Range/Perf
    P0502 Vehicle Speed Sensor Lo Input
    P0503 Vehicle Speed Sensor Noisy
    P0504 Brake Switch A/B Correlation
    P0505 Idle Ctrl Sys Error
    P0506 Idle Ctrl Sys RPM Lower Than Expected
    P0507 Idle Ctrl Sys RPM Higher Than Expected
    P0508 Idle Ctrl Sys Circ Lo
    P0509 Idle Ctrl Sys Circ Hi
    P0510 Closed Throttle Pos Switch Error
    P0511 Idle Air Ctrl Circ
    P0512 Starter Request Circ
    P0513 Incorrect Immobilizer Key
    P0514 Battery Temp Sensor Circ Range/Perf
    P0515 Battery Temp Sensor Circ
    P0516 Battery Temp Sensor Circ Lo
    P0517 Battery Temp Sensor Circ Hi
    P0518 Idle Air Ctrl Circ Interm
    P0519 Idle Air Ctrl Sys Perf
    P0520 Eng Oil Pres Sensor/Switch Circ Error
    P0521 Eng Oil Pres Sensor/Switch Circ Range/Perf
    P0522 Eng Oil Pres Sensor/Switch Circ Lo Voltage
    P0523 Eng Oil Pres Sensor/Switch Circ Hi Voltage
    P0524 Eng Oil Pres Too Lo
    P0525 Cruise Ctrl Servo Ctrl Circ Range/Perf
    P0526 Fan Speed Sensor Circ
    P0527 Fan Speed Sensor Circ Range/Perf
    P0528 Fan Speed Sensor Circ No Signal
    P0529 Fan Speed Sensor Circ Interm
    P0530 A/C Refrigerant Pres Sensor Circ Error
    P0531 A/C Refrigerant Pres Sensor Circ Range/Perf
    P0532 A/C Refrigerant Pres Sensor Circ Lo Input
    P0533 A/C Refrigerant Pres Sensor Circ Hi Input
    P0534 Air Conditioner Refrigerant Charge Loss
    P0535 A/C Evaporator Temp Sensor Circ
    P0536 A/C Evaporator Temp Sensor Circ Range/Perf
    P0537 A/C Evaporator Temp Sensor Circ Low
    P0538 A/C Evaporator Temp Sensor Circ High
    P0539 A/C Evaporator Temp Sensor Circ Interm
    P0540 Manifold Intake Air Heater Circ
    P0541 Manifold Intake Air Heater Circ Lo
    P0542 Manifold Intake Air Heater Circ Hi
    P0543 Intake Air Heater A Circ Open
    P0544 EGT Sensor Circ bank1
    P0545 EGT Sensor Circ Lo bank1
    P0546 EGT Sensor Circ Hi bank1
    P0547 EGT Sensor Circ bank2
    P0548 EGT Sensor Circ Lo bank2
    P0549 EGT Sensor Circ Hi bank2
    P0550 Power Steering Pres Sensor Circ Error
    P0551 Power Steering Pres Sensor Circ Range/Perf
    P0552 Power Steering Pres Sensor Circ Lo Input
    P0553 Power Steering Pres Sensor Circ Hi Input
    P0554 Power Steering Pres Sensor Circ Interm
    P0555 Brake Booster Press Sensor Circ
    P0556 Brake Booster Press Sensor Circ Range/Perf
    P0557 Brake Booster Press Sensor Circ Low Input
    P0558 Brake Booster Press Sensor Circ High Input
    P0559 Brake Booster Press Sensor Circ Interm
    P0560 Sys Voltage Error
    P0561 Sys Voltage Unstable
    P0562 Sys Voltage Lo
    P0563 Sys Voltage Hi
    P0564 Cruise Ctrl Multi-Func Input Signal
    P0565 Cruise Ctrl ON Signal Error
    P0566 Cruise Ctrl OFF Signal Error
    P0567 Cruise Ctrl RESUME Signal Error
    P0568 Cruise Ctrl SET Signal Error
    P0569 Cruise Ctrl COAST Signal Error
    P0570 Cruise Ctrl ACCEL Signal Error
    P0571 Cruise Ctrl/Brake Switch A Circ Fail
    P0572 Cruise Ctrl/Brake Switch A Circ Lo
    P0573 Cruise Ctrl/Brake Switch A Circ Hi
    P0574 Cruise Ctrl Sys Vehicle Speed Too Hi
    P0575 Cruise Ctrl Input Circ
    P0576 Cruise Ctrl Input Circ Lo
    P0577 Cruise Ctrl Input Circ Hi
    P0578 Cruise Ctrl Multi-Func Input A Circ Stuck
    P0579 Cruise Ctrl Multi-Func Input A Circ Range/Perf
    P0580 Cruise Ctrl Multi-Func Input A Circ Low
    P0581 Cruise Ctrl Multi-Func Input A Circ High
    P0582 Cruise Ctrl Vacuum Ctrl Circ/Open
    P0583 Cruise Ctrl Vacuum Ctrl Circ Low
    P0584 Cruise Ctrl Vacuum Ctrl Circ High
    P0585 Cruise Ctrl Multi-Func Input A/B Correlation
    P0586 Cruise Ctrl Vent Ctrl Circ/Open
    P0587 Cruise Ctrl Vent Ctrl Circ Low
    P0588 Cruise Ctrl Vent Ctrl Circ High
    P0589 Cruise Ctrl Multi-Func Input B Circ
    P0590 Cruise Ctrl Multi-Func Input B Circ Stuck
    P0591 Cruise Ctrl Multi-Func Input B Circ Range/Perf
    P0592 Cruise Ctrl Multi-Func Input B Circ Low
    P0593 Cruise Ctrl Multi-Func Input B Circ High
    P0594 Cruise Ctrl Servo Ctrl Circ/Open
    P0595 Cruise Ctrl Servo Ctrl Circ Low
    P0596 Cruise Ctrl Servo Ctrl Circ High
    P0597 Thermostat Heater Ctrl Circ/Open
    P0598 Thermostat Heater Ctrl Circ Low
    P0599 Thermostat Heater Ctrl Circ High
    P0600 Serial Comms Link Error
    P0601 Internal Ctrl Mod Memory Check Sum Error
    P0602 Ctrl Mod Programming Error
    P0603 Internal Ctrl Mod KAM Error
    P0604 Internal Ctrl Mod RAM Error
    P0605 Internal Ctrl Mod ROM Error
    P0606 PCM Processor Fault
    P0607 Powertrain Ctrl Mod Perf
    P0608 Powertrain Ctrl Mod VSS Output A Error
    P0609 Powertrain Ctrl Mod VSS Output B Error
    P0610 Powertrain Ctrl Mod Vehicle Options Error
    P0611 Fuel Injector Ctrl Mod Perf
    P0612 Fuel Injector Ctrl Mod Ctrl Circ
    P0613 TCM Processor
    P0614 ECM / TCM Incompatible
    P0615 Starter Relay Circ
    P0616 Starter Relay Circ Lo
    P0617 Starter Relay Circ Hi
    P0618 Alternative Fuel Ctrl Mod KAM Error
    P0619 Alternative Fuel Ctrl Mod RAM/ROM Error
    P0620 Generator Ctrl Circ Error
    P0621 Generator Lamp L Ctrl Circ Error
    P0622 Generator Field F Ctrl Circ Error
    P0623 Generator Lamp Ctrl Circ Error
    P0624 Fuel Cap Lamp Ctrl Circ Error
    P0625 Generator Field/F Terminal Circ Low
    P0626 Generator Field/F Terminal Circ High
    P0627 Fuel Pump A Ctrl Circ /Open
    P0628 Fuel Pump A Ctrl Circ Low
    P0629 Fuel Pump A Ctrl Circ High
    P0630 VIN Not Programmed/Mismatch-ECM/PCM
    P0631 VIN Not Programmed/Mismatch-TCM
    P0632 Odometer Not Programmed-ECM/PCM
    P0633 Immobilizer Key Not Programmed-ECM/PCM
    P0634 PCM/ECM/TCM Internal Temp Too High
    P0635 Power Steering Ctrl Circ
    P0636 Power Steering Ctrl Circ Lo
    P0637 Power Steering Ctrl Circ Hi
    P0638 Throttle Actuator Ctrl Range/Perf bank1
    P0639 Throttle Actuator Ctrl Range/Perf bank2
    P0640 Manifold Intake Air Heater Ctrl Circ
    P0641 Sensor Ref Voltage A Circ/Open
    P0642 Sensor Ref Voltage A Circ Low
    P0643 Sensor Ref Voltage A Circ High
    P0644 Driver Display Serial Comm Circ
    P0645 A/C Clutch Relay Ctrl Circ
    P0646 A/C Clutch Relay Ctrl Circ Lo
    P0647 A/C Clutch Relay Ctrl Circ Hi
    P0648 Immobilizer Lamp Ctrl Circ
    P0649 Cruise Ctrl Lamp Ctrl Circ
    P0650 Error Indicator Lamp (MIL) Ctrl Circ Error
    P0651 Sensor Ref Voltage B Circ/Open
    P0652 Sensor Ref Voltage B Circ Low
    P0653 Sensor Ref Voltage B Circ High
    P0654 Eng RPM Output Circ Error
    P0655 Eng Hot Lamp Output Ctrl Circ MalFunc
    P0656 Fuel Level Output Circ Error
    P0657 Actuator Supply Voltage A Circ/Open
    P0658 Actuator Supply Voltage A Circ Low
    P0659 Actuator Supply Voltage A Circ High
    P0660 Intake Manif Tuning Valve Ctrl Circ bank1
    P0661 Intake Manif Tuning Valve Ctrl Circ Lo bank1
    P0662 Intake Manif Tuning Valve Ctrl Circ Hi bank1
    P0663 Intake Manif Tuning Valve Ctrl Circ bank2
    P0664 Intake Manif Tuning Valve Ctrl Circ Lo bank2
    P0665 Intake Manif Tuning Valve Ctrl Circ Hi bank2
    P0666 Cruise 'On Signal Error
    P0667 Cruise 'Resume' Signal Error
    P0668 Cruise Set' Signal Error
    P0669 Cruise Coast' Signal Error
    P0670 Glow plug Ctrl Circ Error
    P0671 Glow plug #1 Circ failure
    P0672 Glow plug #2 Circ failure
    P0673 Glow plug #3 Circ failure
    P0674 Glow plug #4 Circ failure
    P0675 Glow plug #5 Circ failure
    P0676 Glow plug #6 Circ failure
    P0677 Glow plug #7 Circ failure
    P0678 Glow plug #8 Circ failure
    P0679 Reserve for future Glow plug #9
    P0680 Reserve for future Glow plug #10
    P0681 Reserve for future Glow plug #11
    P0682 Reserve for future Glow plug #12
    P0683 Glow Plug Ctrl Mod to PCM Comm Circ
    P0684 Glow Plug Ctrl Mod to PCM Comm Circ Range/Perf
    P0685 ECM/PCM Power Relay Ctrl Circ /Open
    P0686 ECM/PCM Power Relay Ctrl Circ Low
    P0687 ECM/PCM Power Relay Ctrl Circ High
    P0688 ECM/PCM Power Relay Sense Circ /Open
    P0689 ECM/PCM Power Relay Sense Circ Low
    P0690 ECM/PCM Power Relay Sense Circ High
    P0691 Fan 1 Ctrl Circ Low
    P0692 Fan 1 Ctrl Circ High
    P0693 Fan 2 Ctrl Circ Low
    P0694 Fan 2 Ctrl Circ High
    P0695 Fan 3 Ctrl Circ Low
    P0696 Fan 3 Ctrl Circ High
    P0697 Sensor Ref Voltage C Circ/Open
    P0698 Sensor Ref Voltage C Circ Low
    P0699 Sensor Ref Voltage C Circ High
    Aug 2007
    Connecticut
    P0700 Tran Ctrl Sys Error
    P0701 Tran Ctrl Sys Range/Perf
    P0702 Tran Ctrl Sys Electrical
    P0703 Brake Switch B Circ Error
    P0704 Clutch Pedal Pos Switch Input Circ Error
    P0705- Tran Range Sensor Circ Error
    P0706 Tran Range Sensor Circ Range/Perf
    P0707 Tran Range Sensor Circ Lo Input
    P0708 Tran Range Sensor Circ Hi Input
    P0709 Tran Range Sensor Circ Interm
    P0710- Tran Fluid Temp Sensor Circ Error
    P0711 Tran Fluid Temp Sensor Circ Range/Perf
    P0712 Tran Fluid Temp Sensor CKT Lo Input
    P0713 Tran Fluid Temp Sensor CKT Hi Input
    P0714 Tran Fluid Temp Sensor Circ Interm
    P0715 Input/Turbine Speed Sensor Circ Error
    P0716 Input/Turbine Speed Sensor Circ Range/Perf
    P0717 Input/Turbine Speed Sensor Circ No Signal
    P0718 Input/Turbine Speed Sensor Circ Interm
    P0719 Torq Conv/Brake Switch B Circ Lo
    P0720 Output Speed Sensor Circ Error
    P0721 Output Speed Sensor Range/Perf
    P0722 Output Speed Sensor No Signal
    P0723 Output Speed Sensor Interm
    P0724 Torq Conv/Brake Switch B Circ Hi
    P0725 Eng Speed input Circ Error
    P0726 Eng Speed Input Circ Range/Perf
    P0727 Eng Speed Input Circ No Signal
    P0728 Eng Speed Input Circ Interm
    P0729 Gear 6 Incorrect Ratio
    P0730 Incorrect Gear Ratio
    P0731 Gear One Ratio Error
    P0732 Gear Two Ratio Error
    P0733 Gear Three Ratio Error
    P0734 Gear Four Ratio Error
    P0735 Gear Five Ratio Error
    P0736 Reverse Gear Ratio Error
    P0737 TCM Eng Speed Output Circ
    P0738 TCM Eng Speed Output Circ Lo
    P0739 TCM Eng Speed Output Circ Hi
    P0740 Torq Conv Clutch Circ MalFunc
    P0741 Torq Conv Clutch Circ Perf/Stuck Off
    P0742 Torq Conv Clutch Circ Stuck On
    P0743-Torq Conv Clutch Sys Electrical Failure
    P0744 Torq Conv Clutch Circ Interm
    P0745 Pres Ctrl Solenoid Error
    P0746 Pres Ctrl Solenoid Perf/Stuck Off
    P0747 Pres Ctrl Solenoid Stuck On
    P0748 Pres Ctrl Solenoid Electrical
    P0749 Pres Ctrl Solenoid Interm
    P0750 Shift Solenoid A Error
    P0751 Shift Solenoid A Perf/Stuck Off
    P0752 Shift Solenoid A Stuck On
    P0753 Shift Solenoid A Electrical
    P0754 Shift Solenoid A Interm
    P0755 Shift Solenoid B Error
    P0756 Shift Solenoid B Perf/Stuck Off
    P0757 Shift Solenoid B Stuck On
    P0758 Shift Solenoid B Electrical
    P0759 Shift Solenoid B Interm
    P0760 Shift Solenoid C Error
    P0761 Shift Solenoid C Perf/Stuck Off
    P0762 Shift Solenoid C Stuck On
    P0763 Shift Solenoid C Electrical
    P0764 Shift Solenoid C Interm
    P0765 Shift Solenoid D Error
    P0766 Shift Solenoid D Perf/Stuck Off
    P0767 Shift Solenoid D Stuck On
    P0768 Shift Solenoid D Electrical
    P0769 Shift Solenoid D Interm
    P0770 Shift Solenoid E Error
    P0771 Shift Solenoid E Perf/Stuck Off
    P0772 Shift Solenoid E Stuck On
    P0773 Shift Solenoid E Electrical
    P0774 Shift Solenoid E Interm
    P0775 Pres Ctrl Solenoid B
    P0776 Pres Ctrl Solenoid B Perf/Stuck Off
    P0777 Pres Ctrl Solenoid B Stuck On
    P0778 Pres Ctrl Solenoid B Electrical
    P0779 Pres Ctrl Solenoid B Interm
    P0780 Shift Error
    P0781 1-2 Shift Error
    P0782 2-3 Shift Error
    P0783 3-4 Shift Error
    P0784 4-5 Shift Error
    P0785 Shift/Timing Solenoid Error
    P0786 Shift/Timing Solenoid Range/Perf
    P0787 Shift/Timing Solenoid Lo
    P0788 Shift/Timing Solenoid Hi
    P0789 Shift/Timing Solenoid Interm
    P0790 Normal/Perf Switch Circ Error
    P0791 Intermediate Shaft Speed Sensor Circ
    P0792 Intermediate Shaft Speed Sensor Circ Range/Perf
    P0793 Intermediate Shaft Speed Sensor Circ No Signal
    P0794 Intermediate Shaft Speed Sensor Circ Interm
    P0795 Pres Ctrl Solenoid C
    P0796 Pres Ctrl Solenoid C Perf/Stuck Off
    P0797 Pres Ctrl Solenoid C Stuck On
    P0798 Pres Ctrl Solenoid C Electrical
    P0799 Pres Ctrl Solenoid C Interm
    P0800 Transfer Case Ctrl Sys (MIL Request)
    P0801 Reverse Inhibit Ctrl Circ Error
    P0802 Trans Ctrl Sys MIL Request Circ/Open
    P0803 1-4 Up shift (Skip Shift) Solenoid Ctrl Circ Error
    P0804 1-4 Up shift (Skip Shift) Lamp Ctrl Circ Error
    P0805 Clutch Pos Sensor Circ
    P0806 Clutch Pos Sensor Circ Range/Perf
    P0807 Clutch Pos Sensor Circ Lo
    P0808 Clutch Pos Sensor Circ Hi
    P0809 Clutch Pos Sensor Circ Interm
    P0810 Clutch Pos Ctrl Error
    P0811 Excessive Clutch Slippage
    P0812 Reverse Input Circ
    P0813 Reverse Output Circ
    P0814 Tran Range Display Circ
    P0815 Up Shift Switch Circ
    P0816 Down shift Switch Circ
    P0817 Starter Disable Circ
    P0818 Driveline Disconnect Switch Input Circ
    P0819 Up and Down Shift Switch to Trans Range Correlation
    P0820 Gear Lever X-Y Pos Sensor Circ
    P0821 Gear Lever X Pos Sensor Circ
    P0822 Gear Lever Y Pos Sensor Circ
    P0823 Gear Lever X Pos Sensor Circ Interm
    P0824 Gear Lever Y Pos Sensor Circ Interm
    P0825 Gear Lever Push/Pull Switch Circ (Shift Anticipate)
    P0826 Up and Down Shift Switch Circ
    P0827 Up and Down Shift Switch Circ Low
    P0828 Up and Down Shift Switch Circ High
    P0829 5-6 Shift
    P0830 Clutch Pedal Switch A Circ
    P0831 Clutch Pedal Switch A Circ Lo
    P0832 Clutch Pedal Switch A Circ Hi
    P0833 Clutch Pedal Switch B Circ
    P0834 Clutch Pedal Switch B Circ Lo
    P0835 Clutch Pedal Switch B Circ Hi
    P0836 4WD Switch Circ
    P0837 4WD Switch Circ Range/Perf
    P0838 4WD Switch Circ Lo
    P0839 4WD Switch Circ Hi
    P0840 Tran Fluid Pres Sensor/Switch A Circ
    P0841 Tran Fluid Pres Sensor/Switch A Circ Range/Perf
    P0842 Tran Fluid Pres Sensor/Switch A Circ Lo
    P0843 Tran Fluid Pres Sensor/Switch A Circ Hi
    P0844 Tran Fluid Pres Sensor/Switch A Circ Interm
    P0845 Tran Fluid Pres Sensor/Switch B Circ
    P0846 Tran Fluid Pres Sensor/Switch B Circ Range/Perf
    P0847 Tran Fluid Pres Sensor/Switch B Circ Lo
    P0848 Tran Fluid Pres Sensor/Switch B Circ Hi
    P0849 Tran Fluid Pres Sensor/Switch B Circ Interm
    P0850 Park/Neutral Switch Input Circ
    P0851 Park/Neutral Switch Input Circ Low
    P0852 Park/Neutral Switch Input Circ High
    P0853 Drive Switch Input Circ
    P0854 Drive Switch Input Circ Low
    P0855 Drive Switch Input Circ High
    P0856 Traction Ctrl Input Signal
    P0857 Traction Ctrl Input Signal Range/Perf
    P0858 Traction Ctrl Input Signal Low
    P0859 Traction Ctrl Input Signal High
    P0860 Gear Shift Mod Comm Circ
    P0861 Gear Shift Mod Comm Circ Low
    P0862 Gear Shift Mod Comm Circ High
    P0863 TCM Comm Circ
    P0864 TCM Comm Circ Range/Perf
    P0865 TCM Comm Circ Low
    P0866 TCM Comm Circ High
    P0867 Trans Fluid Press
    P0868 Trans Fluid Press Low
    P0869 Trans Fluid Press High
    P0870 Trans Fluid Press Sensor/Switch C Circ
    P0871 Trans Fluid Press Sensor/Switch C Circ Range/Perf
    P0872 Trans Fluid Press Sensor/Switch C Circ Low
    P0873 Trans Fluid Press Sensor/Switch C Circ High
    P0874 Trans Fluid Press Sensor/Switch C Circ Interm
    P0875 Trans Fluid Press Sensor/Switch D Circ
    P0876 Trans Fluid Press Sensor/Switch D Circ Range/Perf
    P0877 Trans Fluid Press Sensor/Switch D Circ Low
    P0878 Trans Fluid Press Sensor/Switch D Circ High
    P0879 Trans Fluid Press Sensor/Switch D Circ Interm
    P0880 TCM Power Input Signal
    P0881 TCM Power Input Signal Range/Perf
    P0882 TCM Power Input Signal Low
    P0883 TCM Power Input Signal High
    P0884 TCM Power Input Signal Interm
    P0885 TCM Power Relay Ctrl Circ/Open
    P0886 TCM Power Relay Ctrl Circ Low
    P0887 TCM Power Relay Ctrl Circ High
    P0888 TCM Power Relay Sense Circ
    P0889 TCM Power Relay Sense Circ Range/Perf
    P0890 TCM Power Relay Sense Circ Low
    P0891 TCM Power Relay Sense Circ High
    P0892 TCM Power Relay Sense Circ Interm
    P0893 Multiple Gears Engaged
    P0894 Trans Component Slipping
    P0895 Shift Time Too Short
    P0896 Shift Time Too Long
    P0897 Trans Fluid Deteriorated
    P0898 Trans Ctrl Sys MIL Request Circ Low
    Aug 2007
    Connecticut
    P0900 Clutch Actuator Circ/Open
    P0901 Clutch Actuator Circ Range/Perf
    P0902 Clutch Actuator Circ Low
    P0903 Clutch Actuator Circ High
    P0904 Gate Select Pos Circ
    P0905 Gate Select Pos Circ Range/Perf
    P0906 Gate Select Pos Circ Low
    P0907 Gate Select Pos Circ High
    P0908 Gate Select Pos Circ Interm
    P0909 Gate Select Ctrl Error
    P0910 Gate Select Actuator Circ/Open
    P0911 Gate Select Actuator Circ Range/Perf
    P0912 Gate Select Actuator Circ Low
    P0913 Gate Select Actuator Circ High
    P0914 Gear Shift Pos Circ
    P0915 Gear Shift Pos Circ Range/Perf
    P0916 Gear Shift Pos Circ Low
    P0917 Gear Shift Pos Circ High
    P0918 Gear Shift Pos Circ Interm
    P0919 Gear Shift Pos Ctrl Error
    P0920 Gear Shift Forward Actuator Circ/Open
    P0921 Gear Shift Forward Actuator Circ Range/Perf
    P0922 Gear Shift Forward Actuator Circ Low
    P0923 Gear Shift Forward Actuator Circ High
    P0924 Gear Shift Reverse Actuator Circ/Open
    P0925 Gear Shift Reverse Actuator Circ Range/Perf
    P0926 Gear Shift Reverse Actuator Circ Low
    P0927 Gear Shift Reverse Actuator Circ High
    P0928 Gear Shift Lock Solenoid Ctrl Circ/Open
    P0929 Gear Shift Lock Solenoid Ctrl Circ Range/Perf
    P0930 Gear Shift Lock Solenoid Ctrl Circ Low
    P0931 Gear Shift Lock Solenoid Ctrl Circ High
    P0932 Hydraulic Press Sensor Circ
    P0933 Hydraulic Press Sensor Range/Perf
    P0934 Hydraulic Press Sensor Circ Low
    P0935 Hydraulic Press Sensor Circ High
    P0936 Hydraulic Press Sensor Circ Interm
    P0937 Hydraulic Oil Temp Sensor Circ
    P0938 Hydraulic Oil Temp Sensor Range/Perf
    P0939 Hydraulic Oil Temp Sensor Circ Low
    P0940 Hydraulic Oil Temp Sensor Circ High
    P0941 Hydraulic Oil Temp Sensor Circ Interm
    P0942 Hydraulic Press Unit
    P0943 Hydraulic Press Unit Cycling Period Too Short
    P0944 Hydraulic Press Unit Loss of Press
    P0945 Hydraulic Pump Relay Circ/Open
    P0946 Hydraulic Pump Relay Circ Range/Perf
    P0947 Hydraulic Pump Relay Circ Low
    P0948 Hydraulic Pump Relay Circ High
    P0949 Auto Shift Manual Adaptive Learning Not Complete
    P0950 Auto Shift Manual Ctrl Circ
    P0951 Auto Shift Manual Ctrl Circ Range/Perf
    P0952 Auto Shift Manual Ctrl Circ Low
    P0953 Auto Shift Manual Ctrl Circ High
    P0954 Auto Shift Manual Ctrl Circ Interm
    P0955 Auto Shift Manual Mode Circ
    P0956 Auto Shift Manual Mode Circ Range/Perf
    P0957 Auto Shift Manual Mode Circ Low
    P0958 Auto Shift Manual Mode Circ High
    P0959 Auto Shift Manual Mode Circ Interm
    P0960 Press Ctrl Solenoid A Ctrl Circ/Open
    P0961 Press Ctrl Solenoid A Ctrl Circ Range/Perf
    P0962 Press Ctrl Solenoid A Ctrl Circ Low
    P0963 Press Ctrl Solenoid A Ctrl Circ High
    P0964 Press Ctrl Solenoid B Ctrl Circ/Open
    P0965 Press Ctrl Solenoid B Ctrl Circ Range/Perf
    P0966 Press Ctrl Solenoid B Ctrl Circ Low
    P0967 Press Ctrl Solenoid B Ctrl Circ High
    P0968 Press Ctrl Solenoid C Ctrl Circ/Open
    P0969 Press Ctrl Solenoid C Ctrl Circ Range/Perf
    P0970 Press Ctrl Solenoid C Ctrl Circ Low
    P0971 Press Ctrl Solenoid C Ctrl Circ High
    P0972 Shift Solenoid A Ctrl Circ Range/Perf
    P0973 Shift Solenoid A Ctrl Circ Low
    P0974 Shift Solenoid A Ctrl Circ High
    P0975 Shift Solenoid B Ctrl Circ Range/Perf
    P0976 Shift Solenoid B Ctrl Circ Low
    P0977 Shift Solenoid B Ctrl Circ High
    P0978 Shift Solenoid C Ctrl Circ Range/Perf
    P0979 Shift Solenoid C Ctrl Circ Low
    P0980 Shift Solenoid C Ctrl Circ High
    P0981 Shift Solenoid D Ctrl Circ Range/Perf
    P0982 Shift Solenoid D Ctrl Circ Low
    P0983 Shift Solenoid D Ctrl Circ High
    P0984 Shift Solenoid E Ctrl Circ Range/Perf
    P0985 Shift Solenoid E Ctrl Circ Low
    P0986 Shift Solenoid E Ctrl Circ High
    P0987 Trans Fluid Press Sensor/Switch E Circ
    P0988 Trans Fluid Press Sensor/Switch E Circ Range/Perf
    P0989 Trans Fluid Press Sensor/Switch E Circ Low
    P0990 Trans Fluid Press Sensor/Switch E Circ High
    P0991 Trans Fluid Press Sensor/Switch E Circ Interm
    P0992 Trans Fluid Press Sensor/Switch F Circ
    P0993 Trans Fluid Press Sensor/Switch F Circ Range/Perf
    P0994 Trans Fluid Press Sensor/Switch F Circ Low
    P0995 Trans Fluid Press Sensor/Switch F Circ High
    P0996 Trans Fluid Press Sensor/Switch F Circ Interm
    P0997 Shift Solenoid F Ctrl Circ Range/Perf
    P0998 Shift Solenoid F Ctrl Circ Low
    P0999 Shift Solenoid F Ctrl Circ High
    P0A00 Motor Electronics Coolant Temp Sensor Circ
    P0A01 Motor Electronics Coolant Temp Sensor Circ Range/Perf
    P0A02 Motor Electronics Coolant Temp Sensor Circ Low
    P0A03 Motor Electronics Coolant Temp Sensor Circ High
    P0A04 Motor Electronics Coolant Temp Sensor Circ Interm
    P0A05 Motor Electronics Coolant Pump Ctrl Circ/Open
    P0A06 Motor Electronics Coolant Pump Ctrl Circ Low
    P0A07 Motor Electronics Coolant Pump Ctrl Circ High
    P0A08 DC/DC Converter Status Circ
    P0A09 DC/DC Converter Status Circ Low Input
    P0A10 DC/DC Converter Status Circ High Input
    P0A11 DC/DC Converter Enable Circ/Open
    P0A12 DC/DC Converter Enable Circ Low
    P0A13 DC/DC Converter Enable Circ High
    P0A14 Engine Mount Ctrl Circ/Open
    P0A15 Engine Mount Ctrl Circ Low
    P0A16 Engine Mount Ctrl Circ High
    P0A17 Motor Torque Sensor Circ
    P0A18 Motor Torque Sensor Circ Range/Perf
    P0A19 Motor Torque Sensor Circ Low
    P0A20 Motor Torque Sensor Circ High
    P0A21 Motor Torque Sensor Circ Interm
    P0A22 Generator Torque Sensor Circ
    P0A23 Generator Torque Sensor Circ Range/Perf
    P0A24 Generator Torque Sensor Circ Low
    P0A25 Generator Torque Sensor Circ High
    P0A26 Generator Torque Sensor Circ Interm
    P0A27 Battery Power Off Circ
    P0A28 Battery Power Off Circ Low
    P0A29 Battery Power Off Circ High
    P1000 Monitor Checks Not Complete-More Driving Required
    P1105 Sec Vacuum Sensor Circ
    P1106 MAP Sens Circ Interm Hi Volts
    P1107 MAP Sens Circ Interm Lo Volts
    P1108 BARO to MAP Sens Comparison Too Hi
    P1109 Sec Port Throttle Sys
    P1111 Intake Air Temp Sens Circ Interm Hi Volts
    P1112 Intake Air Temp Sens Circ Interm Lo Volts
    P1113 Intake Resonance Switchover Solenoid Ctrl Circ
    P1114 Eng Coolant Temp Sens Circ Interm Lo Volts
    P1115 Eng Coolant Temp Sens Circ Interm Hi Volts
    P1116 Eng Coolant Temp Sig Unstable or Interm
    P1117 Eng Coolant Temp Sig Out-Of-Range Lo
    P1118 Eng Coolant Temp Sig Out-Of-Range Hi
    P1119 Eng Coolant Temp Sig Out-Of-Range With TFT Sens
    P1120 Throttle Pos Sens1 Circ
    P1121 Throttle Pos Sens Circ Interm Hi Volts
    P1122 Throttle Pos Sens Circ Interm Lo Volts
    P1125 APP Sys
    P1130 HO2S Circ Lo Variance Bank1 Sens1
    P1131 HO2S Circ Lo Variance Bank1 Sens2
    P1132 HO2S Circ Lo Variance Bank2 Sens1
    P1133 HO2S Insufficient Switching Bank1 Sens1
    P1134 HO2S Transition Time Ratio Bank1 Sens1
    P1135 HO2S Lean Mean Bank1 Sens1
    P1136 HO2S Rich Mean Bank1 Sens1
    P1137 HO2S Bank1 Sens2 Lean Sys or Lo Volts
    P1138 HO2S Bank1 Sens2 Rich or Hi Volts
    P1139 HO2S Insuff Switching Bank1 Sens2
    P1140 HO2S Transition Time Ratio Bank1 Sens2
    P1141 HO2S Heater Ctrl Circ Bank1 Sens2
    P1143 HO2S Bank1 Sens3 Lean Sys or Lo Volts
    P1144 HO2S Bank1 Sens3 Rich or Hi Volts
    P1153 HO2S Insufficient Switching Bank2 Sens1
    P1154 HO2S Transition Time Ratio Bank2 Sens1
    P1155 HO2S Lean Mean Bank2 Sens1
    P1156 HO2S Rich Mean Bank2 Sens1
    P1157 HO2S Bank2 Sens2 Lean Sys or Lo Volts
    P1158 HO2S Bank2 Sens2 Rich or Hi Volts
    P1159 HO2S Cross Counts Bank2 Sens2
    P1164 HO2S Bank2 Sens3 Rich or Hi Volts
    P1165 HO2S Cross Counts Bank2 Sens3
    P1170 Bank to Bank Fuel Trim Offset
    P1171 Fuel Sys Lean during Acceleration
    P1185 Eng Oil Temp Circ
    P1186 EOT Circ Perf
    P1187 EOT Sens Circ Lo Volts
    P1188 EOT Sens Circ Hi Volts
    P1189 Eng Oil Press (EOP) Switch Circ
    P1190 Eng Vacuum Leak
    P1191 Intake Air Duct Air Leak
    P1200 Injector Ctrl Circ
    P1201 (Alt. Fuel) Gas Mass Sens Circ Range/Perf
    P1202 (Alt. Fuel) Gas Mass Sens Circ Lo Freq
    P1203 (Alt. Fuel) Gas Mass Sens Circ Hi Freq
    P1211 Mass Air Flow Circ Interm Hi
    P1212 Mass Air Flow Circ Interm Lo
    P1214 Inject Pump Timing Offset
    P1215 Gnd Fault Detection Indicated
    P1216 Fuel Solenoid Response Time Too Short
    P1217 Fuel Solenoid Response Time Too Long
    P1218 Inject Pump Calibration Circ
    P1219 Throttle Pos Sens Ref Volts
    P1220 Throttle Pos (TP) Sens2 Circ
    P1221 Fuel Pump Sec Circ Lo
    P1222 Injector Ctrl Circ Interm
    P1225 Injector Circ Cyl2 Interm
    P1228 Injector Circ Cyl3 Interm
    P1231 Injector Circ Cyl4 Interm
    P1234 Injector Circ Cyl5 Interm
    P1237 Injector Circ Cyl6 Interm
    P1240 Injector Circ Cyl7 Interm
    P1243 Injector Circ Cyl8 Interm
    P1245 Intake Plenum Switchover Valve
    P1250 Early Fuel Evaporation Heater Circ
    P1257 Supercharger Sys Over boost
    P1258 Eng Coolant over Temp-Protection Mode Active
    P1260 Last Test Failed SCC ENTER More Info.
    P1270 Accelerator Pedal Pos Sens A/D Converter Error
    P1271 Accelerator Pedal Pos (APP) Sens1-2 Correlation
    P1272 Accelerator Pedal Pos Sens2
    P1273 Accelerator Pedal Pos Sens1
    P1274 Injectors Wired Incorrectly
    P1275 Accelerator Pedal Pos (APP) Sens1 Circ
    P1276 Accelerator Pedal Pos Sens1 Circ Perf
    P1277 Accelerator Pedal Pos Sens1 Circ Lo Volts
    P1278 Accelerator Pedal Pos Sens1 Circ Hi Volts
    P1280 Accelerator Pedal Pos (APP) Sens2 Circ
    P1281 Accelerator Pedal Pos Sens2 Circ Perf
    P1282 Accelerator Pedal Pos Sens2 Circ Lo Volts
    P1283 Accelerator Pedal Pos Sens2 Circ Hi Volts
    P1285 Accelerator Pedal Pos Sens3 Circ
    P1286 Accelerator Pedal Pos Sens3 Circ Perf
    P1287 Accelerator Pedal Pos Sens3 Circ Lo Volts
    P1288 Accelerator Pedal Pos Sens3 Circ Hi Volts
    P1300 Igniter Circ
    P1305 Ign Coil 2 Pri Feedback Circ
    P1310 Ign Coil 3 Pri Feedback Circ
    P1315 Ign Coil 4 Pri Feedback Circ
    P1320 C 4X Ref Circ Interm
    P1321 Electronic Ign Sys Fault Line
    P1322 EI Sys or Ign Ctrl Extra or Missing
    P1323 IC 24X Ref Circ Lo Freq
    P1324 Crank RPM Too Lo
    P1335 CKP Circ
    P1336 Crank Pos (CKP) Sys Variation Not Learned
    P1345 Crank Pos (CKP)-Camshaft Pos (CMP) Correlation
    P1346 Intake Camshaft Pos [CMP] Sens Sys Perf
    P1350 Ign Ctrl Sys
    P1351 Ign Coil Ctrl Circ Hi Volts
    P1352 IC Output Hi/Pulse Detected when GND Cyl. 2
    P1353 IC Output Hi/Pulse Detected when GND Cyl. 3
    P1354 IC Output Hi/Pulse Detected when GND Cyl. 4
    P1355 IC Output Hi/Pulse Detected when GND Cyl. 5
    P1356 IC Output Hi/Pulse Detected when GND Cyl. 6
    P1357 IC Output Hi/Pulse Detected when GND Cyl. 7
    P1358 IC Output Hi/Pulse Detected when GND Cyl. 8
    P1359 Ignition Coil Group 1 Ctrl Circ
    P1360 Ignition Coil Group 2 Ctrl Circ
    P1361 Ignition Coil Ctrl Circ Lo Volts
    P1362 IC Cyl2 Not Toggling After Enable
    P1363 IC Cyl3 Not Toggling After Enable
    P1364 IC Cyl4 Not Toggling After Enable
    P1365 IC Cyl5 Not Toggling After Enable
    P1366 IC Cyl6 Not Toggling After Enable
    P1367 IC Cyl7 Not Toggling After Enable
    P1368 IC Cyl8 Not Toggling After Enable
    P1370 IC 4X Ref Circ Too Many Pulses
    P1371 IC 4X Ref Circ Too Few Pulses
    P1372 Crank Pos (CKP) SensorA-B Correlation
    P1374 3X Ref Circ
    P1375 IC 24X Ref Circ Hi Volts
    P1376 Ignition Gnd Circ
    P1377 IC Cam Pulse To 4X Ref Pulse
    P1380 Misfire Detected-Rough Road Data Not Available
    P1381 Misfire Detected-No Comm with Brake Ctrl Mod
    P1390 Wheel Speed Sensor1-G-Sensor Circ
    P1391 Wheel Speed Sensor1-G-Sensor Circ Perf
    P1392 Wheel Speed Sensor1-G-Sensor Circ Lo Volts
    P1393 Wheel Speed Sensor1-G-Sensor Circ Hi Volts
    P1394 Wheel Speed Sensor1-G-Sensor Circ Interm
    P1395 Wheel Speed Sensor2-G-Sensor Circ
    P1396 Wheel Speed Sensor2-G-Sensor Circ Perf
    P1397 Wheel Speed Sensor2-G-Sensor Circ Lo Volts
    P1398 Wheel Speed Sensor2-G-Sensor Circ Hi Volts
    P1399 Wheel Speed Sensor2-G-Sensor Circ Interm
    P1403 Exhaust Gas Recirc Sys Valve 1
    P1404 Exhaust Gas Recirc (EGR) Closed Pos Perf
    P1405 Exhaust Gas Recirc Sys Valve 3
    P1406 EGR Valve Pintle Pos Circ
    P1407 EGR Air Intrusion in Exhaust Supply to EGR Valve
    P1408 Intake Manifold Press Sensor Circ
    P1409 EGR Vacuum Sys Leak
    P1410 Fuel Tank Press Sys
    P1415 Sec Air Inject (AIR) Sys Bank1
    P1416 Sec Air Inject (AIR) Sys Bank2
    P1418 Sec Air Inject Sys Relay A Ctrl Circ Hi
    P1420 Intake Air Lo Press Switch Circ Lo Volts
    P1421 Intake Air Lo Press Switch Circ Hi Volts
    P1423 Intake Air Hi Press Switch Circ Hi Volts
    P1431 Fuel Level Sensor2 Circ Perf
    P1432 Fuel Level Sensor2 Circ Lo Volts
    P1433 Fuel Level Sensor2 Circ Hi Volts
    P1441 EVAP Emission Sys Flow during Non-Purge
    P1442 EVAP Vacuum Sw. Hi Volts during Ignition. On
    P1450 Barometric Press Sensor Circ
    P1451 Barometric Press Sensor Perf
    P1460 Cooling Fan Ctrl Sys
    P1480 Fan Sec Lo With Lo Fan On
    P1481 Fan Sec Lo With Hi Fan On
    P1483 Eng Cooling Sys Perf
    P1500 Starter Signal Circ
    P1501 Vehicle Speed Sensor Circ Interm
    P1501 Theft Deterrent Sys
    P1502 Theft Deterrent Fuel Enable Signal Not
    P1503 Theft Deterrent Sys-Password Incorrect
    P1504 Vehicle Speed Output Circ
    P1508 IAC Sys Lo RPM
    P1509 IAC Sys Hi RPM
    P1510 Back Up Power Supply
    P1511 Throttle Ctrl Sys-Backup Sys Perf
    P1514 Air Flow to TP Sensor Correlation Hi
    P1515 Electronic Throttle Sys Throttle Pos
    P1516 Electronic Throttle Mod Throttle Pos
    P1517 Electronic Throttle Mod
    P1518 Electronic Throttle Mod to PCM Comm
    P1519 Electronic Throttle Mod Lo Volts Comm. Disable
    P1520 Gear Indicator Sys
    P1521 Trans Engaged at Hi Throttle Angle
    P1522 Park/Neutral to Drive/Reverse at Hi RPM
    P1523 Elec. Throttle Ctrl Throttle Return
    P1524 TP Sen. Learned Cl. Throttle. Angle Out of Range
    P1525 Throttle Body Service Required
    P1526 TP Sensor Learn Not Complete
    P1527 Trans. Range/Press Switch Comparison
    P1528 Governor
    P1529 Heated Windshield Request Problem
    P1530 Ignition Timing Adjustment Switch Circ
    P1531 A/C Lo Side Temp Sensor Fault
    P1532 A/C Evaporator Temp Sensor Circ Lo Voltage
    P1533 A/C Evaporator Temp Sensor Circ Hi Voltage
    P1534 A/C Hi Side Temp. Sensor Lo Voltage
    P1535 A/C Hi Side Temp Sensor Circ
    P1536 A/C Sys-ECT Over Temp
    P1537 A/C Request Circ Lo Voltage
    P1538 A/C Request Circ Hi Voltage
    P1539 A/C Clutch Status Circ High Volts
    P1540 A/C Sys Hi Press
    P1541 A/C Hi Side Over Temp
    P1542 A/C Sys Hi Press Hi Temp
    P1543 A/C Sys Perf
    P1544 A/C Refrigerant Condition Very Lo
    P1545 A/C Clutch Relay Ctrl Circ
    P1546 A/C Clutch Status Circ Lo Voltage
    P1547 A/C Sys Perf Degraded
    P1548 A/C Recirculation Circ
    P1554 Cruise Engaged Circ Hi Voltage
    P1555 Electronic Variable Orifice Output
    P1558 Cruise Ctrl Servo Indicates Lo
    P1559 Cruise Ctrl Power Mgmt Mode
    P1560 Cruise Ctrl Sys-Transaxle Not In Drive
    P1561 Cruise Vent Solenoid
    P1562 Cruise Vacuum Solenoid
    P1563 Cruise Vehicle Speed/Set Speed Difference Too Hi
    P1564 Cruise Ctrl Sys-Vehicle Accel Too Hi
    P1565 Cruise Servo Pos Sensor
    P1566 Cruise Ctrl Sys-Engine RPM Too Hi
    P1567 Cruise Ctrl Sys-Active Braking Ctrl Active
    P1568 Cruise Servo Stroke Greater than Commanded in Cruise
    P1569 Cruise Servo Stroke Hi While not in Cruise
    P1570 Cruise Ctrl Sys-Traction Ctrl Active
    P1571 TCS PWM Circ No Frequency
    P1572 ASR Active Circ Lo Too Long
    P1573 PCM/EBTCM Serial Data Circ
    P1574 EBTCM Sys-Stop Lamp Switch Circ Hi Volts
    P1575 Extended Travel Brake Sw. Circ Hi Volts
    P1576 BBV Sensor Circ Hi Voltage
    P1577 BBV Sensor Circ Lo Voltage
    P1578 BBV Sensor Circ Lo Vacuum
    P1579 P/N to D/R at Hi Throttle Angle
    P1580 Cruise Move Circ Lo Voltage
    P1581 Cruise Move Circ Hi Voltage
    P1582 Cruise Direction Circ Lo Voltage
    P1583 Cruise Direction Circ Hi Voltage
    P1584 Cruise Ctrl Disabled
    P1585 Cruise Inhibit Ctrl Circ
    P1586 Cruise Ctrl Brake Switch 2 Circ
    P1587 Cruise Ctrl Clutch Ctrl Circ Lo
    P1588 Cruise Ctrl Clutch Ctrl Circ Hi
    P1599 Eng Stall or Near Stall Detected
    Aug 2007
    Connecticut
    P1600 PCM Battery/TCM Watchdog
    P1601 Serial Comm. Problem with Device 1
    P1602 Loss of EBTCM Serial Data
    P1603 Loss of SDM Serial Data
    P1604 Loss of IPC Serial Data
    P1605 Loss of HVAC Serial Data
    P1606 Serial Comm Problem with Device 6
    P1607 Serial Comm Problem with Device 7
    P1608 Serial Comm Problem with Device 8
    P1609 Loss of TCS Serial Data
    P1610 Loss of PZM Serial Data
    P1611 Loss of CVRTD Serial Data
    P1612 Loss of IPM Serial Data
    P1613 Loss of DIM Serial Data
    P1614 Loss of RIM Serial Data
    P1615 Loss of VTD Serial Data
    P1617 Engine Oil Level Switch Circ
    P1619 Engine Oil Life Monitor Reset Circ
    P1620 Lo Coolant Circ
    P1621 PCM Memory Perf
    P1622 Cylinder Select
    P1623 Trans Temp Pull-Up Resistor
    P1624 Customer Snapshot Data Available
    P1625 PCM Sys Reset
    P1626 Theft Deterrent Sys Fuel Enable Circ
    P1627 A/D Perf
    P1628 ECT Pull-Up Resistor
    P1629 Theft Deterrent Sys-Cranking Signal
    P1630 Theft Deterrent Sys-PCM In Learn Mode
    P1631 Theft Deterrent Sys-Password Incorrect
    P1632 Theft Deterrent Sys-Fuel disabled
    P1633 Ignition Supply Power Circ Lo Voltage
    P1634 Ignition 1 Power Circ Lo Voltage
    P1635 5 Volt Ref Lo
    P1636 PCM Stack Overrun
    P1637 Generator L-Terminal Circ
    P1638 Generator F-Terminal Circ
    P1639 5 Volt Ref 2 Circ
    P1640 Driver 1-Input Hi Voltage
    P1641 FC Relay 1 Ctrl Circ
    P1642 FC Relay 2 and 3 Ctrl Circ
    P1643 Engine Speed Output Circ
    P1644 Traction Ctrl Delivered Torque Output Circ
    P1645 EVAP Emission (EVAP) Vent Solenoid Ctrl Circ
    P1646 Driver 1 Line 6
    P1647 Driver 1 Line 7
    P1650 Driver 2-Input Hi Voltage
    P1651 Fan 1 Relay Ctrl Circ
    P1652 VSS Output Circ
    P1653 Oil Level Lamp Ctrl Circ
    P1654 Service Throttle Soon Lamp Ctrl Circ
    P1655 EVAP Purge Solenoid Ctrl Circ
    P1656 Driver 2 Line 6
    P1657 1-4 Up shift Solenoid Ctrl Circ
    P1658 Starter Enable Relay Ctrl Circ
    P1660 Cooling Fans Ctrl Circ
    P1661 MIL Ctrl Circ
    P1662 Cruise Ctrl Inhibit Ctrl Circ
    P1663 Oil Life Lamp Ctrl Circ
    P1664 1-4 Up shift Lamp Ctrl Circ
    P1665 Driver 3 Line 5
    P1666 Driver 3 Line 6
    P1667 Reverse Inhibit Solenoid Ctrl Circ
    P1669 ABS Unit Expected
    P1670 Driver 4
    P1671 Driver 4 Line 1
    P1672 Lo Engine Oil Level Lamp Ctrl Circ
    P1673 Engine Hot Lamp Ctrl Circ
    P1674 Tachometer Ctrl Circ
    P1675 EVAP Vent Solenoid Ctrl Circ
    P1676 Driver 4 Line 6
    P1677 Driver 4 Line 7
    P1680 Driver 5
    P1681 Driver 5 Line 1
    P1682 Driver 5 Line 2
    P1683 Driver 5 Line 3
    P1684 Driver 5 Line 4
    P1685 Driver 5 Line 5
    P1686 Driver 5 Line 6
    P1687 Driver 5 Line 7
    P1689 Delivered Torque Circ Fault
    P1690 ECM Loop Overrun
    P1691 Coolant Gage Circ Lo Voltage
    P1692 Coolant Gage Circ Hi Voltage
    P1693 Tachometer Circ Lo Voltage
    P1694 Tachometer Circ Hi Voltage
    P1695 Remote Keyless Entry Circ Lo
    P1696 Remote Keyless Entry Voltage Hi
    P1700 Trans. MIL Request
    P1701 Trans. MIL Request Circ
    P1705 P/N Signal Output Circ
    P1740 Torque Reduction Signal Circ
    P1743 TP Signal from ECM
    P1760 TCM Supply Volts Interrupted
    P1779 Eng Torque Delivered to TCM Signal
    P1780 Park/Neutral Pos [PNP] Switch Circ
    P1781 Eng Torque Signal Circ
    P1790 Trans Ctrl Mod Checksum
    P1791 Trans Ctrl Mod Loop
    P1792 Trans Ctrl Mod Reprogrammable Memory
    P1792 ECM to TCM Eng Coolant Signal
    P1793 Trans Ctrl Mod Stack Overrun
    P1795 CAN Bus-Throttle Body Pos
    P1800 TCM Power Relay Ctrl Circ
    P1801 Perf Selector Switch Failure
    P1804 Gnd Ctrl Relay
    P1810 TFP Valve Pos Switch Circ
    P1811 Maximum Adapt and Long Shift
    P1812 Trans over Temp Condition
    P1813 Torque Ctrl
    P1814 Torq Conv Overstressed
    P1815 Trans Range Switch-Start In Wrong Range
    P1816 TFP Valve Pos Sw.-Park/Neutral with Drive Ratio
    P1817 TFP Valve Pos Sw.-Reverse With Drive Ratio
    P1818 TFP Valve Pos Sw.-Drive Without Drive Ratio
    P1819 Internal Mode Switch-No Start\Wrong Range
    P1820 Internal Mode Switch Circ A Low
    P1822 Internal Mode Switch Circ B High
    P1823 Internal Mode Switch Circ P Low
    P1825 Internal Mode Switch-Invalid Range
    P1826 Internal Mode Switch Circ C-High
    P1831 PC Solenoid Power Circ-Low Volts
    P1833 A/T Solenoids Power Circ-Low Volts
    P1835 Kick-Down Switch Circ
    P1836 Kick-Down Switch Failed Open
    P1837 Kick-Down Switch Failed Short
    P1842 1-2 Shift Solenoid Circ Low Volts
    P1843 1-2 Shift Solenoid Circ High Volts
    P1844 Torque Reduction Signal Circ Desired By TCM
    P1845 2-3 Shift Solenoid Circ Low Volts
    P1847 2-3 Shift Solenoid Circ High Volts
    P1850 Brake Band Apply Solenoid Circ
    P1851 Brake Band Apply Solenoid Perf
    P1852 Brake Band Apply Solenoid Low Volts
    P1853 Brake Band Apply Solenoid High Volts
    P1860 TCC PWM Solenoid Circ Electrical
    P1864 Torq Conv Clutch Circ
    P1868 Trans Fluid Life
    P1870 Trans Component Slipping
    P1871 Undefined Gear Ratio
    P1873 TCC Stator Temp Switch Circ Low
    P1874 TCC Stator Temp Switch Circ High
    P1875 4WD Low Switch Circ Electrical
    P1884 TCC Enable/Shift Light Circ
    P1886 Shift Timing Solenoid
    P1887 TCC Release Switch Circ
    P1890 ECM Data Input Circ
    P1890 Throttle Pos Signal Input
    P1891 Throttle Pos Sensor PWM Signal Low
    P1892 Throttle Pos Sensor PWM Signal High
    P1893 Eng Torque Signal Low Volts
    P1894 Eng Torque Signal High Volts
    P1895 TCM to ECM Torque Reduction Circ
    P2000 NOx Trap Efficiency Below Threshold Bank1
    P2001 NOx Trap Efficiency Below Threshold Bank2
    P2002 Particulate Trap Efficiency Below Threshold Bank1
    P2003 Particulate Trap Efficiency Below Threshold Bank2
    P2004 Intake Manifold Runner Ctrl Stuck Open Bank1
    P2005 Intake Manifold Runner Ctrl Stuck Open Bank2
    P2006 Intake Manifold Runner Ctrl Stuck Closed Bank1
    P2007 Intake Manifold Runner Ctrl Stuck Closed Bank2
    P2008 Intake Manifold Runner Ctrl Circ/Open Bank1
    P2009 Intake Manifold Runner Ctrl Circ Low Bank1
    P2010 Intake Manifold Runner Ctrl Circ High Bank1
    P2011 Intake Manifold Runner Ctrl Circ/Open Bank2
    P2012 Intake Manifold Runner Ctrl Circ Low Bank2
    P2013 Intake Manifold Runner Ctrl Circ High Bank2
    P2014 Intake Manifold Runner Pos Sensor/Switch Circ Bank1
    P2015 Intake Manifold Runner Pos Sensor/Switch Circ Range/Perf Bank1
    P2016 Intake Manifold Runner Pos Sensor/Switch Circ Low Bank1
    P2017 Intake Manifold Runner Pos Sensor/Switch Circ High Bank1
    P2018 Intake Manifold Runner Pos Sensor/Switch Circ Interm Bank1
    P2019 Intake Manifold Runner Pos Sensor/Switch Circ Bank2
    P2020 Intake Manifold Runner Pos Sensor/Switch Circ Range/Perf Bank2
    P2021 Intake Manifold Runner Pos Sensor/Switch Circ Low Bank2
    P2022 Intake Manifold Runner Pos Sensor/Switch Circ High Bank2
    P2023 Intake Manifold Runner Pos Sensor/Switch Circ Interm Bank2
    P2024 EVAP Fuel Vapor Temp Sensor Circ
    P2025 EVAP Fuel Vapor Temp Sensor Perf
    P2026 EVAP Fuel Vapor Temp Sensor Circ Low Voltage
    P2027 EVAP Fuel Vapor Temp Sensor Circ High Voltage
    P2028 EVAP Fuel Vapor Temp Sensor Circ Interm
    P2029 Fuel Fired Heater Disabled
    P2030 Fuel Fired Heater Perf
    P2031 Exhaust Gas Temp Sensor Circ Bank1 Sensor 2
    P2032 Exhaust Gas Temp Sensor Circ Low Bank1 Sensor 2
    P2033 Exhaust Gas Temp Sensor Circ High Bank1 Sensor 2
    P2034 Exhaust Gas Temp Sensor Circ Bank2 Sensor 2
    P2035 Exhaust Gas Temp Sensor Circ Low Bank2 Sensor 2
    P2036 Exhaust Gas Temp Sensor Circ High Bank2 Sensor 2
    P2037 Reductant Inj Air Press Sensor Circ
    P2038 Reductant Inj Air Press Sensor Circ Range/Perf
    P2039 Reductant Inj Air Press Sensor Circ Low Input
    P2040 Reductant Inj Air Press Sensor Circ High Input
    P2041 Reductant Inj Air Press Sensor Circ Interm
    P2042 Reductant Temp Sensor Circ
    P2043 Reductant Temp Sensor Circ Range/Perf
    P2044 Reductant Temp Sensor Circ Low Input
    P2045 Reductant Temp Sensor Circ High Input
    P2046 Reductant Temp Sensor Circ Interm
    P2047 Reductant Injector Circ/Open Bank1 Unit 1
    P2048 Reductant Injector Circ Low Bank1 Unit 1
    P2049 Reductant Injector Circ High Bank1 Unit 1
    P2050 Reductant Injector Circ/Open Bank2 Unit 1
    P2051 Reductant Injector Circ Low Bank2 Unit 1
    P2052 Reductant Injector Circ High Bank2 Unit 1
    P2053 Reductant Injector Circ/Open Bank1 Unit 2
    P2054 Reductant Injector Circ Low Bank1 Unit 2
    P2055 Reductant Injector Circ High Bank1 Unit 2
    P2056 Reductant Injector Circ/Open Bank2 Unit 2
    P2057 Reductant Injector Circ Low Bank2 Unit 2
    P2058 Reductant Injector Circ High Bank2 Unit 2
    P2059 Reductant Inj Air Pump Ctrl Circ/Open
    P2060 Reductant Inj Air Pump Ctrl Circ Low
    P2061 Reductant Inj Air Pump Ctrl Circ High
    P2062 Reductant Supply Ctrl Circ/Open
    P2063 Reductant Supply Ctrl Circ Low
    P2064 Reductant Supply Ctrl Circ High
    P2065 Fuel Level SensorB Circ
    P2066 Fuel Level SensorB Perf
    P2067 Fuel Level SensorB Circ Low
    P2068 Fuel Level SensorB Circ High
    P2069 Fuel Level SensorB Circ Interm
    P2070 Intake Manifold Tuning (IMT) Valve Stuck Open
    P2071 IMT Valve Stuck Closed
    P2075 IMT Valve Pos Sensor/Switch Circ
    P2076 IMT Valve Pos Sensor/Switch Circ Range/Perf
    P2077 IMT Valve Pos Sensor/Switch Circ Low
    P2078 IMT Valve Pos Sensor/Switch Circ High
    P2079 IMT Valve Pos Sensor/Switch Circ Interm
    P2080 Exhaust Gas Temp Sensor Circ Range/Perf Bank1 Sensor 1
    P2081 Exhaust Gas Temp Sensor Circ Interm Bank1 Sensor 1
    P2082 Exhaust Gas Temp Sensor Circ Range/Perf Bank2 Sensor 1
    P2083 Exhaust Gas Temp Sensor Circ Interm Bank2 Sensor 1
    P2084 Exhaust Gas Temp Sensor Circ Range/Perf Bank1 Sensor 2
    P2085 Exhaust Gas Temp Sensor Circ Interm Bank1 Sensor 2
    P2086 Exhaust Gas Temp Sensor Circ Range/Perf Bank2 Sensor 2
    P2087 Exhaust Gas Temp Sensor Circ Interm Bank2 Sensor 2
    P2088 A Camshaft Pos Actuator Ctrl Circ Low Bank1
    P2089 A Camshaft Pos Actuator Ctrl Circ High Bank1
    P2090 B Camshaft Pos Actuator Ctrl Circ Low Bank1
    P2091 B Camshaft Pos Actuator Ctrl Circ High Bank1
    P2092 A Camshaft Pos Actuator Ctrl Circ Low Bank2
    P2093 A Camshaft Pos Actuator Ctrl Circ High Bank2
    P2094 B Camshaft Pos Actuator Ctrl Circ Low Bank2
    P2095 B Camshaft Pos Actuator Ctrl Circ High Bank2
    P2096 Post Catalyst Fuel Trim Sys Too Lean Bank1
    P2097 Post Catalyst Fuel Trim Sys Too Rich Bank1
    P2098 Post Catalyst Fuel Trim Sys Too Lean Bank2
    P2099 Post Catalyst Fuel Trim Sys Too Rich Bank2
    P2100 Throttle Actuator Ctrl Motor Circ/Open
    P2101 Throttle Actuator Ctrl Motor Circ Range/Perf
    P2102 Throttle Actuator Ctrl Motor Circ Low
    P2103 Throttle Actuator Ctrl Motor Circ High
    P2104 Throttle Actuator Ctrl Sys-Forced Idle
    P2105 Throttle Actuator Ctrl Sys-Forced Engine Shutdown
    P2106 Throttle Actuator Ctrl Sys-Forced Limited Power
    P2107 Throttle Actuator Ctrl Mod Processor
    P2108 Throttle Actuator Ctrl Mod Perf
    P2109 Throttle/Pedal Pos SensorA Minimum Stop Perf
    P2110 Throttle Actuator Ctrl Sys-Forced Limited RPM
    P2111 Throttle Actuator Ctrl Sys-Stuck Open
    P2112 Throttle Actuator Ctrl Sys-Stuck Closed
    P2113 Throttle/Pedal Pos SensorB Minimum Stop Perf
    P2114 Throttle/Pedal Pos Sensor C Minimum Stop Perf
    P2115 Throttle/Pedal Pos Sensor D Minimum Stop Perf
    P2116 Throttle/Pedal Pos Sensor E Minimum Stop Perf
    P2117 Throttle/Pedal Pos Sensor F Minimum Stop Perf
    P2118 Throttle Actuator Ctrl Motor Current Range/Perf
    P2119 Throttle Actuator Ctrl Throttle Body Range/Perf
    P2120 Throttle/Pedal Pos Sensor/Switch D Circ
    P2121 Throttle/Pedal Pos Sensor/Switch D Circ Range/Perf
    P2122 Throttle/Pedal Pos Sensor/Switch D Circ Low Input
    P2123 Throttle/Pedal Pos Sensor/Switch D Circ High Input
    P2124 Throttle/Pedal Pos Sensor/Switch D Circ Interm
    P2125 Throttle/Pedal Pos Sensor/Switch E Circ
    P2126 Throttle/Pedal Pos Sensor/Switch E Circ Range/Perf
    P2127 Throttle/Pedal Pos Sensor/Switch E Circ Low Input
    P2128 Throttle/Pedal Pos Sensor/Switch E Circ High Input
    P2129 Throttle/Pedal Pos Sensor/Switch E Circ Interm
    P2130 Throttle/Pedal Pos Sensor/Switch F Circ
    P2131 Throttle/Pedal Pos Sensor/Switch F Circ Range Perf
    P2132 Throttle/Pedal Pos Sensor/Switch F Circ Low Input
    P2133 Throttle/Pedal Pos Sensor/Switch F Circ High Input
    P2134 Throttle/Pedal Pos Sensor/Switch F Circ Interm
    P2135 Throttle/Pedal Pos Sensor/Switch A / B Voltage Correlation
    P2136 Throttle/Pedal Pos Sensor/Switch A / C Voltage Correlation
    P2137 Throttle/Pedal Pos Sensor/Switch B / C Voltage Correlation
    P2138 Throttle/Pedal Pos Sensor/Switch D / E Voltage Correlation
    P2139 Throttle/Pedal Pos Sensor/Switch D / F Voltage Correlation
    P2140 Throttle/Pedal Pos Sensor/Switch E / F Voltage Correlation
    P2141 Exhaust Gas Recirculation Throttle Ctrl Circ Low
    P2142 Exhaust Gas Recirculation Throttle Ctrl Circ High
    P2143 Exhaust Gas Recirculation Vent Ctrl Circ/Open
    P2144 Exhaust Gas Recirculation Vent Ctrl Circ Low
    P2145 Exhaust Gas Recirculation Vent Ctrl Circ High
    P2146 Fuel Injector Group A Supply Voltage Circ/
    2WD MONSTER 2wdchevywt's Avatar
    Aug 2007
    Connecticut
    P2150 Fuel Injector Group B Supply Voltage Circ Low
    P2151 Fuel Injector Group B Supply Voltage Circ High
    P2152 Fuel Injector Group C Supply Voltage Circ/Open
    P2153 Fuel Injector Group C Supply
    P2154 Fuel Injector Group C Supply Voltage Circ High
    P2155 Fuel Injector Group D Supply Voltage Circ/Open
    P2156 Fuel Injector Group D Supply Voltage Circ Low
    P2157 Fuel Injector Group D Supply Voltage Circ High
    P2158 Vehicle Speed SensorB
    P2159 Vehicle Speed SensorB Range/Perf
    P2160 Vehicle Speed SensorB Circ Low
    P2161 Vehicle Speed SensorB Interm/Erratic
    P2162 Vehicle Speed SensorA / B Correlation
    P2163 Throttle/Pedal Pos SensorA Maximum Stop Perf
    P2164 Throttle/Pedal Pos SensorB Maximum Stop Perf
    P2165 Throttle/Pedal Pos Sensor C Maximum Stop Perf
    P2166 Throttle/Pedal Pos Sensor D Maximum Stop Perf
    P2167 Throttle/Pedal Pos Sensor E Maximum Stop Perf
    P2168 Throttle/Pedal Pos Sensor F Maximum Stop Perf
    P2169 Exhaust Press Reg Vent Solenoid Ctrl Circ/Open
    P2170 Exhaust Press Reg Vent Solenoid Ctrl Circ Low
    P2171 Exhaust Press Reg Vent Solenoid Ctrl Circ High
    P2172 Throttle Actuator Ctrl Sys-Sudden High Airflow Detected
    P2173 Throttle Actuator Ctrl Sys-High Airflow Detected
    P2174 Throttle Actuator Ctrl Sys-Sudden Low Airflow Detected
    P2175 Throttle Actuator Ctrl Sys-Low Airflow Detected
    P2176 Throttle Actuator Ctrl Sys-Idle Pos Not Learned
    P2177 Sys Too Lean Off Idle Bank1
    P2178 Sys Too Rich Off Idle Bank1
    P2179 Sys Too Lean Off Idle Bank2
    P2180 Sys Too Rich Off Idle Bank2
    P2181 Cooling Sys Perf
    P2182 Engine Coolant Temp Sensor 2 Circ
    P2183 Engine Coolant Temp Sensor 2 Circ Range/Perf
    P2184 Engine Coolant Temp Sensor 2 Circ Low
    P2185 Engine Coolant Temp Sensor 2 Circ High
    P2186 Engine Coolant Temp Sensor 2 Circ Interm/Erratic
    P2187 Sys Too Lean at Idle Bank1
    P2188 Sys Too Rich at Idle Bank1
    P2189 Sys Too Lean at Idle Bank2
    P2190 Sys Too Rich at Idle Bank2
    P2191 Sys Too Lean at Higher Load Bank1
    P2192 Sys Too Rich at Higher Load Bank1
    P2193 Sys Too Lean at Higher Load Bank2
    P2194 Sys Too Rich at Higher Load Bank2
    P2195 O2 Sensor Signal Stuck Lean Bank1 Sensor 1
    P2196 O2 Sensor Signal Stuck Rich Bank1 Sensor 1
    P2197 O2 Sensor Signal Stuck Lean Bank2 Sensor 1
    P2198 O2 Sensor Signal Stuck Rich Bank2 Sensor 1
    P2199 Intake Air Temp Sensor 1 / 2 Correlation
    P2200 NOx Sensor Circ Bank1
    P2201 NOx Sensor Circ Range/Perf Bank1
    P2202 NOx Sensor Circ Low Input Bank1
    P2203 NOx Sensor Circ High Input Bank1
    P2204 NOx Sensor Circ Interm Input Bank1
    P2205 NOx Sensor Heater Ctrl Circ/Open Bank1
    P2206 NOx Sensor Heater Ctrl Circ Low Bank1
    P2207 NOx Sensor Heater Ctrl Circ High Bank1
    P2208 NOx Sensor Heater Sense Circ Bank1
    P2209 NOx Sensor Heater Sense Circ Range/Perf Bank1
    P2210 NOx Sensor Heater Sense Circ Low Input Bank1
    P2211 NOx Sensor Heater Sense Circ High Input Bank1
    P2212 NOx Sensor Heater Sense Circ Interm Bank1
    P2213 NOx Sensor Circ Bank2
    P2214 NOx Sensor Circ Range/Perf Bank2
    P2215 NOx Sensor Circ Low Input Bank2
    P2216 NOx Sensor Circ High Input Bank2
    P2217 NOx Sensor Circ Interm Input Bank2
    P2218 NOx Sensor Heater Ctrl Circ/Open Bank2
    P2219 NOx Sensor Heater Ctrl Circ Low Bank2
    P2220 NOx Sensor Heater Ctrl Circ High Bank2
    P2221 NOx Sensor Heater Sense Circ Bank2
    P2222 NOx Sensor Heater Sense Circ Range/Perf Bank2
    P2223 NOx Sensor Heater Sense Circ Low Bank2
    P2224 NOx Sensor Heater Sense Circ High Bank2
    P2225 NOx Sensor Heater Sense Circ Interm Bank2
    P2226 Barometric Press Circ
    P2227 Barometric Press Circ Range/Perf
    P2228 Barometric Press Circ Low
    P2229 Barometric Press Circ High
    P2230 Barometric Press Circ Interm
    P2231 O2 Sensor Signal Circ Shorted to Heater Circ Bank1 Sensor 1
    P2232 O2 Sensor Signal Circ Shorted to Heater Circ Bank1 Sensor 2
    P2233 O2 Sensor Signal Circ Shorted to Heater Circ Bank1 Sensor 3
    P2234 O2 Sensor Signal Circ Shorted to Heater Circ Bank2 Sensor 1
    P2235 O2 Sensor Signal Circ Shorted to Heater Circ Bank2 Sensor 2
    P2236 O2 Sensor Signal Circ Shorted to Heater Circ Bank2 Sensor 3
    P2237 O2 Sensor Positive Current Ctrl Circ/Open Bank1 Sensor 1
    P2238 O2 Sensor Positive Current Ctrl Circ Low Bank1 Sensor 1
    P2239 O2 Sensor Positive Current Ctrl Circ High Bank1 Sensor 1
    P2240 O2 Sensor Positive Current Ctrl Circ/Open Bank2 Sensor 1
    P2241 O2 Sensor Positive Current Ctrl Circ Low Bank2 Sensor 1
    P2242 O2 Sensor Positive Current Ctrl Circ High Bank2 Sensor 1
    P2243 O2 Sensor Ref Voltage Circ/Open Bank1 Sensor 1
    P2244 O2 Sensor Ref Voltage Perf Bank1 Sensor 1
    P2245 O2 Sensor Ref Voltage Circ Low Bank1 Sensor 1
    P2246 O2 Sensor Ref Voltage Circ High Bank1 Sensor 1
    P2247 O2 Sensor Ref Voltage Circ/Open Bank2 Sensor 1
    P2248 O2 Sensor Ref Voltage Perf Bank2 Sensor 1
    P2249 O2 Sensor Ref Voltage Circ Low Bank2 Sensor 1
    P2250 O2 Sensor Ref Voltage Circ High Bank2 Sensor 1
    P2251 O2 Sensor Negative Current Ctrl Circ/Open Bank1 Sensor 1
    P2252 O2 Sensor Negative Current Ctrl Circ Low Bank1 Sensor 1
    P2253 O2 Sensor Negative Current Ctrl Circ High Bank1 Sensor 1
    P2254 O2 Sensor Negative Current Ctrl Circ/Open Bank2 Sensor 1
    P2255 O2 Sensor Negative Current Ctrl Circ Low Bank2 Sensor 1
    P2256 O2 Sensor Negative Current Ctrl Circ High Bank2 Sensor 1
    P2257 Sec Air Inj Sys Ctrl A Circ Low
    P2258 Sec Air Inj Sys Ctrl A Circ High
    P2259 Sec Air Inj Sys Ctrl B Circ Low
    P2260 Sec Air Inj Sys Ctrl B Circ High
    P2261 T/S Charger Bypass Valve-Mechanical
    P2262 Turbo Boost Press Not Detected-Mechanical
    P2263 T/S Charger Boost Sys Perf
    P2264 Water in Fuel Sensor Circ
    P2265 Water in Fuel Sensor Circ Range/Perf
    P2266 Water in Fuel Sensor Circ Low
    P2267 Water in Fuel Sensor Circ High
    P2268 Water in Fuel Sensor Circ Interm
    P2269 Water in Fuel Condition
    P2270 O2 Sensor Signal Stuck Lean Bank1 Sensor 2
    P2271 O2 Sensor Signal Stuck Rich Bank1 Sensor 2
    P2272 O2 Sensor Signal Stuck Lean Bank2 Sensor 2
    P2273 O2 Sensor Signal Stuck Rich Bank2 Sensor 2
    P2274 O2 Sensor Signal Stuck Lean Bank1 Sensor 3
    P2275 O2 Sensor Signal Stuck Rich Bank1 Sensor 3
    P2276 O2 Sensor Signal Stuck Lean Bank2 Sensor 3
    P2277 O2 Sensor Signal Stuck Rich Bank2 Sensor 3
    P2278 O2 Sensor Signals Swapped Bank1 Sensor 3 /Bank2 Sensor 3
    P2279 Intake Air Sys Leak
    P2280 Air Flow Restriction / Air Leak Between Air Filter and MAF
    P2281 Air Leak Between MAF and Throttle Body
    P2282 Air Leak Between Throttle Body and Intake Valves
    P2283 Injector Ctrl Press Sensor Circ
    P2284 Injector Ctrl Press Sensor Circ Range/Perf
    P2285 Injector Ctrl Press Sensor Circ Low
    P2286 Injector Ctrl Press Sensor Circ High
    P2287 Injector Ctrl Press Sensor Circ Interm
    P2288 Injector Ctrl Press Too High
    P2289 Injector Ctrl Press Too High-Engine Off
    P2290 Injector Ctrl Press Too Low
    P2291 Injector Ctrl Press Too Low-Engine Cranking
    P2292 Injector Ctrl Press Erratic
    P2293 Fuel Press Reg 2 Perf
    P2294 Fuel Press Reg 2 Ctrl Circ
    P2295 Fuel Press Reg 2 Ctrl Circ Low
    P2296 Fuel Press Reg 2 Ctrl Circ High
    P2297 O2 Sensor Out of Range During Deceleration Bank1 Sensor 1
    P2298 O2 Sensor Out of Range During Deceleration Bank2 Sensor 1
    P2299 Brake Pedal Pos / Accelerator Pedal Pos Incompatible
    P2300 Ignition Coil A Pri Ctrl Circ Low
    P2301 Ignition Coil A Pri Ctrl Circ High
    P2302 Ignition Coil A Sec Circ
    P2303 Ignition Coil B Pri Ctrl Circ Low
    P2304 Ignition Coil B Pri Ctrl Circ High
    P2305 Ignition Coil B Sec Circ
    P2306 Ignition Coil C Pri Ctrl Circ Low
    P2307 Ignition Coil C Pri Ctrl Circ High
    P2308 Ignition Coil C Sec Circ
    P2309 Ignition Coil D Pri Ctrl Circ Low
    P2310 Ignition Coil D Pri Ctrl Circ High
    P2311 Ignition Coil D Sec Circ
    P2312 Ignition Coil E Pri Ctrl Circ Low
    P2313 Ignition Coil E Pri Ctrl Circ High
    P2314 Ignition Coil E Sec Circ
    P2315 Ignition Coil F Pri Ctrl Circ Low
    P2316 Ignition Coil F Pri Ctrl Circ High
    P2317 Ignition Coil F Sec Circ
    P2318 Ignition Coil G Pri Ctrl Circ Low
    P2319 Ignition Coil G Pri Ctrl Circ High
    P2320 Ignition Coil G Sec Circ
    P2321 Ignition Coil H Pri Ctrl Circ Low
    P2322 Ignition Coil H Pri Ctrl Circ High
    P2323 Ignition Coil H Sec Circ
    P2324 Ignition Coil I Pri Ctrl Circ Low
    P2325 Ignition Coil I Pri Ctrl Circ High
    P2326 Ignition Coil I Sec Circ
    P2327 Ignition Coil J Pri Ctrl Circ Low
    P2328 Ignition Coil J Pri Ctrl Circ High
    P2329 Ignition Coil J Sec Circ
    P2330 Ignition Coil K Pri Ctrl Circ Low
    P2331 Ignition Coil K Pri Ctrl Circ High
    P2332 Ignition Coil K Sec Circ
    P2333 Ignition Coil L Pri Ctrl Circ Low
    P2334 Ignition Coil L Pri Ctrl Circ High
    P2335 Ignition Coil L Sec Circ
    P2336 Cylinder #1 Above Knock Threshold
    P2337 Cylinder #2 Above Knock Threshold
    P2338 Cylinder #3 Above Knock Threshold
    P2339 Cylinder #4 Above Knock Threshold
    P2340 Cylinder #5 Above Knock Threshold
    P2341 Cylinder #6 Above Knock Threshold
    P2342 Cylinder #7 Above Knock Threshold
    P2343 Cylinder #8 Above Knock Threshold
    P2344 Cylinder #9 Above Knock Threshold
    P2345 Cylinder #10 Above Knock Threshold
    P2346 Cylinder #11 Above Knock Threshold
    P2347 Cylinder #12 Above Knock Threshold
    P2400 EVAP Leak Detection Pump Ctrl Circ/Open
    P2401 EVAP Leak Detection Pump Ctrl Circ Low
    P2402 EVAP Leak Detection Pump Ctrl Circ High
    P2403 EVAP Leak Detection Pump Sense Circ/Open
    P2404 EVAP Leak Detection Pump Sense Circ Range/Perf
    P2405 EVAP Leak Detection Pump Sense Circ Low
    P2406 EVAP Leak Detection Pump Sense Circ High
    P2407 EVAP Leak Detection Pump Sense Circ Interm/Erratic
    P2408 Fuel Cap Sensor/Switch Circ
    P2409 Fuel Cap Sensor/Switch Circ Range/Perf
    P2410 Fuel Cap Sensor/Switch Circ Low
    P2411 Fuel Cap Sensor/Switch Circ High
    P2412 Fuel Cap Sensor/Switch Circ Interm/Erratic
    P2413 Exhaust Gas Recirculation Sys Perf
    P2414 O2 Sensor Exhaust Sample Error Bank1 Sensor 1
    P2415 O2 Sensor Exhaust Sample Error Bank2 Sensor 1
    P2416 O2 Sensor Signals Swapped Bank1 Sensor 2 /Bank1 Sensor 3
    P2417 O2 Sensor Signals Swapped Bank2 Sensor 2 /Bank2 Sensor 3
    P2418 EVAP Switching Valve Ctrl Circ /Open
    P2419 EVAP Switching Valve Ctrl Circ Low
    P2420 EVAP Switching Valve Ctrl Circ High
    P2421 EVAP Vent Valve Stuck Open
    P2422 EVAP Vent Valve Stuck Closed
    P2423 HC Adsorption Catalyst Efficiency Below Threshold Bank1
    P2424 HC Adsorption Catalyst Efficiency Below Threshold Bank2
    P2425 Exhaust Gas Recirculation Cooling Valve Ctrl Circ/Open
    P2426 Exhaust Gas Recirculation Cooling Valve Ctrl Circ Low
    P2427 Exhaust Gas Recirculation Cooling Valve Ctrl Circ High
    P2428 Exhaust Gas Temp Too High Bank1
    P2429 Exhaust Gas Temp Too High Bank2
    P2430 Sec Air Inj Sys Air Flow/Press Sensor Circ Bank1
    P2431 Sec Air Inj Sys Air Flow/Press Sensor Circ Range/Perf Bank1
    P2432 Sec Air Inj Sys Air Flow/Press Sensor Circ Low Bank1
    P2433 Sec Air Inj Sys Air Flow/Press Sensor Circ High Bank1
    P2434 Sec Air Inj Sys Air Flow/Press Sensor Circ Interm/Erratic Bank1
    P2435 Sec Air Inj Sys Air Flow/Press Sensor Circ Bank2
    P2436 Sec Air Inj Sys Air Flow/Press Sensor Circ Range/Perf Bank2
    P2437 Sec Air Inj Sys Air Flow/Press Sensor Circ Low Bank2
    P2438 Sec Air Inj Sys Air Flow/Press Sensor Circ High Bank2
    P2439 Sec Air Inj Sys Air Flow/Press Sensor Circ Interm/Erratic Bank2
    P2440 Sec Air Inj Sys Switching Valve Stuck Open Bank1
    P2441 Sec Air Inj Sys Switching Valve Stuck Closed Bank1
    P2442 Sec Air Inj Sys Switching Valve Stuck Open Bank2
    P2443 Sec Air Inj Sys Switching Valve Stuck Closed Bank2
    P2444 Sec Air Inj Sys Pump Stuck On Bank1
    P2445 Sec Air Inj Sys Pump Stuck Off Bank1
    P2446 Sec Air Inj Sys Pump Stuck On Bank2
    P2447 Sec Air Inj Sys Pump Stuck Off Bank2
    2004 SILVERADO 1500 5.3, 37X13.5 TOYO MT, 18X9 XD MONSTERS, 6K HIDS, CUSTOM TUNE, AFE CAI, 6" RCX, 3" BL, RCX KICKER BRACES, COGNITO PITMAN AND IDLER SUPPORT BRACKETS, COGNITO UCA, COGNITO LIMIT STRAPS, PROCOMP AAL, TRUETRAC, 4.88 GEARS
    Aug 2007
    Connecticut
    Re: Gm Diagnostic Trouble Codes
    P2500 Generator Lamp/L-Terminal Circ Low
    P2501 Generator Lamp/L-Terminal Circ High
    P2502 Charging Sys Voltage
    P2503 Charging Sys Voltage Low
    P2504 Charging Sys Voltage High
    P2505 ECM/PCM Power Input Signal
    P2506 ECM/PCM Power Input Signal Range/Perf
    P2507 ECM/PCM Power Input Signal Low
    P2508 ECM/PCM Power Input Signal High
    P2509 ECM/PCM Power Input Signal Interm
    P2510 ECM/PCM Power Relay Sense Circ Range/Perf
    P2511 ECM/PCM Power Relay Sense Circ Interm
    P2512 Event Data Recorder Request Circ/ Open
    P2513 Event Data Recorder Request Circ Low
    P2514 Event Data Recorder Request Circ High
    P2515 A/C Refrigerant Press SensorB Circ
    P2516 A/C Refrigerant Press SensorB Circ Range/Perf
    P2517 A/C Refrigerant Press SensorB Circ Low
    P2518 A/C Refrigerant Press SensorB Circ High
    P2519 A/C Request A Circ
    P2520 A/C Request A Circ Low
    P2521 A/C Request A Circ High
    P2522 A/C Request B Circ
    P2523 A/C Request B Circ Low
    P2524 A/C Request B Circ High
    P2525 Vacuum Reservoir Press Sensor Circ
    P2526 Vacuum Reservoir Press Sensor Circ Range/Perf
    P2527 Vacuum Reservoir Press Sensor Circ Low
    P2528 Vacuum Reservoir Press Sensor Circ High
    P2529 Vacuum Reservoir Press Sensor Circ Interm
    P2530 Ignition Switch Run Pos Circ
    P2531 Ignition Switch Run Pos Circ Low
    P2532 Ignition Switch Run Pos Circ High
    P2533 Ignition Switch Run/Start Pos Circ
    P2534 Ignition Switch Run/Start Pos Circ Low
    P2535 Ignition Switch Run/Start Pos Circ High
    P2536 Ignition Switch Accessory Pos Circ
    P2537 Ignition Switch Accessory Pos Circ Low
    P2538 Ignition Switch Accessory Pos Circ High
    P2539 Low Press Fuel Sys Sensor Circ
    P2540 Low Press Fuel Sys Sensor Circ Range/Perf
    P2541 Low Press Fuel Sys Sensor Circ Low
    P2542 Low Press Fuel Sys Sensor Circ High
    P2543 Low Press Fuel Sys Sensor Circ Interm
    P2544 Torque Mgmt Request Input Signal A
    P2545 Torque Mgmt Request Input Signal A Range/Perf
    P2546 Torque Mgmt Request Input Signal A Low
    P2547 Torque Mgmt Request Input Signal A High
    P2548 Torque Mgmt Request Input Signal B
    P2549 Torque Mgmt Request Input Signal B Range/Perf
    P2550 Torque Mgmt Request Input Signal B Low
    P2551 Torque Mgmt Request Input Signal B High
    P2552 Throttle/Fuel Inhibit Circ
    P2553 Throttle/Fuel Inhibit Circ Range/Perf
    P2554 Throttle/Fuel Inhibit Circ Low
    P2555 Throttle/Fuel Inhibit Circ High
    P2556 Engine Coolant Level Sensor/Switch Circ
    P2557 Engine Coolant Level Sensor/Switch Circ Range/Perf
    P2558 Engine Coolant Level Sensor/Switch Circ Low
    P2559 Engine Coolant Level Sensor/Switch Circ High
    P2560 Engine Coolant Level Low
    P2561 A/C Ctrl Mod Requested MIL Illumination
    P2562 Turbocharger Boost Ctrl Pos Sensor Circ
    P2563 Turbocharger Boost Ctrl Pos Sensor Circ Range/Perf
    P2564 Turbocharger Boost Ctrl Pos Sensor Circ Low
    P2565 Turbocharger Boost Ctrl Pos Sensor Circ High
    P2566 Turbocharger Boost Ctrl Pos Sensor Circ Interm
    P2567 Direct Ozone Reduction Catalyst Temp Sensor Circ
    P2568 Direct Ozone Reduction Catalyst Temp Sensor Circ Range/Perf
    P2569 Direct Ozone Reduction Catalyst Temp Sensor Circ Low
    P2570 Direct Ozone Reduction Catalyst Temp Sensor Circ High
    P2571 Direct Ozone Reduction Catalyst Temp Sensor Circ Interm/Erratic
    P2572 Direct Ozone Reduction Catalyst Deterioration Sensor Circ
    P2573 Direct Ozone Reduction Catalyst Deterioration Sensor Circ Range/Perf
    P2574 Direct Ozone Reduction Catalyst Deterioration Sensor Circ Low
    P2575 Direct Ozone Reduction Catalyst Deterioration Sensor Circ High
    P2576 Direct Ozone Reduction Catalyst Deterioration Sensor Circ Interm/Erratic
    P2577 Direct Ozone Reduction Catalyst Efficiency Below Threshold
    P2600 Coolant Pump Ctrl Circ/Open
    P2601 Coolant Pump Ctrl Circ Range/Perf
    P2602 Coolant Pump Ctrl Circ Low
    P2603 Coolant Pump Ctrl Circ High
    P2604 Intake Air Heater A Circ Range/Perf
    P2605 Intake Air Heater A Circ/Open
    P2606 Intake Air Heater B Circ Range/Perf
    P2607 Intake Air Heater B Circ Low
    P2608 Intake Air Heater B Circ High
    P2609 Intake Air Heater Sys Perf
    P2610 ECM/PCM Internal Engine Off Timer Perf
    P2611 A/C Refrigerant Distribution Valve Ctrl Circ/Open
    P2612 A/C Refrigerant Distribution Valve Ctrl Circ Low
    P2613 A/C Refrigerant Distribution Valve Ctrl Circ High
    P2614 Camshaft Pos Signal Output Circ/Open
    P2615 Camshaft Pos Signal Output Circ Low
    P2616 Camshaft Pos Signal Output Circ High
    P2617 Crank Pos Signal Output Circ/Open
    P2618 Crank Pos Signal Output Circ Low
    P2619 Crank Pos Signal Output Circ High
    P2620 Throttle Pos Output Circ/Open
    P2621 Throttle Pos Output Circ Low
    P2622 Throttle Pos Output Circ High
    P2623 Injector Ctrl Press Reg Circ/Open
    P2624 Injector Ctrl Press Reg Circ Low
    P2625 Injector Ctrl Press Reg Circ High
    P2626 O2 Sensor Pumping Current Trim Circ/Open Bank1 Sensor 1
    P2627 O2 Sensor Pumping Current Trim Circ Low Bank1 Sensor 1
    P2628 O2 Sensor Pumping Current Trim Circ High Bank1 Sensor 1
    P2629 O2 Sensor Pumping Current Trim Circ/Open Bank2 Sensor 1
    P2630 O2 Sensor Pumping Current Trim Circ Low Bank2 Sensor 1
    P2631 O2 Sensor Pumping Current Trim Circ High Bank2 Sensor 1
    P2632 Fuel Pump B Ctrl Circ /Open
    P2633 Fuel Pump B Ctrl Circ Low
    P2634 Fuel Pump B Ctrl Circ High
    P2635 Fuel Pump A Low Flow / Perf
    P2636 Fuel Pump B Low Flow / Perf
    P2637 Torque Mgmt Feedback Signal A
    P2638 Torque Mgmt Feedback Signal A Range/Perf
    P2639 Torque Mgmt Feedback Signal A Low
    P2640 Torque Mgmt Feedback Signal A High
    P2641 Torque Mgmt Feedback Signal B
    P2642 Torque Mgmt Feedback Signal B Range/Perf
    P2643 Torque Mgmt Feedback Signal B Low
    P2644 Torque Mgmt Feedback Signal B High
    P2645 A Rocker Arm Actuator Ctrl Circ/Open Bank1
    P2646 A Rocker Arm Actuator Sys Perf or Stuck Off Bank1
    P2647 A Rocker Arm Actuator Sys Stuck On Bank1
    P2648 A Rocker Arm Actuator Ctrl Circ Low Bank1
    P2649 A Rocker Arm Actuator Ctrl Circ High Bank1
    P2650 B Rocker Arm Actuator Ctrl Circ/Open Bank1
    P2651 B Rocker Arm Actuator Sys Perf or Stuck Off Bank1
    P2652 B Rocker Arm Actuator Sys Stuck On Bank1
    P2653 B Rocker Arm Actuator Ctrl Circ Low Bank1
    P2654 B Rocker Arm Actuator Ctrl Circ High Bank1
    P2655 A Rocker Arm Actuator Ctrl Circ/Open Bank2
    P2656 A Rocker Arm Actuator Sys Perf or Stuck Off Bank2
    P2657 A Rocker Arm Actuator Sys Stuck On Bank2
    P2658 A Rocker Arm Actuator Ctrl Circ Low Bank2
    P2659 A Rocker Arm Actuator Ctrl Circ High Bank2
    P2660 B Rocker Arm Actuator Ctrl Circ/Open Bank2
    P2661 B Rocker Arm Actuator Sys Perf or Stuck Off Bank2
    P2662 B Rocker Arm Actuator Sys Stuck On Bank2
    P2663 B Rocker Arm Actuator Ctrl Circ Low Bank2
    P2664 B Rocker Arm Actuator Ctrl Circ High Bank2
    P2665 Fuel Shutoff Valve B Ctrl Circ/Open
    P2666 Fuel Shutoff Valve B Ctrl Circ Low
    P2667 Fuel Shutoff Valve B Ctrl Circ High
    P2668 Fuel Mode Indicator Lamp Ctrl Circ
    P2669 Actuator Supply Voltage B Circ /Open
    P2670 Actuator Supply Voltage B Circ Low
    P2671 Actuator Supply Voltage B Circ High
    P2700 Trans Friction Element A Apply Time Range/Perf
    P2701 Trans Friction Element B Apply Time Range/Perf
    P2702 Trans Friction Element C Apply Time Range/Perf
    P2703 Trans Friction Element D Apply Time Range/Perf
    P2704 Trans Friction Element E Apply Time Range/Perf
    P2705 Trans Friction Element F Apply Time Range/Perf
    P2706 Shift Solenoid F
    P2707 Shift Solenoid F Perf or Stuck Off
    P2708 Shift Solenoid F Stuck On
    P2709 Shift Solenoid F Electrical
    P2710 Shift Solenoid F Interm
    P2711 Unexpected Mechanical Gear Disengagement
    P2712 Hydraulic Power Unit Leakage
    P2713 Press Ctrl Solenoid D
    P2714 Press Ctrl Solenoid D Perf or Stuck Off
    P2715 Press Ctrl Solenoid D Stuck On
    P2716 Press Ctrl Solenoid D Electrical
    P2717 Press Ctrl Solenoid D Interm
    P2718 Press Ctrl Solenoid D Ctrl Circ / Open
    P2719 Press Ctrl Solenoid D Ctrl Circ Range/Perf
    P2720 Press Ctrl Solenoid D Ctrl Circ Low
    P2721 Press Ctrl Solenoid D Ctrl Circ High
    P2722 Press Ctrl Solenoid E
    P2723 Press Ctrl Solenoid E Perf or Stuck Off
    P2724 Press Ctrl Solenoid E Stuck On
    P2725 Press Ctrl Solenoid E Electrical
    P2726 Press Ctrl Solenoid E Interm
    P2727 Press Ctrl Solenoid E Ctrl Circ / Open
    P2728 Press Ctrl Solenoid E Ctrl Circ Range/Perf
    P2729 Press Ctrl Solenoid E Ctrl Circ Low
    P2730 Press Ctrl Solenoid E Ctrl Circ High
    P2731 Press Ctrl Solenoid F
    P2732 Press Ctrl Solenoid F Perf or Stuck Off
    P2733 Press Ctrl Solenoid F Stuck On
    P2734 Press Ctrl Solenoid F Electrical
    P2735 Press Ctrl Solenoid F Interm
    P2736 Press Ctrl Solenoid F Ctrl Circ/Open
    P2737 Press Ctrl Solenoid F Ctrl Circ Range/Perf
    P2738 Press Ctrl Solenoid F Ctrl Circ Low
    P2739 Press Ctrl Solenoid F Ctrl Circ High
    P2740 Trans Fluid Temp SensorB Circ
    P2741 Trans Fluid Temp SensorB Circ Range Perf
    P2742 Trans Fluid Temp SensorB Circ Low
    P2743 Trans Fluid Temp SensorB Circ High
    P2744 Trans Fluid Temp SensorB Circ Interm
    P2745 Intermediate Shaft Speed SensorB Circ
    P2746 Intermediate Shaft Speed SensorB Circ Range/Perf
    P2747 Intermediate Shaft Speed SensorB Circ No Signal
    P2748 Intermediate Shaft Speed SensorB Circ Interm
    P2749 Intermediate Shaft Speed Sensor C Circ
    P2750 Intermediate Shaft Speed Sensor C Circ Range/Perf
    P2751 Intermediate Shaft Speed Sensor C Circ No Signal
    P2752 Intermediate Shaft Speed Sensor C Circ Interm
    P2753 Trans Fluid Cooler Ctrl Circ/Open
    P2754 Trans Fluid Cooler Ctrl Circ Low
    P2755 Trans Fluid Cooler Ctrl Circ High
    P2756 Torq Conv Clutch Press Ctrl Solenoid
    P2757 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ Perf or Stuck Off
    P2758 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ Stuck On
    P2759 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ Electrical
    P2760 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ Interm
    P2761 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ/Open
    P2762 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ Range/Perf
    P2763 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ High
    P2764 Torq Conv Clutch Press Ctrl Solenoid Ctrl Circ Low
    P2765 Input/Turbine Speed SensorB Circ
    P2766 Input/Turbine Speed SensorB Circ Range/Perf
    P2767 Input/Turbine Speed SensorB Circ No Signal
    P2768 Input/Turbine Speed SensorB Circ Interm
    P2769 Torq Conv Clutch Circ Low
    P2770 Torq Conv Clutch Circ High
    P2771 4WD Low Switch Circ
    P2772 4WD Low Switch Circ Range/Perf
    P2773 4WD Low Switch Circ Low
    P2774 4WD Low Switch Circ High
    P2775 Upshift Switch Circ Range/Perf
    P2776 Upshift Switch Circ Low
    P2777 Upshift Switch Circ High
    P2778 Upshift Switch Circ Interm/Erratic
    P2779 Downshift Switch Circ Range/Perf
    P2780 Downshift Switch Circ Low
    P2781 Downshift Switch Circ High
    P2782 Downshift Switch Circ Interm/Erratic
    P2783 Torq Conv Temp Too High
    P2784 Input/Turbine Speed SensorA/B Correlation
    P2785 Clutch Actuator Temp Too High
    P2786 Gear Shift Actuator Temp Too High
    P2787 Clutch Temp Too High
    P2788 Auto Shift Manual Adaptive Learning at Limit
    P2789 Clutch Adaptive Learning at Limit
    P2790 Gate Select Direction Circ
    P2791 Gate Select Direction Circ Low
    P2792 Gate Select Direction Circ High
    P2793 Gear Shift Direction Circ
    P2794 Gear Shift Direction Circ Low
    P2795 Gear Shift Direction Circ High
    Aug 2007
    Connecticut
    P2A00 O2 Sensor Circ Range/Perf Bank1 Sensor 1
    P2A01 O2 Sensor Circ Range/Perf Bank1 Sensor 2
    P2A02 O2 Sensor Circ Range/Perf Bank1 Sensor 3
    P2A03 O2 Sensor Circ Range/Perf Bank2 Sensor 1
    P2A04 O2 Sensor Circ Range/Perf Bank2 Sensor 2
    P2A05 O2 Sensor Circ Range/Perf Bank2 Sensor 3
    P3400 Cylinder Deactivation Sys Bank1
    P3401 Cyl1 Deactivation/Intake Valve Ctrl Circ/Open
    P3402 Cyl1 Deactivation/Intake Valve Ctrl Perf
    P3403 Cyl1 Deactivation/Intake Valve Ctrl Circ Low
    P3404 Cyl1 Deactivation/Intake Valve Ctrl Circ High
    P3405 Cyl1 Exhaust Valve Ctrl Circ/Open
    P3406 Cyl1 Exhaust Valve Ctrl Perf
    P3407 Cyl1 Exhaust Valve Ctrl Circ Low
    P3408 Cyl1 Exhaust Valve Ctrl Circ High
    P3409 Cyl2 Deactivation/Intake Valve Ctrl Circ/Open
    P3410 Cyl2 Deactivation/Intake Valve Ctrl Perf
    P3411 Cyl2 Deactivation/Intake Valve Ctrl Circ Low
    P3412 Cyl2 Deactivation/Intake Valve Ctrl Circ High
    P3413 Cyl2 Exhaust Valve Ctrl Circ/Open
    P3414 Cyl2 Exhaust Valve Ctrl Perf
    P3415 Cyl2 Exhaust Valve Ctrl Circ Low
    P3416 Cyl2 Exhaust Valve Ctrl Circ High
    P3417 Cyl3 Deactivation/Intake Valve Ctrl Circ/Open
    P3418 Cyl3 Deactivation/Intake Valve Ctrl Perf
    P3419 Cyl3 Deactivation/Intake Valve Ctrl Circ Low
    P3420 Cyl3 Deactivation/Intake Valve Ctrl Circ High
    P3421 Cyl3 Exhaust Valve Ctrl Circ/Open
    P3422 Cyl3 Exhaust Valve Ctrl Perf
    P3423 Cyl3 Exhaust Valve Ctrl Circ Low
    P3424 Cyl3 Exhaust Valve Ctrl Circ High
    P3425 Cyl4 Deactivation/Intake Valve Ctrl Circ/Open
    P3426 Cyl4 Deactivation/Intake Valve Ctrl Perf
    P3427 Cyl4 Deactivation/Intake Valve Ctrl Circ Low
    P3428 Cyl4 Deactivation/Intake Valve Ctrl Circ High
    P3429 Cyl4 Exhaust Valve Ctrl Circ/Open
    P3430 Cyl4 Exhaust Valve Ctrl Perf
    P3431 Cyl4 Exhaust Valve Ctrl Circ Low
    P3432 Cyl4 Exhaust Valve Ctrl Circ High
    P3433 Cyl5 Deactivation/Intake Valve Ctrl Circ/Open
    P3434 Cyl5 Deactivation/Intake Valve Ctrl Perf
    P3435 Cyl5 Deactivation/Intake Valve Ctrl Circ Low
    P3436 Cyl5 Deactivation/Intake Valve Ctrl Circ High
    P3437 Cyl5 Exhaust Valve Ctrl Circ/Open
    P3438 Cyl5 Exhaust Valve Ctrl Perf
    P3439 Cyl5 Exhaust Valve Ctrl Circ Low
    P3440 Cyl5 Exhaust Valve Ctrl Circ High
    P3441 Cyl6 Deactivation/Intake Valve Ctrl Circ/Open
    P3442 Cyl6 Deactivation/Intake Valve Ctrl Perf
    P3443 Cyl6 Deactivation/Intake Valve Ctrl Circ Low
    P3444 Cyl6 Deactivation/Intake Valve Ctrl Circ High
    P3445 Cyl6 Exhaust Valve Ctrl Circ/Open
    P3446 Cyl6 Exhaust Valve Ctrl Perf
    P3447 Cyl6 Exhaust Valve Ctrl Circ Low
    P3448 Cyl6 Exhaust Valve Ctrl Circ High
    P3449 Cyl7 Deactivation/Intake Valve Ctrl Circ/Open
    P3450 Cyl7 Deactivation/Intake Valve Ctrl Perf
    P3451 Cyl7 Deactivation/Intake Valve Ctrl Circ Low
    P3452 Cyl7 Deactivation/Intake Valve Ctrl Circ High
    P3453 Cyl7 Exhaust Valve Ctrl Circ/Open
    P3454 Cyl7 Exhaust Valve Ctrl Perf
    P3455 Cyl7 Exhaust Valve Ctrl Circ Low
    P3456 Cyl7 Exhaust Valve Ctrl Circ High
    P3457 Cyl8 Deactivation/Intake Valve Ctrl Circ/Open
    P3458 Cyl8 Deactivation/Intake Valve Ctrl Perf
    P3459 Cyl8 Deactivation/Intake Valve Ctrl Circ Low
    P3460 Cyl8 Deactivation/Intake Valve Ctrl Circ High
    P3461 Cyl8 Exhaust Valve Ctrl Circ/Open
    P3462 Cyl8 Exhaust Valve Ctrl Perf
    P3463 Cyl8 Exhaust Valve Ctrl Circ Low
    P3464 Cyl8 Exhaust Valve Ctrl Circ High
    P3465 Cyl9 Deactivation/Intake Valve Ctrl Circ/Open
    P3466 Cyl9 Deactivation/Intake Valve Ctrl Perf
    P3467 Cyl9 Deactivation/Intake Valve Ctrl Circ Low
    P3468 Cyl9 Deactivation/Intake Valve Ctrl Circ High
    P3469 Cyl9 Exhaust Valve Ctrl Circ/Open
    P3470 Cyl9 Exhaust Valve Ctrl Perf
    P3471 Cyl9 Exhaust Valve Ctrl Circ Low
    P3472 Cyl9 Exhaust Valve Ctrl Circ High
    P3473 Cyl10 Deactivation/Intake Valve Ctrl Circ/Open
    P3474 Cyl10 Deactivation/Intake Valve Ctrl Perf
    P3475 Cyl10 Deactivation/Intake Valve Ctrl Circ Low
    P3476 Cyl10 Deactivation/Intake Valve Ctrl Circ High
    P3477 Cyl10 Exhaust Valve Ctrl Circ/Open
    P3478 Cyl10 Exhaust Valve Ctrl Perf
    P3479 Cyl10 Exhaust Valve Ctrl Circ Low
    P3480 Cyl10 Exhaust Valve Ctrl Circ High
    P3481 Cyl11 Deactivation/Intake Valve Ctrl Circ/Open
    P3482 Cyl11 Deactivation/Intake Valve Ctrl Perf
    P3483 Cyl11 Deactivation/Intake Valve Ctrl Circ Low
    P3484 Cyl11 Deactivation/Intake Valve Ctrl Circ High
    P3485 Cyl11 Exhaust Valve Ctrl Circ/Open
    P3486 Cyl11 Exhaust Valve Ctrl Perf
    P3487 Cyl11 Exhaust Valve Ctrl Circ Low
    P3488 Cyl11 Exhaust Valve Ctrl Circ High
    P3489 Cyl12 Deactivation/Intake Valve Ctrl Circ/Open
    P3490 Cyl12 Deactivation/Intake Valve Ctrl Perf
    P3491 Cyl12 Deactivation/Intake Valve Ctrl Circ Low
    P3492 Cyl12 Deactivation/Intake Valve Ctrl Circ High
    P3493 Cyl12 Exhaust Valve Ctrl Circ/Open
    U0001 High Speed CAN Comm Bus
    U0002 High Speed CAN Comm Bus Perf
    U0003 High Speed CAN Comm Bus + Open
    U0004 High Speed CAN Comm Bus + Low
    U0005 High Speed CAN Comm Bus + High
    U0006 High Speed CAN Comm Bus - Open
    U0007 High Speed CAN Comm Bus - Low
    U0008 High Speed CAN Comm Bus - High
    U0009 High Speed CAN Comm Bus - shorted to Bus +
    U0010 Med Speed CAN Comm Bus
    U0011 Med Speed CAN Comm Bus Perf
    U0012 Med Speed CAN Comm Bus + Open
    U0013 Med Speed CAN Comm Bus + Low
    U0014 Med Speed CAN Comm Bus + High
    U0015 Med Speed CAN Comm Bus - Open
    U0016 Med Speed CAN Comm Bus - Low
    U0017 Med Speed CAN Comm Bus - High
    U0018 Med Speed CAN Comm Bus - shorted to Bus +
    U0019 Low Speed CAN Comm Bus
    U0020 Low Speed CAN Comm Bus Perf
    U0021 Low Speed CAN Comm Bus + Open
    U0022 Low Speed CAN Comm Bus + Low
    U0023 Low Speed CAN Comm Bus + High
    U0024 Low Speed CAN Comm Bus - Open
    U0025 Low Speed CAN Comm Bus - Low
    U0026 Low Speed CAN Comm Bus - High
    U0027 Low Speed CAN Comm Bus - shorted to Bus +
    U0028 Vehicle Comm Bus A
    U0029 Vehicle Comm Bus A Perf
    U0030 Vehicle Comm Bus A + Open
    U0031 Vehicle Comm Bus A + Low
    U0032 Vehicle Comm Bus A + High
    U0033 Vehicle Comm Bus A - Open
    U0034 Vehicle Comm Bus A - Low
    U0035 Vehicle Comm Bus A - High
    U0036 Vehicle Comm Bus A - shorted to Bus A +
    U0037 Vehicle Comm Bus B
    U0038 Vehicle Comm Bus B Perf
    U0039 Vehicle Comm Bus B + Open
    U0040 Vehicle Comm Bus B + Low
    U0041 Vehicle Comm Bus B + High
    U0042 Vehicle Comm Bus B - Open
    U0043 Vehicle Comm Bus B - Low
    U0044 Vehicle Comm Bus B - High
    U0045 Vehicle Comm Bus B - shorted to Bus B +
    U0046 Vehicle Comm Bus C
    U0047 Vehicle Comm Bus C Perf
    U0048 Vehicle Comm Bus C + Open
    U0049 Vehicle Comm Bus C + Low
    U0050 Vehicle Comm Bus C + High
    U0051 Vehicle Comm Bus C - Open
    U0052 Vehicle Comm Bus C - Low
    U0053 Vehicle Comm Bus C - High
    U0054 Vehicle Comm Bus C - shorted to Bus C +
    U0055 Vehicle Comm Bus D
    U0056 Vehicle Comm Bus D Perf
    U0057 Vehicle Comm Bus D + Open
    U0058 Vehicle Comm Bus D + Low
    U0059 Vehicle Comm Bus D + High
    U0060 Vehicle Comm Bus D - Open
    U0061 Vehicle Comm Bus D - Low
    U0062 Vehicle Comm Bus D - High
    U0063 Vehicle Comm Bus D - shorted to Bus D +
    U0064 Vehicle Comm Bus E
    U0065 Vehicle Comm Bus E Perf
    U0066 Vehicle Comm Bus E + Open
    U0067 Vehicle Comm Bus E + Low
    U0068 Vehicle Comm Bus E + High
    U0069 Vehicle Comm Bus E - Open
    U0070 Vehicle Comm Bus E - Low
    U0071 Vehicle Comm Bus E - High
    U0072 Vehicle Comm Bus E - shorted to Bus E +
    U0073 Ctrl Mod Comm Bus Off
    U0100 Lost Comm With ECM/PCM A
    U0101 Lost Comm with TCM
    U0102 Lost Comm with Transfer Case Ctrl Mod
    U0103 Lost Comm With Gear Shift Mod
    U0104 Lost Comm With Cruise Ctrl Mod
    U0105 Lost Comm With Fuel Injector Ctrl Mod
    U0106 Lost Comm With Glow Plug Ctrl Mod
    U0107 Lost Comm With Throttle Actuator Ctrl Mod
    U0108 Lost Comm With Alternative Fuel Ctrl Mod
    U0109 Lost Comm With Fuel Pump Ctrl Mod
    U0110 Lost Comm With Drive Motor Ctrl Mod
    U0111 Lost Comm With Battery Energy Ctrl Mod A
    U0112 Lost Comm With Battery Energy Ctrl Mod B
    U0113 Lost Comm With Emissions Critical Ctrl Information
    U0114 Lost Comm With 4WD Clutch Ctrl Mod
    U0115 Lost Comm With ECM/PCM B
    U0121 Lost Comm With Anti-Lock Brake Sys (ABS) Ctrl Mod
    U0122 Lost Comm With Vehicle Dynamics Ctrl Mod
    U0123 Lost Comm With Yaw Rate Sensor Mod
    U0124 Lost Comm With Lateral Acceleration Sensor Mod
    U0125 Lost Comm With Multi-axis Acceleration Sensor Mod
    U0126 Lost Comm With Steering Angle Sensor Mod
    U0127 Lost Comm With Tire Press Monitor Mod
    U0128 Lost Comm With Park Brake Ctrl Mod
    U0129 Lost Comm With Brake Sys Ctrl Mod
    U0130 Lost Comm With Steering Effort Ctrl Mod
    U0131 Lost Comm With Power Steering Ctrl Mod
    U0132 Lost Comm With Ride Level Ctrl Mod
    U0140 Lost Comm With Body Ctrl Mod
    U0141 Lost Comm With Body Ctrl Mod A
    U0142 Lost Comm With Body Ctrl Mod B
    U0143 Lost Comm With Body Ctrl Mod C
    U0144 Lost Comm With Body Ctrl Mod D
    U0145 Lost Comm With Body Ctrl Mod E
    U0146 Lost Comm With Gateway A
    U0147 Lost Comm With Gateway B
    U0148 Lost Comm With Gateway C
    U0149 Lost Comm With Gateway D
    U0150 Lost Comm With Gateway E
    U0151 Lost Comm With Restraints Ctrl Mod
    U0152 Lost Comm With Side Restraints Ctrl Mod Left
    U0153 Lost Comm With Side Restraints Ctrl Mod Right
    U0154 Lost Comm With Restraints Occupant Sensing Ctrl Mod
    U0155 Lost Comm With Instr Panel Cluster (IPC) Ctrl Mod
    U0156 Lost Comm With Information Center A
    U0157 Lost Comm With Information Center B
    U0158 Lost Comm With Head Up Display
    U0159 Lost Comm With Parking Assist Ctrl Mod
    U0160 Lost Comm With Audible Alert Ctrl Mod
    U0161 Lost Comm With Compass Mod
    U0162 Lost Comm With Navigation Display Mod
    U0163 Lost Comm With Navigation Ctrl Mod
    U0164 Lost Comm With HVAC Ctrl Mod
    U0165 Lost Comm With HVAC Ctrl Mod Rear
    U0166 Lost Comm With Auxiliary Heater Ctrl Mod
    U0167 Lost Comm With Vehicle Immobilizer Ctrl Mod
    U0168 Lost Comm With Vehicle Security Ctrl Mod
    U0169 Lost Comm With Sunroof Ctrl Mod
    U0170 Lost Comm With Restraints Sys SensorA
    U0171 Lost Comm With Restraints Sys SensorB
    U0172 Lost Comm With Restraints Sys Sensor C
    U0173 Lost Comm With Restraints Sys Sensor D
    U0174 Lost Comm With Restraints Sys Sensor E
    U0175 Lost Comm With Restraints Sys Sensor F
    U0176 Lost Comm With Restraints Sys Sensor G
    U0177 Lost Comm With Restraints Sys Sensor H
    U0178 Lost Comm With Restraints Sys Sensor I
    U0179 Lost Comm With Restraints Sys Sensor J
    U0180 Lost Comm With Automatic Lighting Ctrl Mod
    U0181 Lost Comm With Headlamp Leveling Ctrl Mod
    U0182 Lost Comm With Lighting Ctrl Mod Front
    U0183 Lost Comm With Lighting Ctrl Mod Rear
    U0184 Lost Comm With Radio
    U0185 Lost Comm With Antenna Ctrl Mod
    U0186 Lost Comm With Audio Amplifier
    U0187 Lost Comm With Digital Disc Player/Changer Mod A
    U0188 Lost Comm With Digital Disc Player/Changer Mod B
    U0189 Lost Comm With Digital Disc Player/Changer Mod C
    U0190 Lost Comm With Digital Disc Player/Changer Mod D
    U0191 Lost Comm With Television
    U0192 Lost Comm With Personal Computer
    U0193 Lost Comm With Digital Audio Ctrl Mod A
    U0194 Lost Comm With Digital Audio Ctrl Mod B
    U0195 Lost Comm With Subscription Entertainment Receiver Mod
    U0196 Lost Comm With Rear Seat Entertainment Ctrl Mod
    U0197 Lost Comm With Telephone Ctrl Mod
    U0198 Lost Comm With Telematic Ctrl Mod
    U0199 Lost Comm With Door Ctrl Mod A
    U0200 Lost Comm With Door Ctrl Mod B
    U0201 Lost Comm With Door Ctrl Mod C
    U0202 Lost Comm With Door Ctrl Mod D
    U0203 Lost Comm With Door Ctrl Mod E
    U0204 Lost Comm With Door Ctrl Mod F
    U0205 Lost Comm With Door Ctrl Mod G
    U0206 Lost Comm With Folding Top Ctrl Mod
    U0207 Lost Comm With Moveable Roof Ctrl Mod
    U0208 Lost Comm With Seat Ctrl Mod A
    U0209 Lost Comm With Seat Ctrl Mod B
    U0210 Lost Comm With Seat Ctrl Mod C
    U0211 Lost Comm With Seat Ctrl Mod D
    U0212 Lost Comm With Steering Column Ctrl Mod
    U0213 Lost Comm With Mirror Ctrl Mod
    U0214 Lost Comm With Remote Func Actuation
    U0215 Lost Comm With Door Switch A
    U0216 Lost Comm With Door Switch B
    U0217 Lost Comm With Door Switch C
    U0218 Lost Comm With Door Switch D
    U0219 Lost Comm With Door Switch E
    U0220 Lost Comm With Door Switch F
    U0221 Lost Comm With Door Switch G
    U0222 Lost Comm With Door Window Motor A
    U0223 Lost Comm With Door Window Motor B
    U0224 Lost Comm With Door Window Motor C
    U0225 Lost Comm With Door Window Motor D
    U0226 Lost Comm With Door Window Motor E
    U0227 Lost Comm With Door Window Motor F
    U0228 Lost Comm With Door Window Motor G
    U0229 Lost Comm With Heated Steering Wheel Mod
    U0230 Lost Comm With Rear Gate Mod
    U0231 Lost Comm With Rain Sensing Mod
    U0232 Lost Comm With Side Obstacle Detection Ctrl Mod Left
    U0233 Lost Comm With Side Obstacle Detection Ctrl Mod Right
    U0234 Lost Comm With Convenience Recall Mod
    U0235 Lost Comm With Cruise Ctrl Front Distance Range Sensor
    U0300 Internal Ctrl Mod Software Incompatibility
    U0301 Software Incompatibility with ECM/PCM
    U0302 Software Incompatibility with Trans Ctrl Mod
    U0303 Software Incompatibility with Transfer Case Ctrl Mod
    U0304 Software Incompatibility with Gear Shift Ctrl Mod
    U0305 Software Incompatibility with Cruise Ctrl Mod
    U0306 Software Incompatibility with Fuel Injector Ctrl Mod
    U0307 Software Incompatibility with Glow Plug Ctrl Mod
    U0308 Software Incompatibility with Throttle Actuator Ctrl Mod
    U0309 Software Incompatibility with Alternative Fuel Ctrl Mod
    U0310 Software Incompatibility with Fuel Pump Ctrl Mod
    U0311 Software Incompatibility with Drive Motor Ctrl Mod
    U0312 Software Incompatibility with Battery Energy Ctrl Mod A
    U0313 Software Incompatibility with Battery Energy Ctrl Mod B
    U0314 Software Incompatibility with 4WD Clutch Ctrl Mod
    U0315 Software Incompatibility with Anti-Lock Brake Sys Ctrl Mod
    U0316 Software Incompatibility with Vehicle Dynamics Ctrl Mod
    U0317 Software Incompatibility with Park Brake Ctrl Mod
    U0318 Software Incompatibility with Brake Sys Ctrl Mod
    U0319 Software Incompatibility with Steering Effort Ctrl Mod
    U0320 Software Incompatibility with Power Steering Ctrl Mod
    U0321 Software Incompatibility with Ride Level Ctrl Mod
    U0322 Software Incompatibility with Body Ctrl Mod
    U0323 Software Incompatibility with Instr Panel Ctrl Mod
    U0324 Software Incompatibility with HVAC Ctrl Mod
    U0325 Software Incompatibility with Auxiliary Heater Ctrl Mod
    U0326 Software Incompatibility with Vehicle Immobilizer Ctrl Mod
    U0327 Software Incompatibility with Vehicle Security Ctrl Mod
    U0328 Software Incompatibility with Steering Angle Sensor Mod
    U0329 Software Incompatibility with Steering Column Ctrl Mod
    U0330 Software Incompatibility with Tire Press Monitor Mod
    U0331 Software Incompatibility with Body Ctrl Mod A
    U0400 Invalid Data
    U0401 Invalid Data From ECM/PCM
    U0402 Invalid Data From Trans Ctrl Mod
    U0403 Invalid Data From Transfer Case Ctrl Mod
    U0404 Invalid Data From Gear Shift Ctrl Mod
    U0405 Invalid Data From Cruise Ctrl Mod
    U0406 Invalid Data From Fuel Injector Ctrl Mod
    U0407 Invalid Data From Glow Plug Ctrl Mod
    U0408 Invalid Data From Throttle Actuator Ctrl Mod
    U0409 Invalid Data From Alternative Fuel Ctrl Mod
    U0410 Invalid Data From Fuel Pump Ctrl Mod
    U0411 Invalid Data From Drive Motor Ctrl Mod
    U0412 Invalid Data From Battery Energy Ctrl Mod A
    U0413 Invalid Data From Battery Energy Ctrl Mod B
    U0414 Invalid Data From 4WD Clutch Ctrl Mod
    U0415 Invalid Data From Anti-Lock Brake Sys Ctrl Mod
    U0416 Invalid Data From Vehicle Dynamics Ctrl Mod
    U0417 Invalid Data From Park Brake Ctrl Mod
    U0418 Invalid Data From Brake Sys Ctrl Mod
    U0419 Invalid Data From Steering Effort Ctrl Mod
    U0420 Invalid Data From Power Steering Ctrl Mod
    U0421 Invalid Data From Ride Level Ctrl Mod
    U0422 Invalid Data From Body Ctrl Mod
    U0423 Invalid Data From Instr Panel Ctrl Mod
    U0424 Invalid Data From HVAC Ctrl Mod
    U0425 Invalid Data From Auxiliary Heater Ctrl Mod
    U0426 Invalid Data From Vehicle Immobilizer Ctrl Mod
    U0427 Invalid Data From Vehicle Security Ctrl Mod
    U0428 Invalid Data From Steering Angle Sensor Mod
    U0429 Invalid Data From Steering Column Ctrl Mod
    U0430 Invalid Data From Tire Press Monitor Mod
    U0431 Invalid Data From Body Ctrl Mod A
    Aug 2007
    Connecticut
    DTC U1000 Class 2 Communication Malfunction
    DTC U1001-U1254 Loss of XXX Communications
    DTC U1002 Loss of serial communications for class 2 devices
    DTC U1003 Loss of serial communications for class 2 devices
    DTC U1004 Loss of serial communications for class 2 devices
    DTC U1005 Loss of serial communications for class 2 devices
    DTC U1006 Loss of serial communications for class 2 devices
    DTC U1007 Loss of serial communications for class 2 devices
    DTC U1008 Loss of serial communications for class 2 devices
    DTC U1009 Loss of serial communications for class 2 devices
    DTC U1010 Loss of serial communications for class 2 devices
    DTC U1011 Loss of serial communications for class 2 devices
    DTC U1012 Loss of serial communications for class 2 devices
    DTC U1013 Loss of serial communications for class 2 devices
    DTC U1014 Loss of serial communications for class 2 devices
    DTC U1015 Loss of serial communications for class 2 devices
    DTC U1016 Loss of Class 2 Communication with VCM
    DTC U1016 Loss of Communications with PCM
    DTC U1017 Loss of serial communications for class 2 devices
    DTC U1018 Loss of serial communications for class 2 devices
    DTC U1019 Loss of serial communications for class 2 devices
    DTC U1020 Loss of serial communications for class 2 devices
    DTC U1021 Loss of serial communications for class 2 devices
    DTC U1022 Loss of serial communications for class 2 devices
    DTC U1023 Loss of serial communications for class 2 devices
    DTC U1024 Loss of serial communications for class 2 devices
    DTC U1025 Loss of serial communications for class 2 devices
    DTC U1026 Loss of ATC Class 2 Communication
    DTC U1027 Loss of serial communications for class 2 devices
    DTC U1028 Loss of serial communications for class 2 devices
    DTC U1029 Loss of serial communications for class 2 devices
    DTC U1030 Loss of serial communications for class 2 devices
    DTC U1031 Loss of serial communications for class 2 devices
    DTC U1032 Loss of serial communications for class 2 devices
    DTC U1033 Loss of serial communications for class 2 devices
    DTC U1034 Loss of serial communications for class 2 devices
    DTC U1035 Loss of serial communications for class 2 devices
    DTC U1036 Loss of serial communications for class 2 devices
    DTC U1037 Loss of serial communications for class 2 devices
    DTC U1038 Loss of Serial Communications for Class 2 Devices
    DTC U1039 Loss of Serial Communications for Class 2 Devices
    DTC U1040 Loss of Class 2 Communications with ABS
    DTC U1041 Loss of EBCM Communication
    DTC U1042 Lost Communications with Brake/Traction Control System
    DTC U1043 Loss of Serial Communications for Class 2 Devices
    DTC U1044 Loss of Serial Communications for Class 2 Devices
    DTC U1045 Loss of Serial Communications for Class 2 Devices
    DTC U1046 Loss of Serial Communications for Class 2 Devices
    DTC U1047 Loss of Serial Communications for Class 2 Devices
    DTC U1048 Loss of Serial Communications for Class 2 Devices
    DTC U1049 Loss of Serial Communications for Class 2 Devices
    DTC U1050 Loss of Serial Communications for Class 2 Devices
    DTC U1051 Loss of Serial Communications for Class 2 Devices
    DTC U1052 Loss of Serial Communications for Class 2 Devices
    DTC U1053 Loss of Serial Communications for Class 2 Devices
    DTC U1054 Loss of Serial Communications for Class 2 Devices
    DTC U1055 Loss of Serial Communications for Class 2 Devices
    DTC U1056 Loss of Communications with RSS
    DTC U1057 Loss of Serial Communications for Class 2 Devices
    DTC U1058 Loss of Serial Communications for Class 2 Devices
    DTC U1059 Loss of Serial Communications for Class 2 Devices
    DTC U1060 Loss of Serial Communications for Class 2 Devices
    DTC U1161 Loss of PDM Serial Data
    DTC U1062 Loss of Serial Communications for Class 2 Devices
    DTC U1163 Loss of RRDM Serial Data
    DTC U1064 Loss of Communications with DIM
    DTC U1065 Loss of Communications with IPM
    DTC U1066 Loss of Communications with RIM
    DTC U1067 Loss of Serial Communications for Class 2 Devices
    DTC U1068 Loss of Serial Communications for Class 2 Devices
    DTC U1069 Loss of Serial Communications for Class 2 Devices
    DTC U1170 Loss of Driver Door Sw Asm Serial Data
    DTC U1071 Loss of Serial Communications for Class 2 Devices
    DTC U1072 Loss of Serial Communications for Class 2 Devices
    DTC U1073 Loss of Serial Communications for Class 2 Devices
    DTC U1074 Loss of Serial Communications for Class 2 Devices
    DTC U1075 Loss of Serial Communications for Class 2 Devices
    DTC U1076 Loss of Serial Communications for Class 2 Devices
    DTC U1077 Loss of Serial Communications for Class 2 Devices
    DTC U1078 Loss of Serial Communications for Class 2 Devices
    DTC U1079 Loss of Serial Communications for Class 2 Devices
    DTC U1080 Loss of Serial Communications for Class 2 Devices
    DTC U1081 Loss of Serial Communications for Class 2 Devices
    DTC U1082 Loss of Serial Communications for Class 2 Devices
    DTC U1083 Loss of Serial Communications for Class 2 Devices
    DTC U1084 Loss of Serial Communications for Class 2 Devices
    DTC U1085 Loss of Serial Communications for Class 2 Devices
    DTC U1086 Loss of Serial Communications for Class 2 Devices
    DTC U1087 Loss of Serial Communications for Class 2 Devices
    DTC U1088 Loss of Communications with SDM
    DTC U1089 Loss of Serial Communications for Class 2 Devices
    DTC U1090 Loss of Serial Communications for Class 2 Devices
    DTC U1091 Loss of Serial Communications for Class 2 Devices
    DTC U1092 Loss of Serial Communications for Class 2 Devices
    DTC U1093 Loss of Serial Communications for Class 2 Devices
    DTC U1094 Loss of Serial Communications for Class 2 Devices
    DTC U1095 Loss of Serial Communications for Class 2 Devices
    DTC U1096 Loss of Communications with IPC
    DTC U1097 Loss of Serial Communications for Class 2 Devices
    DTC U1098 Loss of Serial Communications for Class 2 Devices
    DTC U1099 Loss of Serial Communications for Class 2 Devices
    DTC U1100 Loss of Serial Communications for Class 2 Devices
    DTC U1101 Loss of Serial Communications for Class 2 Devices
    DTC U1102 Loss of Serial Communications for Class 2 Devices
    DTC U1103 Loss of Serial Communications for Class 2 Devices
    DTC U1104 Loss of Serial Communications for Class 2 Devices
    DTC U1105 Loss of Serial Communications for Class 2 Devices
    DTC U1106 Loss of Serial Communications for Class 2 Devices
    DTC U1107 Loss of Serial Communications for Class 2 Devices
    DTC U1108 Loss of Serial Communications for Class 2 Devices
    DTC U1109 Loss of Serial Communications for Class 2 Devices
    DTC U1110 Loss of Serial Communications for Class 2 Devices
    DTC U1111 Loss of Serial Communications for Class 2 Devices
    DTC U1112 Loss of Serial Communications for Class 2 Devices
    DTC U1113 Loss of Serial Communications for Class 2 Devices
    DTC U1114 Loss of Serial Communications for Class 2 Devices
    DTC U1115 Loss of Serial Communications for Class 2 Devices
    DTC U1116 Loss of Serial Communications for Class 2 Devices
    DTC U1117 Loss of Serial Communications for Class 2 Devices
    DTC U1118 Loss of Serial Communications for Class 2 Devices
    DTC U1119 Loss of Serial Communications for Class 2 Devices
    DTC U1120 Loss of Serial Communications for Class 2 Devices
    DTC U1121 Loss of Serial Communications for Class 2 Devices
    DTC U1122 Loss of Serial Communications for Class 2 Devices
    DTC U1123 Loss of serial communications for class 2 devices
    DTC U1124 Loss of serial communications for class 2 devices
    DTC U1125 Loss of serial communications for class 2 devices
    DTC U1126 Loss of serial communications for class 2 devices
    DTC U1127 Loss of serial communications for class 2 devices
    DTC U1128 Loss of Communications with IRC
    DTC U1129 Loss of Communications with AMP
    DTC U1130 Loss of serial communications for class 2 devices
    DTC U1131 Loss of serial communications for class 2 devices
    DTC U1132 Loss of serial communications for class 2 devices
    DTC U1133 Loss of serial communications for class 2 devices
    DTC U1134 Loss of serial communications for class 2 devices
    DTC U1135 Loss of serial communications for class 2 devices
    DTC U1136 Loss of serial communications for class 2 devices
    DTC U1137 Loss of serial communications for class 2 devices
    DTC U1138 Loss of serial communications for class 2 devices
    DTC U1139 Loss of serial communications for class 2 devices
    DTC U1140 Loss of serial communications for class 2 devices
    DTC U1141 Loss of serial communications for class 2 devices
    DTC U1142 Loss of serial communications for class 2 devices
    DTC U1143 Loss of serial communications for class 2 devices
    DTC U1144 Loss of Communications with PHN
    DTC U1145 Loss Of NAV Communications
    DTC U1146 Loss Of Onstar Communiction
    DTC U1147 Loss of serial communications for class 2 devices
    DTC U1148 Loss of serial communications for class 2 devices
    DTC U1149 Loss of serial communications for class 2 devices
    DTC U1150 Loss of serial communications for class 2 devices
    DTC U1151 Loss of serial communications for class 2 devices
    DTC U1152 Loss Of ACM Serial Data Communication
    DTC U1152 Loss of Data HCM
    DTC U1153 Loss of Communications with CCP
    DTC U1154 Loss of serial communications for class 2 devices
    DTC U1155 Loss of serial communications for class 2 devices
    DTC U1156 Loss of serial communications for class 2 devices
    DTC U1157 Loss of serial communications for class 2
    DTC U1158 Loss of serial communications for class 2 devices
    DTC U1159 Loss of serial communications for class 2 devices
    DTC U1160 Loss of Communications with DDM
    DTC U1161 Loss of PASS Door Module SBI
    DTC U1162 Loss of Rear Driver Door Module SBI
    DTC U1163 Loss of Rear PASS Door Module SBI
    DTC U1164 Loss Of DIM Serial Data Communication
    DTC U1165 Loss of serial communications for class 2 devices
    DTC U1166 Loss of Communications with SCM
    DTC U1167 Loss of serial communications for class 2 devices
    DTC U1168 Loss Of TTM Communications
    DTC U1169 Loss of Communications with MMM
    DTC U1170 Loss of Driver Door Switch SBI
    DTC U1171 Loss of serial communications for class 2 devices
    DTC U1172 Loss of serial communications for class 2 devices
    DTC U1173 Loss of serial communications for class 2 devices
    DTC U1174 Loss of serial communications for class 2 devices
    DTC U1175 Loss of serial communications for class 2 devices
    DTC U1176 Loss Of RFA Communications
    DTC U1177 Loss of serial communications for class 2 devices
    DTC U1178 Loss of serial communications for class 2 devices
    DTC U1179 Loss of serial communications for class 2 devices
    DTC U1180 Loss of serial communications for class 2 devices
    DTC U1181 Loss of serial communications for class 2 devices
    DTC U1182 Loss of serial communications for class 2 devices
    DTC U1183 Loss of serial communications for class 2 devices
    DTC U1184 Loss of serial communications for class 2 devices
    DTC U1185 Loss of serial communications for class 2 devices
    DTC U1186 Loss of serial communications for class 2 devices
    DTC U1187 Loss of serial communications for class 2 devices
    DTC U1188 Loss of serial communications for class 2 devices
    DTC U1189 Loss of serial communications for class 2 devices
    DTC U1190 Loss of serial communications for class 2 devices
    DTC U1191 Loss of serial communications for class 2 devices
    DTC U1192 Loss of VTD Class 2 Serial Data Com
    DTC U1193 Loss of VIM Class 2 Communication
    DTC U1194 Loss of serial communications for class 2 devices
    DTC U1195 Loss of serial communications for class 2 devices
    DTC U1196 Loss of serial communications for class 2 devices
    DTC U1197 Loss of serial communications for class 2 devices
    DTC U1198 Loss of serial communications for class 2 devices
    DTC U1199 Loss of serial communications for class 2 devices
    DTC U1200 Loss of serial communications for class 2 devices
    DTC U1201 Loss of serial communications for class 2 devices
    DTC U1202 Loss of serial communications for class 2 devices
    DTC U1203 Loss of serial communications for class 2 devices
    DTC U1204 Loss of serial communications for class 2 devices
    DTC U1205 Loss of serial communications for class 2 devices
    DTC U1206 Loss of serial communications for class 2 devices
    DTC U1207 Loss of serial communications for class 2 devices
    DTC U1208 Loss of serial communications for class 2 devices
    DTC U1209 Loss of serial communications for class 2 devices
    DTC U1210 Loss of serial communications for class 2 devices
    DTC U1215 Loss of serial communications for class 2 devices
    DTC U1220 Loss of serial communications for class 2 devices
    DTC U1225 Loss of serial communications for class 2 devices
    DTC U1230 Loss of serial communications for class 2 devices
    DTC U1235 Loss of serial communications for class 2 devices
    DTC U1240 Loss of serial communications for class 2 devices
    DTC U1245 Loss of serial communications for class 2 devices
    DTC U1250 Loss of serial communications for class 2 devices
    DTC U1251 Loss of serial communications for class 2 devices
    DTC U1252 Loss of serial communications for class 2 devices
    DTC U1253 Loss of serial communications for class 2 devices
    DTC U1254 Loss of serial communications for class 2 devices
    DTC U1255 Class 2 Communication Malfunction
    DTC U1255 Serial Data Line Malfunction
    DTC U1300 Class 2 Short to Ground
    DTC U1301 Class 2 Short to Battery
    DTC U1304 Loss Of UART Communications
    DTC U1305 Class 2 Data Link Low or High
    DTC U1500 Inter-Device Dedicated Bus Malfunction
    DTC U2000 Invalid BFC Transmitted SPI Data
    DTC U2001 Invalid IPC Transmitted SPI Data
    DTC U2002 SPI Data-In Low
    DTC U2003 SPI Data-In High
    DTC U2004 SPI Data-Out Low
    DTC U2005 SPI Data-Out High
    DTC U2006 SPI Clock-Out Low
    DTC U2007 SPI Clock-Out High
    DTC U2050 SIR PPS/CPS Communications Link malfunction
    DTC U2100 CAN Bus OFF
    DTC U2100 CAN-BUS Communication Malfunction
    DTC U2102 More Controllers on Bus than Programmed
    DTC U2103 Fewer Controllers On Bus Than Programmed
    DTC U2104 CAN Bus Reset Counter Overrun
    DTC U2105 CAN Bus Error ECM
    DTC U2105 Lost Comm with Engine Control System
    DTC U2106 Lost Comm with Trans Control System
    DTC U2107 Lost Communications with Body Control System
    DTC U2108 CAN Bus Error ABS
    DTC U2108 Lost Comm with ABS Control System
    DTC U2150 Navigation ECU Gateway Communication Error
    DTC U2151 Navigation ECU Communication Malfunction
    DTC U2153 VICS ECU Communication Error
    TN
    I vote sticky!
    05 Cavalier
    Aug 2007
    Connecticut
    bump bump bump
    whats everyone think
    I Drive A Silverado
    Nov 2001
    Tennessee
    Too Much information
    Previously owned fullsizes
    89 Silverado (2)
    90 Silverado
    92 Silverado
    92 454SS
    95 Silverado Ext Cab
    96 Silverado
    elkton,maryland
    Im thinkin sticky as well.
    97 Gmc Sierra 1500
    Kiowa, KS
    The dreaded U code is for loss of communication. When a module stops communicating the other modules in the sytem will contain U codes stating that communication was lost with X module.
    Austin Texas
    This is great. We need a sticky with all the trouble codes for all year trucks. I say OBD 1 is next!
    Registered User kev2809's Avatar
    Dec 2007
    Rosenberg, Tx
    definitly worth being a sticky...i have a question also.
    my truck is throwin codes p0420 and p0430. can anyone give my advice on what to change/fix/look into first to fix this problem?
    thanks in advance!!
    02 GMC Sierra ECSB - 05 front clip
    2008 Silverado 4x4 Z71 Crew Cab - Stock......for now
    67 1/2 ton Suburban - Project DRGWGN
    rollin the nasty D's!!! Double Dueces's Avatar
    Apr 2006
    Minnesota
    I gota p0171 or P0174 Sys too Lean (bank 2) now how do I fix this issue???
    '01 XCSB a few mods done to it.
    truck parts http://www.supermotors.net/vehicles/...ry/10422/66312
    Aug 2007
    Connecticut
    Quote Originally Posted by Double Dueces
    http://www.fullsizechevy.com/forums/...171-p0174.html
    check this. maybe you can get an idea
    Registered User created2destroy's Avatar
    Nov 2008
    Defiance, OH
    Thanks alot. I had been looking to something like this to save to my computer, so I copied and pasted it into a txt file.
    2001 Silverado, Z71, LT, 5.3, g80, Tuned by Blackbear Performance:rocking:
    I'm All Tip thekl0wn's Avatar
    Apr 2005
    Indy
    Why is this not a sticky?
    '03 Tahoe - Blackey
