Thread: 305 ECM in a 350 TBI Truck?
Results 1 to 18 of 18
    Mudder Phucker BMac4x4's Avatar
    Mar 2006
    Jupiter, Florida
    How would a TBI 350 run with a 305 ECM in it?
    Registered User stahlecker's Avatar
    Aug 2004
    Nebraska
    Re: 305 ECM in a 350 TBI Truck?
    I had a 305 ECM in my 91 when I first swapped a 350 into it. It ran alright. But swapped the 350 ECM in since I had it layin around.
    2004 Silverado 1500 ECSB Blue/Silver Z71
    Winter Toys:
    NEW! 2008 Yamaha Apex MTX SE
    2001 Arctic Cat 800 Mountain Cat with a 2003 King Cat 900 engine (150hp) and 144" finger track. (needs a new home)
    Mar 2006
    Jupiter, Florida
    Well i just want to know if there's any difference in the two or if its just a different chip for each motor. I got a junkyard ecm because mine was fried and i'm not 100% sure that is from a 350. but i did swap the chip from mine into the new one.
    Dec 2004
    Elkhart IN
    whats the 4 letter code on it? that should tell you exactly what it is.
    Mar 2006
    Jupiter, Florida
    not sure, the truck is accross town at a friends shop. what code should it have?
    Dec 2004
    Elkhart IN
    hard to say.
    Mar 2006
    Jupiter, Florida
    here's a pic from the sticker on it
    May 2007
    house
    BDXJ is the broadcast code. it comes back to a 1994 LB4 (4.3L) M30 trans
    Mar 2006
    Jupiter, Florida
    so how would a 6 cyl ecm rum a 350? and whats a LB4 and a M30 trans?
    May 2007
    house
    gm ecu are very similar. somebody hot cheap and just swapped it in, thats my guess.
    JoshTheCanadian
    Quote Originally Posted by BMac4x4
    If you get a custom tune it will run it. LB4 equals a 4.3L V6 Z Code engine. and M30 is trans im not sure which one
    May 2007
    house
    the ecu will work for a v8 with the correct harness but the chip is no good for a v8 replace it with one that is made for you motor.
    Mar 2006
    Jupiter, Florida
    Yea i stated that in this thread already. i took my custom tuned chip from my other fried ecu and put it in the new one. so what you all are getting at is, other then the chip, there is no difference in the two ecus and it shouldnt cause any performance issues?
    Dec 2004
    Elkhart IN
    right. if you swapped the chip, that's no longer any different than a stock 350 ECM.
    Mar 2006
    Jupiter, Florida
    thanks
    Jul 2003
    Ft, Riley Ks
    What year is the truck? I have a spare Prom from my 92!
    Infantryman in the US Army
    SH!T HAPPENS, THEN WE DIE
    Waterford WI, LaFarge WI (cabin)
    i had the 305 ecm in my '95 for a while til i got a deal on the 350 ecm. ran fine, a little rough at times but im not really convinced the ecm was the problem.
    04 GMC RCLB LB7 stock w/ leveling kit
    95 GMC RCSB ongoing resto/SAS Build
    94 Dodge 12v 5spd "charcoal pit"
    89 Toyota flat bed
    Mar 2006
    Jupiter, Florida
    Naa i don't need the prom but thanks anyway rob. i don't think the ecu is the problem but i was trying to eliminate it as a possibility. i think the fuel system is all clogged up with blue silicone that my brother used when he put the fuel pump in for me. bastard!!
