Thread: changing the Transfer case fluid?
Results 1 to 6 of 6
    Nov 2008
    PA
    Can anyone tell me how to change the Transfer case fluid in a 93 K1500? photos etc. The haynes manual i do not thing does a good job explaining this.
    2005 Chevy Tahoe, All Wheel Drive, 4.10, 5.3L
    1993 Chevy K1500 4x4, 175000 miles, 350
    D to the MAX gr8shot's Avatar
    Jul 2008
    Grand Island, NE
    Re: changing the Transfer case fluid?
    Very very simple. There are two plugs. One at the bottom of the case and one at the top. Take out the top plug first, then the bottom plug. Let the fluid drain out. then put the bottom plug back in, and refill the t-case with ATF until it's to the bottom of the fill hole, and put the plug back in. It's every bit as easy as it sounds.
    Australian Chevy
    Melbourne, Australia
    Yep! I use a sports drink 'squeeze' bottle (like you carry on a push bike).
    I screwed a 3/8 hose barb into the drink nozzle and fitted 12" or so of clear tubing onto it. This way I can turn the bottle upside down whilst laying under my Burb and squeeze the bottle to fill the T/fer case.
    Howard
    YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T
    MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE
    DUCT TAPE.
    98 K1500 Suburban, 4L80E, Whipple SC, Marine Intake, Hydroboost, LS1 0411 PCM.
    Jul 2008
    Grand Island, NE
    Thats a good point. I failed to mention that it's kinda hard to get the bottle up there to fill. I actually used the pointy screw on tip thingy that comes on bottles of diff fluid. Worked amazing and screwed right on to the ATF bottle.
    Nov 2008
    PA
    can any one tell me how many quarts go in the transfer case? I am assuming the ATF is the same grade as whats in the tranny?
    Registered User putz65's Avatar
    Dec 2008
    Grand Marais, MN
    Yes use the same ATF you would put in your transmission. I think it takes 2 to 3 quarts.
    98 Chevy ECSB Z71, 5.7L, 4L60E
