Thread: Proper vale adjustment
Results 1 to 11 of 11
    Oct 2008
    Fayetteville NC
    Ok i have read numerous threads looking for the proper valve adjustment for a vortec 350.
    I need to readjust my valves tomorrow and i was planning on doing them while the truck is warm.
    I was going to get the motor hot, remove the valve cover. loosen the rocker til it taps. tighten til the tap is gone then go 1/2 turn. i hear 1/4 turn, 1/2 turn 3/4 turn and 1 full turn. which is right?
    Dec 2004
    Elkhart IN
    Re: Proper vale adjustment
    1/2 turn has worked for me before. i dont like setting them with the engine running though, too messy.
    S.E. Wi.
    so GD how do you set em with the engine off? I have a set of slide on clips that go on the rocker arms and cover the oil holes, works great keeping the oil from shooting all over the inner fender panels.
    Dec 2004
    Elkhart IN
    haynes or chiltons manuals have a sequence on which valves to adjust with the #1 piston at TDC, then rotate it 180*, and to the rest of them. take the pushrod between your fingers, and roll it back and forth, when you get to the point that you start feeling resistance, go 1/2 turn more. works every time.
    Oct 2008
    Fayetteville NC
    thats the way i did mine grease but the manual i was using said to go a full turn after finding zero lash.
    Registered User jim27299's Avatar
    New Jersey
    I know the manuals say to do a full turn, but that is too much for me. I've tried going the full turn past zero lash and the truck runs rough; seems like a good way to bend a pushrod. I agree with using 1/2 a turn.
    1997 K1500 - Vortec 350, Edelbrock shorty headers, Magnaflow Catback, 0411 swap, Self tuned
    1995 Tahoe - TBI 350 with Vortec heads, 4WD, Edelbrock shorty headers, Flowmaster 50 series, Self tuned
    springfield, louisiana
    ok, when i did this, i went 1/4 turn, whats the engine doing after you do one? it seems to bogg down
    1997 K1500 Built vortec 355
    New Jersey
    Are you adjusting it when running when it bogs down? I always adjust the engine when cold now. Typically when you start the engine up after you have just adjusted the valves it will run rough for a few seconds until the lifters get pumped up with oil, but that's normal. 1/4 turn should be fine.
    If you adjust the engine when running it definitely will bog down for a second or two as you adjust each valve, but again this is normal as long as it doesn't stay like this.
    yea engine runnin, it stables out, bnut just wondering why it does tht
    S.E. Wi.
    James, GD is adjusting them the way I set my solid lifter lash on the race motor, the reason it will run funky when setting 1 turn while running and then starts to run fine is it takes awhile for the lifter to bleed off some oil pressure and it is hanging the valve open a tad bit. The best setting is 1/2 turn after the noise is gone, so I just set them till they no longer clack, shut the motor off and then do 1/2 turn on each valve, let the lifters bleed off and then restart the engine back up.
    o, ok. thanks for clearing that up for me mudbuddy.
