Thread: bad fuel smell in tahoe
Results 1 to 20 of 25
    Jan 2008
    North Stonington CT
    ive got a 97 hoe 5.7 vortec all stock. im getting a super strong fuel smell INSIDE the truck, no leaks outside or smell from outside. i replaced the gascap with no luck. it goes away after a bit of driving then comes back after you park it for a while. all the vent lines are intact and not broken. im at a loss.
    Jan 2008
    North Stonington CT
    Re: bad fuel smell in tahoe
    searched some more, still nada
    SnowedXCSP snowed500's Avatar
    Sep 2004
    Emerson, NJ
    My 97 had a strong smell inside and out but i saw nothing leaking what-so-ever. Turned out it was the return line tucked up above the tank. No leak but that was the problem. Gas was stinkin but evaporating. Good luck...
    Jan 2008
    North Stonington CT
    thanks man, ill look into that
    Sep 2004
    Emerson, NJ
    Sure sure no problem....
    Jun 2008
    Canada
    I've got the same issue with my 96 Yukon. The first time i dropped the tank that vent line that runs along the top of the tank had rotted in several places. I pieced it together with hose and clamps but the gas smell is still reall bad. Let us know if you figure it out. I'm leaning towards a bad ring gasket where the fuel pump goes into the tank.
    Sep 2006
    Tennessee
    I remember a thread where a guy was tracking down a chemical / fuel smell and it ended up being a bottle of de-icer underneath the seat! I would think your leak would be somewhere around the top of the intake in the supply line. Probably when you shut the truck off the pressure bleads off and the vapors are sucked into the hvac fresh air intake.
    Jan 2008
    North Stonington CT
    where is that supply line locatated exactly?
    Sep 2006
    Tennessee
    Top of the engine to the right of the distributor. You'll see a fuel pressure test port schrader valve in it.
    UT
    If you double check the supply and return lines and don't find a leak, I would also suggest checking the EVAP lines/components. They could be leaking, or, if they are clogged or a valve isn't opening, that can release gasoline vapors.
    '98 K1500 Suburban LS rear ARB
    '92 Ford Explorer XLT 4x4
    S/C Z71
    Any codes?
    Jan 2008
    North Stonington CT
    no codes at all. truck runs like a bear.
    Jan 2008
    North Stonington CT
    okay i thoghut the problem went away but it is back now wityh a vengance. i have to drive with the windows down. the outside and inside of the truck smell like gas. its got a new gas cap on it.
    houston,tx
    does it smell like gas under the hood?
    Jan 2008
    North Stonington CT
    no not under the hood, jsut from the drivers door allll the way back and the inside of the truck reeks
    Sep 2006
    Tennessee
    Check the fuel filter. It's mounted in that area inside the frame.
    Jan 2008
    North Stonington CT
    i jsut examined it again (the fuel filter) and it is not leaking at all. the smell is raw gas in the truck and outside of it
    WILL WORK FOR PARTS! chevy-aholic's Avatar
    Jan 2009
    Minnesota
    is anything leaking onto the ground yet??? If the smell is that strong, it should leave a puddle somewhere!
    Projects: (click for link)
    496SS: Roots-Blown 496 BBC, Custom backhalf, Parallel 4-link, T316 Stainless exhaust "Dual Path" w/ dumps, Lots of fiberglass!!!
    "Stock appearence, Strip Performance!"
    The Jeep: SOLD!!
    Jan 2008
    North Stonington CT
    no shocking nothing on the ground.
    Jan 2009
    Minnesota
    Quote Originally Posted by kiddcarbuff
    It has to be your vent line. Is it bent or broken right under the driver's door around the filter area. If there i no gas on the ground, then it can't be the supply or return lines (they drip fuel when they leak, leaving a visible puddle) the vent line is the only one that can leav and not swuirt gas out or alter the engine at all. I would even go as far s to say it would not show up in codes either!
    The Jeep: SOLD!!
