Thread: Steering wheel doesn't lock
Results 1 to 14 of 14
    Supporting Member
    Sep 2005
    MN
    I just bought a 2005 Suburban 2500 and I notice the steering wheel doesn't lock when the ignition is off
    Normal?
    Registered User gmsuv's Avatar
    Michigan
    Re: Steering wheel doesn't lock
    Here are the diagnostic steps to check
    Lock System Does Not Lock
    Step
    Action
    Yes
    No
    DEFINITION: The lock system will not allow the key to be turned to the OFF lock position.
    1
    Did you review the Steering Wheel and Column Description and Operation?
    Go to Step 2
    Go to Steering Wheel and Column Description and Operation
    2
    Verify that the lock system does not lock.
    Does the lock system operate normally?
    System OK
    Go to Step 3
    3
    Inspect for a faulty lock cylinder or release button.
    Is the lock cylinder or release button damaged?
    Go to Step 7
    Go to Step 4
    4
    Inspect the shift cable adjustment.
    Is the shift cable adjusted incorrectly?
    Go to Step 8
    Go to Step 5
    5
    Inspect the ignition switch for damage.
    Is the ignition switch damaged?
    Go to Step 9
    Go to Step 6
    6
    Inspect the linear shift for damage.
    Is the linear shift control damaged?
    Go to Step 10
    Go to Step 7
    7
    Replace the lock cylinder. Refer to Ignition Lock Cylinder Replacement .
    Did you complete the repair?
    Go to Step 11
    8
    Adjust the shift cable. Refer to Automatic Transmission Range Selector Cable Adjustment in Automatic Transmission - 4L60-E/4L65-E or to Automatic Transmission Range Selector Cable Adjustment in Automatic Transmission - 4L80-E/4L85-E.
    Go to Step 11
    9
    Replace the ignition switch. Refer to Ignition Switch Replacement .
    Go to Step 11
    10
    Replace the linear shift assembly. Refer to Linear Shift Assembly Replacement .
    Go to Step 11
    11
    Operate the system in order to verify the repair.
    Did you correct the condition?
    Old Geezers know stuff... dlstewart01's Avatar
    May 2005
    Tennessee
    They took the steering wheel lock off some time around 2002. Your 2005 DOES NOT have a steering wheel lock.
    Have a good one,
    Don
    Edit: After some research I don't believe the lock has been on there since 1999. Some of the early 99s had them, then the steering wheel lock disappeared. There are some who say they were there through 2001, I can't verify this.
    05 GMC Sierra, Ext Cab, 5.3
    "Never argue with an idiot. They will bring you down to their level and beat you with experience."
    3/5 Cav, C Troop, Blacks Knights, Vietnam, 1969
    Nov 2007
    Michigan
    My 2003 2500hd & my 2008 Honda Civic does not have the steering lock.
    Mike
    2003 2500HD 6.0 auto 4.10 4x4
    Registered User figment3's Avatar
    Nov 2008
    mars
    no locks on 2003 and up
    Kiowa, KS
    Actually a 2003 duramax with 6 speed manual does have a steering wheel lock. Just found that out this weekend. Come to think of it I don't know if any of the trucks had steering wheels locks from 99 and up. I don't think my 99 has it.
    May 2005
    Tennessee
    I just knew someone with a straight shift would post this. The automatics have not had a steering wheel lock since around 1999. Some early 99s had them.
    Have a good one,
    Don
    Formerly KC9NMO WX9BLZ's Avatar
    May 2005
    Indianapolis, IN
    I would love to have a Dmax with a 6 speed stick!
    Quote Originally Posted by tatoodkelt
    When approaching a four-way stop, the vehicle with the largest tires always has the right of way.
    Quote Originally Posted by possom813
    I can deal with loud and uncomfortable, hell I've been married for 8 years.
    Kiowa, KS
    Quote Originally Posted by KC9NMO
    The guy had hell with throw out bearings for the first 40,000 miles or so. Finally GM came out with a redesigned bearing and it hasn't done it since. I prefer an automatic with a diesel, at least a light duty truck diesel.
    Soap, Ballot, Ammo
    Aug 2008
    Clinton, MO
    Quote Originally Posted by dlstewart01
    Have a good one,
    Don
    Learn something new every day. Do you know the reason the lock was deleted after all these years?
    My 2000 has the lock btw.
    May 2005
    Broken Bow, OK
    They had it after 99. It is 2002 when they took it out. My 2001 C3 has it, but our 2003 Tahoe does not.
    excerpt from a service bulletin:
    Notice: On the 2002 and later model year vehicles, the steering column LOCK was removed from the steering column. It is critical that the J 42640 - Steering column Anti-Rotation Pin is used when servicing steering columns on 2002 and later model year vehicles. Failure to use the J 42640 may result in damage to the SIR coil.
    The steering column lock was an anti-theft feature that I guess they think is no longer necessary with the PASSLOCK II installed. I know a lot of people park with the wheels cut sharply and then can't turn the ignition when they get back in. They don't think to take pressure off the wheel. I have had several people call and say their truck won't start and that is all that was wrong with it. It was probably removed as a cost cutting measure though. Steering column is less complicated meaning less cost to manufacture.
    May 2005
    Tennessee
    Quote Originally Posted by 99-2door
    Yes I read that and thats what I was going by, but then one of the GM engineers told me they took it off before then, I guess it doesn't matter its been gone for a while.
    Don
    Kiowa, KS
    I've had my 99 going on 7 months and I don't think one time the steering wheel lock has ever engaged. Either it doesn't have it or it was taken off or just doesn't work. Doesn't bother me any.
    I want to say it became an issue when the push buttom start Corvettes came about. Seems like the steering lock was operated by a solenoid and for whatever reason it was engaging at random while going down the road, or was capable of doing that and they decided it was best just not to have it anymore.
    May 2005
    Indianapolis, IN
    I imagine it was a cost saving measure.
