Thread: Camshaft Position Sensor
Results 1 to 8 of 8
    Jan 2007
    philly
    The trucks been getting harder to start for the last week or so, so I had the codes ran today. Through a P0340, Camshaft Position Sensor A- Bank 1 Circuit Malfunction.
    I searched around the forums and dint really find much besides that the CPS is located somewhere below the distributor.
    How would I approach changing this? is it hard? Or is it just unscrewing and unplugging the old one and throwing the new one in?
    What would be the esiest way to access it? From under the truck? Or from the top?
    Help!!!
    1998 Chevy K1500- Used, Abused, and Sold 1989 Camaro Iroc-Z 5.0, auto....- Sold
    1987 Dodge Dakota 2bbl, 5 spd, v6, 4x4, -scrap
    1993 Honda CBR600 F2- DD when nice out 1987 k5 blazer- bad ass
    Jan 2007
    philly
    Re: Camshaft Position Sensor
    ttt
    May 2007
    Louisville, Ky
    The CPS is inside the distributor cap housing. You'll need to take the cap off. Remove the rotor and you'll see it on the backside towards the firewall. There should be two little torx head screws holding it in place. Be careful not to drop the screws inside the distributor. Unplug the harness. You shouldn't have any problems. I can't remember, but it may need some di-electric grease upon reinstallation of the new one??? Anyone else know this bit of info?
    Have you tried jiggling the wiring harness yet? I'm assuming not since you didn't know the exact location of it. Try to move the harness a bit and see if it will start. I had one do this once before. Also would get moisture in when it was wet outside due to the bad connection. Just a thought.
    1997 C1500 ECLB 5.7 Vortec G80 3.73 Rear
    K&N FIPK, Cherrybomb Vortex DI/DO Dumped
    Jan 2007
    philly
    Quote Originally Posted by JJonesey
    Thank you very much! Thats just the info I was looking for.
    Woodstock Ontario Canada
    Could be the circuit to and from the sensor as well.
    peace
    PAuly
    Jan 2007
    philly
    Just replaced the sensor... Still doesnt start. I guess Pauly was right. I dont know what I'm going to do now, no idea where the circut goes...
    Jun 2002
    Wisconsin
    The pink wire at the sensor should have power with the key on. The other two wires go to the VCM. On the 96(I dont have a 98 service manual) they went to the blue connector, posts 3 and 8 but matching the wire colors at the sensor and vcm should work
    elkton,maryland
    Had a similar problem. A voltmeter is your friend.
    97 Gmc Sierra 1500
