Thread: How cold will a Duramax start?
Results 1 to 20 of 38
    Registered User TheDozer's Avatar
    North Branch MN
    I am considering a duramax but my biggest concern is it gets cold up here in the winter! How cold can it be outside before I am going to have problems getting it started without pugging in the block heater?
    Sep 2008
    Pennsylvania
    Re: How cold will a Duramax start?
    Diesels really aren't as bad to start as people make them seem, especially glow plug Diesels like the Duramax. It's probably going to get down to at most 0-10 F before you start running into real issues. I know in 50-70 F they fire right up with literally an instant glow cycle. I'd worry about the fuel gelling before I'd worry about it not starting due to cold weather. It is, however, better if the block heater is plugged in. It may also be smokey and rough in cold weather until it warms up a bit.
    1994 K1500 ECSB 6.5/4L80-E
    1987 V20 Suburban DRW 6.2/TH400. WIP.
    Registered User Mantovanelli's Avatar
    Nov 2008
    MIAMI
    Glow plugs eliminate the huge problem of cold starts.
    CHEVY 4 LIFE
    1995 3500 grounded, 6.5T all the toys
    1964 IMPALA (low&slow)
    1984 Kawasaki 750GPZ TURBO (low&stupid fast):aniteef:
    North Branch MN
    Quote Originally Posted by RCpullerdude
    Im not worried about if its 0 to 10. That is a pretty nice day in January here! Its when its -15 and it is sitting out where it cant be plugged in Im worried about.
    Registered User Farmer98's Avatar
    WA
    You will want it plugged in at -15
    06 truck
    Registered User dozerboy's Avatar
    TX
    Dmax are one of the best cold starting diesel engines. While its a good idea to plug them in below 0F they will start without issue in the -20sC. Fuel gelling is your main concern and seems to be somewhat more common issue with the Dmax. GM has came out with a new fuel filter that should fix that issue. The main source of the problem in the new ULSD fuel and being blended with Bio fuel which raises the freezing point a lot.
    These views expressed on this post are not my own, but rather randomly generated computer gibberish and in no way should be used to judge the author's IQ or mental health.
    Registered User chrisk1500's Avatar
    Canada
    MN does not get cold compared to up here.....
    No issues with my 6.5 or my TDI...friends with DMAXes don't have issues either. Of course, common sense has to be applied and you need to plug them in...
    07.5 LMM DMAX 2500 HD, ext cab, 4x4
    Registered User 98[GMC]z71's Avatar
    Nov 2007
    Gower, Missouri
    Anything under 0 your gonna want to plug it in.
    "Sex is like a casino, liquor in the front, poker in the back"
    98|GMC|Z71|5.7|CAI|TrueDuals|31/10.5/15|Eagle Alloys|4 HI headlight mod w/ 8000k HID's|RockfordFosgateT300-2|PioneerHU|Kenwood:fsg:
    2006.5 LBZ Duramax|4'' MBRP|Diablo Predator|Resonater Block off|L.E.D. pod gagues |
    North Branch MN
    What Im worried about is when it has to sit somewhere and it has to sit out and cant be plugged in. If its -15 is it going to start? Like I said sometime plugging it in is not an option.
    Sep 2008
    Pennsylvania
    Quote Originally Posted by TheDozer
    You have a PM
    Canada
    Webasto is the answer in that case....
    North Branch MN
    Whats Webasto?
    TX
    Didn't I answer this question? A Webasto is a heater that cost about $3K that burns a small amount of diesel to heat and circulate the coolant. Very handy to have and beats idling a lot, but not a necessity.
    dave94K1500
    get a gasser no problems here under zero degrees.. and you dont have to plug em in.
    Registered Abuser
    Nov 2008
    Morris, IL
    A friend of mine bought a duramax, he loved it. But with his job, he had to park the truck for weeks at a time in the winter at the shop where he and other employee's meet, and go out of state to do work.
    He sold the truck, because after weeks of sitting at cold temps it would not start.
    Now, my duramax I maybe plugged in only a few times this winter.
    Even on the coldest days, it never failed to start, although it did gel up on me, once.
    Even when it gelled, it still ran good, but stumbled on its face during accell.
    If your going to have it running daily, you shouldnt have a starting issue, but Id say if it sits for days, or weeks... you'll probably definatley have an issue over time.
    I could be wrong, but I thought I heard with that webasto heater, that it uses about a gallon of fuel every 4 hrs ?
    D to the MAX gr8shot's Avatar
    Jul 2008
    Grand Island, NE
    Search youtube. Plenty of vids on cold starts on a dmax. They definently start better than a 12v or a powerjoke. Even the 6 leaker powerstroke doesn't start very good when cold. The dmax's will fire right up, so long as you put some additives in to keep em from gelling up. That will be a problem before not starting will.
    If it's plugged in, you won't even notice it's cold out. If it's not, it'll still start up no problem, but just kick the high idle on to warm it up faster.
    CT
    sorry, old thread, but if anyone tells you duramax's wont start in the cold they are full of crap.
    Here is mine starting at -7* without being plugged in, lower than stock compression, and ON ONLY ONE BATTERY.
    http://www.youtube.com/watch?v=6iA72Mzv9ek
    ben
    05 silverado crew cab short bed LT. fast.
    Dmax/Ally
    (not the same motor it came with from the factory)
    fairbanks alaska
    you can do pad heaters on the tranny pan and oil pan and the block heater as well and thats the standard for here in alaska and they will start if you don't have weak batteries also get the glow plugs nice and hot by turning them on 3 or so times, theres a company called zero start that actually has a coolant heater which runs a mechanical pump tapped into your coolant lines and we install those on most our heavy equipment which is also diesel and they get amazingly warm fast, hell even some of our diesel powerstrokes not plugged in at 40 below will pop off if you hit the glow plugs a few times, i wouldnt recommend doing it to your personal truck, its kinda rough on the motor
    Bow Down Justin_Inc's Avatar
    Aug 2007
    Garson, Manitoba
    Quote Originally Posted by alaskadg87 View Post
    cold starts are a 100 times harder on a diesel than any gas engine, Sure they may start but i dont know why anyone would want to put they're engine through that, plug the bugger in and if you cant plug it in all the time invest in a Wabasco or Espar coolant heater. You can program the Espar/Wabasco heater for 7 days to automatically come on when ever you want for how ever you want. they draw about 1amp/hr and burn about a liter of fuel in 4hrs.
    **Flat Broke Racing**
    1989 Chevy RCSB Stepside, 427 LSX block, PT106 turbo, Lenko 6spd Manual, Moser M9 rear, tube chassis, full cage, NBS front clip, rear step shavers, Zo6 seats, A/C, 1050hp street tune and daily drivable!
    fairbanks alaska
    if your on a budget buy the pad heaters and block heater and run them to a three way splitter, this is the standard up here and it works
