Thread: 700r4 retrofit
Results 1 to 6 of 6
    "Shake and bake" kidwithwrench86's Avatar
    Dec 2008
    Hopatcong, NJ
    700r4 retrofit
    what would i have to do to put a 700r4 into my 94 blazer with a 4l60e in it? the blazer has all teh hook ups for the tv cable, i just need to know about the wiring part.
    kids with wrenches 4x4 - hopatcong, NJ.
    proud member of the oobs and obs hood wacker clubs
    Re: 700r4 retrofit
    A donor harness from a 88-92 would help. plus your gonna need a custom burnt chip. what year is the 700r4? does it have the electronic vss?
    Dec 2008
    Hopatcong, NJ
    Re: 700r4 retrofit
    its a built 4x4 trans thats in my 86 silverado.
    Nov 2008
    Olathe KS
    Re: 700r4 retrofit
    The only electrical item you need for 700r4 is
    to control the torque converter lock up.
    You can do it manually with a $3 toggle switch or
    you can use any number of ways to "controllers".
    U can even use a vacuum switch so the trans only
    "sees" power to lock-up at a set/stable engine
    vacuum.
    94 Extended Cab Step Side (Big Red)
    12.01 @ 115.4 mph 1.90 60'
    422 small block. Vortech S/C
    Tows the 9000 lb camper just fine!
    94 GMC C1500 Long Bed (Big Blue)
    Stock for now
    Kids Drive It
    Dec 2008
    Hopatcong, NJ
    Re: 700r4 retrofit
    yea i've got all that stuff in my 86 which would go into the blazer along with the trans, my biggest question is, if i just unplug the harness at the trans, and leave it, will it screw with my engine? i doubt it would, but i wasnt sure if it changed anything with fuel or anything depending on what gear its in,
    Nov 2008
    Olathe KS
    Re: 700r4 retrofit
    You will be fine..
    The "harness" that plugs into a 700r4 really
    only operates the lock up function.
    Your engine doesn't care what the trans is doing!
    Stock for now
    Kids Drive It
