Thread: 350 vortec vs. carbed 454
Page 1 of 8 123 ... LastLast
Results 1 to 20 of 159
    Registered User Green meanie's Avatar
    charlo,mt
    which pulls a load better a lightly modded 5.7 vortec or carbed stock 454, same load, both 3/4 ton's (better gear for small block) I like the vortec, never gets hot, pulls very well, though a good running BBC has great take off power. what's all you's opinion,
    Dec 2004
    Elkhart IN
    Re: 350 vortec vs. carbed 454
    if the BBC is in proper tune and repair, there's no way the poor little small block is going to stand a chance at winning.
    charlo,mt
    :fsc: mileage will suffer on longer trips with BB, my '00 5.7 3/4 4x4 4.10's ccsb gets steady 12-13 mpg from montana to idaho pulling 7,000 pounds up the passes, worst was 11 mpg, also did not budge more than 190 degrees, with plenty of power, very happy with SBC.
    Euless, Texas
    Quote Originally Posted by Green meanie
    Vortec 350
    http://www.youtube.com/watch?v=XHsZ6DIAPIk
    http://www.youtube.com/watch?v=Zm-54_fxLgY
    Engine in signature pulls anything hooked up to it, runs cool, and doesn't ping on 87 octane.
    charlo,mt
    good choice
    Dec 2004
    Elkhart IN
    not necessarily, depends on the load, gears, tire sizes, and a whole bunch of other factors. i've seen several cases where swapping in a big block IMPROVED milage. bigger engine doesnt always mean worse economy.
    charlo,mt
    :fsc: just from experience, all the vortec 454 ccsb's in my area all seem to get 10-12 mpg unloaded, but also depends on the way someone drives and maintnence, best Ive done on older trucks was with '75 1/2 ton 4x4 4spd 308 gear stock gutless 350 q-jet, 31" tire was 18mpg on hiway.
    shake & bake 91_bowtie's Avatar
    Jan 2002
    KCMO
    Quote Originally Posted by Fast305
    Vortec 350
    Well damn! That proves it. Close the thread! Two vids on youtube settled the case, once again.
    I've always known that you've had a plug wire loose, but to suggest that a sbc will out pull a bbc is down right stupid. Honestly, what do those vids prove? Were they pulling loads? Was it the same load? I have similar vids of my gauges, that I took so I could watch the tach, when testing different launch techniques. Should I be including that in all of my posts? Would that help get my point across? :LOL:
    08 TBSS
    91 HD 3/4 ton
    03 Z71 Tahoe
    - Luke 1989K1500's Avatar
    Jan 2005
    Ravenna, Michigan
    :fsc:
    You dont have to put that before every post.
    Jan 2002
    KCMO
    Quote Originally Posted by 1989K1500
    :fsc:you don't?
    08 TBSS
    91 HD 3/4 ton
    03 Z71 Tahoe
    Jan 2005
    Ravenna, Michigan
    Quote Originally Posted by 91_bowtie
    :fsc:you don't?
    :fsc:I dont think so? :fsc:
    Euless, Texas
    I know how the older BBC ran stock and I know how the 5.7 runs stock. The Vortec 5.7/4L80E is a much more flexible powertrain than the 7.4/TH400. Puts more power to the wheels over a broader RPM range. This means it will pull better over the vast majority of conditions. Not to mention carb 454 is a pig on gas, i've seen plenty in the single digits fuel economy wise while pulling.
    Youtube video is of two very similarly setup trucks. One a carbed 7.4/TH400 driveline and the other a Vortec 5.7/4L60E. As you can see the Vortec 350 has supperior power and acceleration. Under a load expect to see the same results.
    Jan 2005
    Ravenna, Michigan
    :fsc: My truck accelerates faster than either of those, that doesnt mean mine tows better. :fsc:
    Euless, Texas
    Both trucks being stock, the truck that puts the most torque to the wheels over the broadest operating range is going to pull better. Quite honestly a 350 Vortec pulls alot like an older big block. I've pulled 6,000 lbs behind a stock Chevrolet Express 2500 with 3.42s and honestly it had great power.
    Jan 2002
    KCMO
    The vortec 350 also accelerates quicker than a stock powerstroke/cummins/dmax. I'm not going to search youtube for vids of their speedometers. So are you saying the vortec 350 would also out pull those trucks? I'm just trying to use your logic. What about a turbo honda that runs 10's? It accelerates quicker than the vortec, so it would out pull it too, right?
    08 TBSS
    91 HD 3/4 ton
    03 Z71 Tahoe
    Dec 2004
    Elkhart IN
    :fsc:i've pulled 6K with a stock C1500 and it took out the trans and overheated the motor. it had 3.42 gears too.:fsc:
    edit: crap, i forgot to put in my :fsc:s
    Dec 2004
    Elkhart IN
    fast, since the first post clearly states "which pulls a load better" and not which one will make a better daily driver that pulls a load once in a while, the answer is BBC.
    Jan 2002
    KCMO
    I don't understand what you're saying. Do you have a vid of the speedometer to help clear this up?
    08 TBSS
    91 HD 3/4 ton
    03 Z71 Tahoe
    Jan 2005
    Ravenna, Michigan
    :fsc: Must have been slower than the two vids posted. :fsc:
    :fsc: And you need 3.08 gears, those are the best gears. :fsc:
    Jan 2005
    Ravenna, Michigan
    :fsc: :fsc:
