Thread: 97 tahoe runs rich/misfires
Results 1 to 20 of 20
    Registered User 91chevyon22s's Avatar
    May 2008
    calgary, AB
    I have a 1997 tahoe with a vortec 350...when i start it up in the morning it fires right up. after about a minute or 2 of driving it misfires at idle, and if i shut it off and re-start the truck within the next 3 hours i have to actually give it a bit of gas just for it to start..it seems like it runs to rich when it idles.
    It has new cap,rotor,plugs,wires,coil,O2 sensor and fuel filter...please help me with this its really becoming irritating not to mention robbing gas milage like crazy !! thanks in advance
    May 2008
    calgary, AB
    Re: 97 tahoe runs rich/misfires
    Bump...i really need help with this!!
    1997 2wd Tahoe,loaded,tinted,dropped,22's
    1995 2wd Suburban,tinted,2 12's, exhaust,roll pan, 7" touch screen
    1981 Short box,dropped 4/6, 468/th400, black on black
    1977 blazer 8" lift 454/4speed/205
    sittin on 38.5" swampers
    Hired Goon Aloicious's Avatar
    UT
    Quote Originally Posted by 91chevyon22s
    how do you know its running rich? lean conditions can cause problems like you describe as well. do you have any codes stored? if you can get a scanner that can look at your fuel trims and see what they are at, and if your scanner can see misfire counts, you can see which cylinder the misfires are occuring at. how long has it been acting this way? is it ONLY at idle that it has the problems? did you replace BOTH pre-cat O2 sensors? unfortunately its hard to diagnose problems like this, especially over the internet, but you've started at the right place by doing a tune up.
    May 2008
    calgary, AB
    Well i figure its running rich because they exhaust smells very strongly like gas at an idle and when it fires up theres a bit of black smoke at first. i have plugged it in and it comes up as (random ignition misfire) The guy that put in the plugs put in ACdelco platinums, i heard the rapid fires were much better. and yes both O2's were replaced, even the after cat one was done. im thinking maybe its just ****ty plugs?
    Thanks!
    May 2008
    calgary, AB
    Bump..has anyone had this problem,or know of anypossible solutions?
    S/C Z71
    Do you still have the stock poppets and FPR in there?
    May 2008
    calgary, AB
    To tell you the truth i have no idea i only got the truck a month ago, where are the poppets?
    S/C Z71
    The poppets are the fuel injectors and they're in the intake manifold. It sounds like one or more of them are leaking or the FPR is leaking causing a rich condition upon start up.
    May 2008
    calgary, AB
    so in order to get to the injectors i have to take off the intake?
    St. Paul, MN
    You just have to remove the top half of the intake. There is a plastic shell that covers the fuel injectors and the fuel pressure regulator. Once this piece is off, it will look like this:
    May 2008
    calgary, AB
    ahh awesome thanks for the picture!!
    so the dist. tb. all that stuff comes off with the plastic cover yes? and i dont have to get any gaskets for this do i?
    sorry im new to vortecs lol used to play with TBI's a lot
    May 2008
    calgary, AB
    okay i pulled out all the plugst see whats up, they all seem a little to carboned up and black for like 1 month old and the back 4 are nasty black an grungy and smell of gas... FPR??
    UT
    yeah if you're getting P0300, it smells rich and you're running the original poppets, theres a good possibility its either the poppets themselves or the FPR leaking causing the problem, either one will require pulling the upper intake.
    you shouldn't need to pull the dizzy for just the upper intake, but the TB and what not will have to come off, the upper intake is the black plastic dome looking part that the TB mounts on, then there is an aluminum lower intake below that.
    May 2008
    calgary, AB
    And how do i go about checking the poppets and FPR?
    Is there a way to test them to see if they are leaking?
    UT
    I'm not running a regular manifold and never had issues like this with it when I was running it, so I can't help much, someone like 98greenmachine who has done a lot with them would be able to help out more.
    S/C Z71
    If you're going to take the upper intake off then just replace the injector spider (all 8 injectors and the FPR) with the updated unit. You shouldn't have to remove the distributor.
    May 2008
    calgary, AB
    well i pulled out all the plugs cleaned em up a bit cause they were pretty black looking i took out the IAC and cleaned it up a little bit put it back togther went for a ride and the missing is still there but not nearly as bad...i think the ac delco platinums are the problem... lol might go with rapid fires see if that will solve it??
    May 2008
    calgary, AB
    any ideas??
    S/C Z71
    Ever change the fuel filter? What's the pressure?
    May 2008
    calgary, AB
    Brand new fuel filter. have not checked the pressure yet..
