Thread: OBS 4/6 C Notch question
Results 1 to 20 of 21
    Registered User SS350Sport's Avatar
    Utah
    OBS 4/6 C Notch updated with pictures
    Has anyone ever just welded in this piece from the bolt in c-notch?
    It seems like it would be a lot cleaner, just as strong if welded in and you wouldn't have to dick around with trimming the bed rail to clear the top of the bolt in notch. What do you guys think?
    91 C1500 SPORT, 5.7, 700R4
    :FSC:
    DBG
    Sep 2005
    San Luis Obispo, CA
    Re: OBS 4/6 C Notch question
    The only problem I can see is that if you just use that small section of the notch to weld in, you don't have as much distribution of the load across that whole chunk of metal. If you welded that section in and boxed the area around it, you'd probably be fine.
    Darren
    89 RCSB Dana 60/14 Bolt 4-lnk frnt/rr, 39.5's/14" Welds, 5.13, Truetrac/Detroit, AEM Intake, Holley 670 TBI, Holley Mnfld, Shorties, 40 series, no cat. 98 2wd 355, lt4 hotcam, 1.6 rllr rckrs
    Project Pics:
    http://community.webshots.com/album/366426764ygYniE
    Utah
    Boxing it is a good idea. All I would have to do is cut straight up the sides from the bottom ends of the notch and turn it around, I would have the plate for the box already welded to the notch portion.
    :FSC:
    DBG
    Sep 2005
    San Luis Obispo, CA
    You would want to box the whole backside of the frame at least 6" or so to the left and right (looking at the picture) of the notch. The frame section you cut out isn't gonna be nearly enought material to give you the strength necessary. You're best bet would be to weld that notch in and then trace the shape of the frame onto a piece of 1/8" (min) thick sheet metal. Cut out the piece and weld it to the back side of your frame.
    Darren
    Project Pics:
    Registered User 5.7L JWL's Avatar
    Savannah, Ga.
    SS350Sport, sorry for the :jacked: but DARREN250R I just got done looking at your build up of your suspension WAY COOL MAN
    I just had to tell darren250r that
    '98 ECSB, Edel Headers, Magnaflow Cats/CatBack
    K&N, Pully, Ign.Kit, D/S Rotors, SS Lines, BB 89 Tune
    Built 4L60E w/ Vigilante 2800 Stall
    http://photobucket.com/R3215T3R/ (Toyvrolet Drag Truck/S-10 Drag Truck)Pics.
    Utah
    I hope you feel better now..
    :FSC:
    Utah
    Re: OBS 4/6 C Notch Update with Pictures
    I had the C notch's ready to bolt in and started to think of a cleaner way to install them when I posted the question here. darren250r gave me the suggestion to box in the frame and here is what I came up with. I will post more when finished.
    Ready to bolt in.
    Here are the cuts I made, basically took off the top and bottom flanges
    Tacked in place
    Top view
    Side view
    :FSC:
    DBG
    Sep 2005
    San Luis Obispo, CA
    Nice man. That's exactly what I was picturing when I was explaining it. That worked out well using the cut up notch instead of plate steel. I would go the same route if I was to put a c-notch in...much cleaner than a bolt-in. Probably stronger too.
    Darren
    Thanks JWL
    Project Pics:
    Savannah, Ga.
    Quote Originally Posted by SS350Sport
    Not really.
    Just givin' credit.
    Utah
    Re: OBS 4/6 C Notch Finished pictures
    I finished up the welding today. I think it will look a lot cleaner when painted and put back together. I also welded nuts on the inside of the frame rails and on top of the notch for my upper bag mount and the bump stops.
    Back view
    Nuts welded in:
    :FSC:
    Apr 2003
    Ft.Lauderdale, Fl.
    Nice clean workmanship. I like it. But, do those standard size frame rail notches actually provide enough clearance, to keep the rear-end from bottoming out, when doing a straight 6" axle flip?
    Utah
    Quote Originally Posted by LS1GMCTruck
    I can't say for sure, until I start driving it. But I would guess the answer will be yes. I do have some helper bags that will be installed and inflated for when I'm hauling a new project home.
    :FSC:
    Registered User Tigwldr's Avatar
    Jul 2008
    NC
    Great idea, that looks awesome.
    Nice work.
    DBG
    Sep 2005
    San Luis Obispo, CA
    Good Job
    Darren
    Project Pics:
    Feb 2008
    DIRTY SOUTH JERZEY
    Nice work man! I had that notch on my obs ext. cab with a 4/6 and it would hit over bumps. That was my experience, I had to install a super c-notch. Good luck
    Apr 2003
    Ft.Lauderdale, Fl.
    Quote Originally Posted by PURPLEHAYES
    This is what I have been hearing as well. I don't want mine to EVER bottom out on my frame or snubbers. Are the Super-C sections just as easy to weld in? Thanks
    Feb 2008
    DIRTY SOUTH JERZEY
    A little more work to weld in but basically same idea. You have to cut crossmember on bottom of bed for it to fit back on. When you put the bed back on it will lay on top of the notch. You will have to tighten bed bolts to pull the bed down tight. Or you could cut the bed, but what ever works for you. Have fun
    Registered User ZRACE1's Avatar
    Enterprise, Alabama
    Exclamation Re: OBS 4/6 C Notch question
    Hey SS350, is it my imagination or did you just flip over your U-bolt bracket when you flipped your rear end. I noticed you were using the stock brackets. Explain please how you did that....that is way cool.
    Thanks
    tony
    Ol' Skewl BS'er flotsamm's Avatar
    Jul 2007
    California
    Quote Originally Posted by ZRACE1
    Thanks
    tony
    Basically you cut the axle saddle off the axle then put it on the bottom. Then you flip the brackets over and use the u-bolts sideways across the leaf springs.
    5.7L, 5-Speed, 4/6 drop on 245/45/18's
    Utah
    Thanks
    tony
    What flotsamm said. I cut the spring perch off of the axle tube and rewelded it to the (new) bottom side of the tube. I'm going to drive it for the summer and tear it all back down for paint and do some more mods on the flip.
    :FSC:
