Thread: Driver side temp control - 2004 Silverado
Results 1 to 11 of 11
    Jul 2008
    MS
    I have a 2004 Silverado RCSB Z71 with manaul climate control. I'm having issues with the driver side temp control not working properly. It seems to always blow cold... which would be fine if it was summer. The passenger side works as it should... heat and a/c work.
    I found the tech article at this link http://www.fullsizechevy.com/forums/...king-99-a.html.
    I found the actuator and removed it to inspect and the gears looked good. I then reinstalled the actuator.
    I followed the instructions and removed the HVAC fuse etc..
    When I turned the truck on I was able to select heat and a/c. I turned the truck off and the next time I turned it on it was stuck cold again.. no heat.
    I'm assuming the actuator is good if the heat works sporadically. It also seems like every 10 cycles the heat will work as it should, then the next time I crank it ... no heat.
    It seems software related, but I'd hope it's something I could fix myself. I was thinking of going to a junk yard and getting a 05-06 model's actuator to see if there was a updated part.
    Has anyone experienced this problem with the driver's side temp control? It seems common on these trucks, but I can't figure why it's so sporadic.
    2004 Silverado RCSB Z71 with the 5.3
    Kiowa, KS
    Re: Driver side temp control - 2004 Silverado
    Needs an actuator. Its got a potentiometer in there (like a throttle position sensor) that goes out or acts up. My diagnosis consists of taking the Tech 2 and doing an actuator recalibration which typically renders the actuator inoperable. I go get one from parts and all is well.
    Just be happy it wasn't the passengers side. GM service info says pull the dash out. We have our methods though.
    Jul 2008
    MS
    I've heard the passenger side is a pain as well.
    Do you think I should go with a used junk yard part? Do you know if there has been an updated part also?
    I fixed the other problem I was having... no defrost. When I would select defrost it would blow only on the feet. Basically I only had front, front/feet/, feet. No defrost at all.
    I found where the air mode actuator was located and watched it's action with my head under the dash. It appears I must have jumped a few gears b/c it's travel never was enough to open the defrost. I loosened the air mode actuator and adjusted it's travel. Now I get defrost/feet when defrost is selected so I know I'm almost there. It got dark before I could adjust it some more.
    These actuators are pretty crappy. It seems to cause a lot of problems on vehicles. My daily driver's front door lock actuator went out which caused havic on the stock alarm system. I like my wife's accord... a cable does all the work for HVAC... it opens the heater core valve and manual moves air modes. No issues with it and it has 260K miles
    Jul 2008
    MS
    Bump... does anyone know if this actuator has an updated part # or should I go with a junk yard part?
    Registered User slicpartna's Avatar
    Feb 2002
    Bham, AL
    Quote Originally Posted by joutlaw
    i also have the same problem with my 04 avalanche but it is the passenger side.
    Is it wise to replace both actuators while in there?
    Feb 2002
    Bham, AL
    Quote Originally Posted by slicpartna
    bump
    Aug 2010
    alabama
    i have a simular problem on my 2004 silverado 5.3. I will have my truck on max air and on occasion the driver side will blow heat. The driver side blows over 100% and the passenger blows 50 in 95% weather. The wierd thing is when i shut the truck off and back on it works properly. Its not an emergency but annoying. So if you find a solution please tell they might relate.
    Thank you.
    Nov 2010
    nevada
    I am having similar problem. Lots of problems with 03 thru 07 HVAC, gm won't admit it. Unfortunately I had my battery die several times just for luck [some times you couldnt turn the fan off] in between not getting heat. No more GM for me.
    Quote Originally Posted by Mharris View Post
    Thank you.
    Old Geezers know stuff... dlstewart01's Avatar
    May 2005
    Tennessee
    The drivers side is on the 1st page, the passenger side in on the 2nd page...
    http://chevroletforum.com/forum/showthread.php?t=22624
    05 GMC Sierra, Ext Cab, 5.3
    "Never argue with an idiot. They will bring you down to their level and beat you with experience."
    3/5 Cav, C Troop, Blacks Knights, Vietnam, 1969
    Head Cook mrgrim's Avatar
    Jun 2008
    Philly
    You need to replace the actuators. I would not do JY parts as they may have the same problem. I got a set from rock auto and second
    set 2 years later from the dealer. Dealer parts seem to be lasting so far. I have the little deal with a 9 volt battery that plugs into the
    cig lighter for when the battery needs disconnected.
    04 ECSB 5.3 4x4 Z71
    06 Front clip, Reflexion steel hood, Escalade touch screen nav, Escalade wood steering wheel
    06 E Fans and Rad, 2 Alpine subs, 250 amp MechMan alternator, Dual battery with isolator
    05+ front brake swap, Suburban rear brake swap,Rusty door bottoms,Line X,PCM4Less tune
    Jun 2008
    Philly
    Double post
    04 ECSB 5.3 4x4 Z71
