Thread: V6 to V8 engine swap
Results 1 to 20 of 26
    Tiger Tiger's Avatar
    Dec 2008
    Florida
    Other than the engine and transmission what else would I have to change/do to swap my engine out with a V8?
    Is any one V8 engine thats easier to swap out?
    1994 4.3 V6 reg. cab, short bed.
    Aug 2008
    Vacaville, California
    Re: V6 to V8 engine swap
    potentially drive shaft if the trans is diff length.
    Registered User ABK1500's Avatar
    Minnesota
    I'm assuming the truck in your sig?
    Anyway, find a TBI 350, it will bolt up to your current tranny, and get the associated wiring with the 350.
    You may or may not need new motor mounts, I don't remember.
    98 ECSB/265s/Swapped 350/NV3500 /Airaid/Flowmaster/3.73/Alpine/Kicker
    Carpe deim. Seize the carp.
    Oct 2003
    Colorado Springs, CO
    Wouldn't the wiring be the same from the 4.3 to the 350? It's only 2 injectors for each engine, or is some too short due to the shorter block?
    Dec 2008
    Florida
    The injectors are the same. I didn't think that I was going to be able to use the same wiring harness and tranny though. That's awsome.
    My sig is the truck that I just got. the reason I want to do the swap is because I got the truck with two cracked heads and I figured I could probably get a used V8 for the price of 2 new heads. I think the V6 hurts my pride a little as well.
    Dec 2008
    Florida
    The motor mounts are a little different though. They are like a step back. I would go outside and take a picture but my girlfriend is out doing something with the camera.
    Dec 2008
    Florida
    Minnesota
    If they were like mine (although my truck is a Vortec), they v6 motor mounts will not work, they are to far back.
    V8 mounts are not hard to come by though...
    Dec 2004
    Elkhart IN
    the motor mounts themselves are the same, they're just positioned too far back. move them forward on the frame (the holes should already be there), and you should be fine. you may have to lengthen a couple wires, but that's about it. swap your TB for a comparable year TB for a 350 (larger bore IIRC and larger injectors) get a custom tune for your year truck with a 350, and call it good.
    Smokin 38s SuperChevy17's Avatar
    Sep 2006
    Southeast Texas
    Remove the V6 brackets on the frame and bolt in new motor mounts using the existing holes. You'll need to lengthen the wires on the temp sensor on the driver's side head and the wire on the passenger's side knock sensor. There could be a few more but I haven't found them yet. If you can find a complete TBI 350 that would be your best bet. Be sure and keep the metal brackets on the bottom side of the engine as you will need them to bolt it to the new motor mounts. If you are keeping your original trans, you wont have any problems with driveshaft length. It will all stay in the original location. You can reuse the original wiring harness. You can even take the injectors from the 350 and put them in your original TB unit if it's in better shape. I just got my 350 swapped in about a week ago and am doing the wiring now.
    95 Chevy 2wd TBI Vortec 350 5spd. *Ultimate Budget Engine Swap*
    Engine: 98 4-bolt Vortec 350|Scat Crank|LT4 Production Cam|1.6 Proform Full Roller Rockers|Edelbrock EPS Intake|454 Throttle Body|Hedman Elite 69840 LT|ZOOM Perfection Clutch|Custom Tune by TBIChips
    98 ecsb 4x4 38" TSLs
    TN
    You can use the wiring harness, you need a 350 computer.
    You need new mounts, and ESC (Electronic Spark Contorl Module) for a 350.
    The trans should work fine, but it may not last behind a 350.
    That's about it.
    05 Cavalier
    Dec 2004
    Elkhart IN
    ah, and the distributor.
    Sep 2006
    Southeast Texas
    Yep, forgot to mention the computer. Or you can send the V6 chip off to have it custom tuned.
    I assumed the distributor would come with the motor. But if not, then you will need the V8 dist. A complete TBI 350 engine will be easiest to swap in. You didn't mention what trans it was, but if it's manual, then you'll need clutch, pressure plate, & flywheel for V8 also.
    Dec 2004
    Elkhart IN
    the 4.3 flywheel and clutch should fit the 5.7 just fine.
    Minnesota
    :word: Transferred over on mine w/o a problem. I did however need new motor mounts.
    Sep 2006
    Southeast Texas
    Do you really think you should use the smaller V6 clutch behind a V8?
    Dec 2004
    Elkhart IN
    if it is in fact smaller, its not going to be THAT much smaller that it wont work. if its worn, replace it and upgrade.
    Jul 2010
    NB, Canada
    If you went backwards say to put a v6 into a truck that had a v8 would I need to replace the tranny and rear?
    Apr 2003
    Ft.Lauderdale, Fl.
    V-6 radiator usable on the V-8?
    Sep 2003
    Catalina, AZ/Swartz Creek, MI
    The transmission & rear can stay in place.
    It could be hooked up, whether it will cool sufficiently I don't know. I'm looking for motor mount info myself, and also about the fuel lines, is there any issue with those going from a 4.3 to SBC? Far as the motor mounts, it's just moving them to the proper location on the frame?
