Thread: Oil Leaking around the Oil Filter Adapter plate
Results 1 to 12 of 12
    Registered User BigLenny's Avatar
    Feb 2008
    Trumann,AR
    hey guys I just put a 3 inch suspension lift on my 1995 Tahoe and today while over a friends house he noticed oil dripping down on the ground, I crawled up under my truck and noticed Oil dripping from where the Oil filter goes in sideways to the adapter plate. It looks like its leaking from the plate but can't really tell. What i was wonder is there a gasket that goes between this plate and motor or could it be a rear main seal?
    Jan 2009
    st. cloud florida
    Re: Oil Leaking around the Oil Filter Adapter plate
    yes the is a gasket between it and the motor. you can get a kit at advance auto parts for like 10 bucks.. had to redo mine last month.. same problem
    Feb 2008
    Trumann,AR
    I take it, that its a pretty simple project? I just don't want to get in over my head.
    SE Michigan
    Quote Originally Posted by BigLenny
    2 bolts
    2000 Silverado 6.0 4L80E 2wd
    Registered User wp_camochevy's Avatar
    savage
    had the same problem make sure you loosen those oil cooler lines before you start i didnt and went pulling on them fixed the gasket put it all back on no leak for like 30 min motor got warm and noticed leaking again found out one of the oil cooler lines were cracked from pulling on them
    Jun 2008
    Eastern Shore, Maryland
    8 dollar kit from advanced auto comes with a couple paper gaskets and Orings(some not needed). 2 bolts like has been said. The hardest part is crawling under the truck. Good luck!
    1997 Sierra Z71 4x4 5.7L Vortec
    1994 Silverado Z71 4x4 5.7L TBI
    Feb 2008
    USA
    Nov 2008
    tenn
    No reason to undo the cooler lines from the adapter, just leave them connected. Mine had 2 allen head bolts holding the adapter on, I put some thread lock on them when I put them back in just to make sure they stayed in place.
    Feb 2008
    USA
    82560 Assortment contains various o-rings and gaskets to seal oil filter adapters and oil cooler lines
    Detailed Applications: Click Here
    Type: Oil Adapter and Cooler Gasket Assortment
    Make: Chrysler/GM/Jeep 2003-82
    OE #: 10244496, 12559583, 12559584, 15564870, 4720363
    Brand: Dorman - HELP! - Carded
    Application Notes: Please select Detailed Applications for Application Note information.
    https://www.dormanproducts.com/cgi-b...tegory_list=:0
    savage
    i had to take mine off it was easier to clean the adapter
    Feb 2008
    Trumann,AR
    thanks guys it was an easy job, got it doen with no problem
    Feb 2008
    USA
    Did you end up taking off the oil cooler lines?
