Thread: No Fuel From Injectors (TBI)
Results 1 to 20 of 21
    Registered User KodiakBlack's Avatar
    Jul 2008
    Westchester, NY
    today i decided to try and fire up the SS and no fuel was spraing out of the injectors. checked the fuse everything is ok. the fuel pump is working because we took the fuel line off going into the TBI and it poored fuel out. i wiggled some wires or something (idk what i did) and it sprayed for a little bit and started to fire up. turned it off and now nothing. cant get any fuel out of the injectors. does anyone know?? i checked the injectors resistance and they seem to be alright. ???????? im lost. all help is appreciated!! thanks!
    1994 2Door Blazer - 285/70-17, 2" PA BL, 2" Blocks, Trainhorns, Tints, 55w 6K HIDs
    1990 454SS - build
    Lanark, Ontario
    Re: No Fuel From Injectors (TBI)
    Show any oil pressure during cranking?
    Registered User 98crewcab's Avatar
    Aug 2004
    NorCal
    what year ? do you have spark?, if you poor gas in the throttle body will it run?
    Jul 2008
    Westchester, NY
    Quote Originally Posted by Quyonmob
    i havnt done an oil pressure check. what would that matter?
    Quote Originally Posted by 98crewcab
    i think so, it started to run when the injectors worked for a second. and it fired off starting fluid
    1990 454SS - build
    Jul 2008
    Westchester, NY
    its a 1990 454SS TBI, yes i think it is getting spark because it fired a bit
    1990 454SS - build
    Apr 2005
    Minnesota
    Fuel pressure regulator go bad maybe?
    Sep 2006
    fairborn,ohio
    Check the dizzy...mine had a crack in the magnet that wouldn't let the injectors fire.
    somewhere else
    #1 suspect is the ignition module; you can have one that will still spark but not signal the ECM to fire the injectors.
    The pickup coil can be an issue too, but I'd suspect the module first.
    The one thing that caught my attention though is that you said you wiggled some wires and it worked briefly. Take off your air cleaner and the spacer ring under it. Do you see any chafing of the injector wires where the spacer ring sits? This is a somewhat common area for the injector harness to get damaged and short, and it will definitely keep the injectors from firing.
    Richard
    Jul 2008
    Westchester, NY
    Quote Originally Posted by TEE
    i had the distributor off earlier to fix a snapped screw, so ill take a look at that. thanks!
    Quote Originally Posted by someotherguy
    Richard
    ill make sure to take a look at that!
    1990 454SS - build
    Jul 2008
    Westchester, NY
    bump for help! ps. i replaced the whole ignition coil, nothing! its not getting any spark at all out of the coil!
    1990 454SS - build
    Not active, no PMs
    Jun 2003
    West KY
    I'm def going with the ICM on this one. Had the same problem last summer and damn if it didn't happen right as I was getting ready to put the boat in the water. Cake fix, and realitively cheap. Just be careful with the harness and plug that go to the ICM, it's very prone to be weak and break... plastic is fail.
    1988 Chevrolet Silverado - Sold
    Project 88 Thunder Build Thread
    1987 Pontiac Trans Am [Restored]
    1988 Pontiac GTA
    2005 Trailblazer LT
    Aug 2002
    Slapoutoftown, AL
    yea man, i'm pretty sure your ignition module is to blame. the only reason i'm not totally sure is you said you "wiggled wires and it started working briefly", that leads me to believe either the injector wires might have chafed on the spacer ring as mentioned above or maybe a rat got into the wiring on its hiatus and chewed one partially. where did you wiggle the wire? if it was around the injectors, check the connectors to the injectors (to include the injector pins themselves) and then check the wiring. also check your grounds.
    but, about the ignition module, it is under the distributor cap, toward the firewall...has two plugs coming out of it. it controls spark AND injector pulse. pretty sure replacing that will fix your problem...even if the parts store tests it and it tests good...replace it. it's cheap to replace (about $30) and i'm pretty sure it's original on that truck...REPLACE IT.
    Jul 2008
    Westchester, NY
    Quote Originally Posted by FordeatinZ71
    yeah thats what im gonna end up doin, i cant get it to fire or do anything anymore by wiggling anything!
    1990 454SS - build
    Aug 2002
    Slapoutoftown, AL
    well, honestly, that wiggling thing might have been a coinkydink. those ignition modules can act weird when they're dying. on my '91, the first time it acted up i was on a trail. i had just kicked the truck hard sideways through a mudhole...and it died. i figured it got some water in it. tried starting it and it wouldn't do ANYTHING. just cranked over with no sign of firing. took me about 20 minutes of checking things under the hood and cranking attempts but then it fired up, ran rough...cleared up and ran GREAT. ran perfect for another week.
    fast forward a week...i'm on the same trail...same spot...it does it again! same scenario. still thought it was water...
    fast forward two weeks...i get stuck at the end of the trail...not in water at all...i'm letting the truck idle while i'm hooking stuff up...it shuts off like someone turned the key...first thought was ignition module...i was right...put it in, truck fired right up and never put a wheel wrong since...
    Jul 2008
    Westchester, NY
    just bought the module, so im gonna go put that in right now!!
    1990 454SS - build
    Aug 2004
    NorCal
    Did the module work?
    Registered User Cheyenne'88's Avatar
    Speedway
    I guess maybe he's checking the oil pressure by now.
    Aug 2002
    Slapoutoftown, AL
    Or he's out doing burnouts and playing with his new toy...lol
    Lanark, Ontario
    Quote Originally Posted by KodiakBlack
    Quote Originally Posted by Cheyenne'88
    I'm glad someone else is aware of the oil pressure switch.
    Too low an oil pressure = no fuel delivery.
    Registered User SEREOUS67's Avatar
    May 2011
    Anaheim,CA
    Old thread but I didnt get the result out of this issue... I had same prob. Cranked and sparked but no fuel out of injectors. It does run for a bit if I put a cap full of fuel down the throttle body. Im still thinking what else to look for but I will change the module and see what happens. Thanks for the tips.
