Thread: Engine Misfire P0300
Page 1 of 3 123 LastLast
Results 1 to 20 of 45
    Registered User GMSEE's Avatar
    Nov 2008
    USA
    1996 GMC K1500 XC 5.7L SFI
    My truck is misfiring. It is giving the code of P0300, which in my Haynes book says "Engine Misfire". It is running really rough consistent with a misfire. I've driven it around town and it is really down on power. I can't figure out what could be the problem. The motor is shaking pretty bad a certain RPM's. I have dual exhaust that is completely separate on both sides. One side of the exhaust is throbbing a lot more than the other side. Can't hear or see anything else weird in the motor.
    OK, so I've replaced:
    1. Both O2 sensors (pre-cat)
    2. Camshaft Position sensor
    3. Crankshaft Position sensor
    4. Spark Plugs
    5. Plug Wires
    6. Cap and Rotor
    7. Fuel Filter
    8. Cleaned MAF sensor
    9. Ignition Coil
    I don't know what there is left to do... I've done everything I can think of.
    Is there anything else that could be causing a misfire??? Or I could try changing????
    Hired Goon Aloicious's Avatar
    UT
    Re: Engine Misfire P0300
    Quote Originally Posted by GMSEE
    4. Spark Plugs
    5. Plug Wires
    6. Cap and Rotor
    7. Fuel Filter
    9. Ignition Coil
    common causes of P0300 in the L31 motors could be the injector spider problems, fuel pressure regulator leaking, and intake manifold gasket leak. good luck, these radom misfires can be a pain to track down sometimes.
    EDIt- forgot, the dizzy gear can get worn in these trucks and cause the p0300 also.
    Aug 2008
    Vacaville, California
    does it still have cats? im assuming it doesent but you know where that can get you.
    Nov 2008
    USA
    Yes still has cats. It has two separate cats. What is the spider gear?
    UT
    spider gear? no, the dizzy gear is the gear on the bottom of the distributor that mates with the cam, the injector spider is the fuel injecting aparatus on the L31 motors, it consists of a fuel metering body and 8 poppet valves to act as fuel injectors, it looks like a spider is why its named that.
    here's some posts to help:
    http://www.fullsizechevy.com/forums/...m-misfire.html
    http://www.fullsizechevy.com/forums/...-misfires.html
    Nov 2008
    USA
    OK, thanks for the info. Does anyone know about the MAP sensor?Would this be causing a misfire? The Haynes book says the MAP sensor uses intake pressure to tell the PCM how to control fuel delivery and ignition timing.
    I've already replaced everything else that has to do with ignition timing.
    One thing to mention is when I put a spark sensor (non-invasive) on my wires and cap it only shows a spark every so often and very very random. Sometimes I won't see a spark for up to 10 seconds . It's completely random on every wire. When I put it to the coil wire it shows a constant light. Why would the spark to the plugs be so random?
    UT
    the MAP sensor is the "Manifold Absolute Pressure" sensor, it tells the PCM what the vacuum is in the manifold so the PCM can calculate the fueling. its possible that it could cause a misfire, but pretty unlikely. I'd really bet it is the distributor gear, that is a very common part on our trucks that will cause a P0300.
    I don't know abou the spark light, I would manually pull a few (one at a time) plugs, ground them and check for spark while someone cranks the engine over, if they were firing in 10 second intervals, the truck wouldn't even run. however, the goofy readings do suggest a spark problem over a fuel issue. which again, would point to the distributor gear being worn or a cap/rotor issue since the readings at the coil are consistant.
    does the cap bolt down tightly? there is a high likelyhood that the screws that hold the cap down have stripped or broken the plastic tabs on the distributor that they screw into, I had that happen to me and it wouldn't let the truck run at all. I have since put in a aluminum distributor to stop that from happening again.
    Aug 2008
    the way you described the exhaust would make me think about possibly a clogged cat but idk.
    Nov 2008
    USA
    on my motor the timing is set by the computer, so if I take the distributer out to replace the gear, how do I know how to put it back in correctly? Is it just by making a mark on the housing of the distributer where it meets the motor?
    Australian Chevy
    Melbourne, Australia
    Mark iot all before you take it out. If the gear needs changing, do so and then re-install exactly as you removed it. I always take a heap of pic's of everything I do....handy reference!
    You may need to get the CMP retard set by someone with a scanner once you replace the dizzy gear.
    Howard
    YOU ONLY NEED TWO TOOLS IN LIFE - WD-40 AND DUCT TAPE. IF IT DOESN'T
    MOVE AND SHOULD, USE THE WD-40. IF IT SHOULDN'T MOVE AND DOES, USE THE
    DUCT TAPE.
    98 K1500 Suburban, 4L80E, Whipple SC, Marine Intake, Hydroboost, LS1 0411 PCM.
    UT
    Quote Originally Posted by Da Burb
    yup, mark the dizzy before you pull it, that way it will run when you put it back in, I would take it somewhere that has a scanner able to read the CMP retard and have the timing set, shouldn't cost much, even at the dealer I would think it would be a pretty routine thing.
    Nov 2008
    USA
    If I take it out and replace it exactly the same way why then would I have to have the timing reset?
    UT
    it would run but the timing on these is VERY sensitive (VERY we're talking a couple degrees could be like 1/16 of an inch turn), when I pulled my dizzy last time, I put it back in the same as when I took it out, and in reading the CMP retard with my efilive, it was still 14* off. you may have it close when re-stabbing it but chances are its not super precise, best just to get it set. the CMP retard needs to be at 0* +- 2*. you can definantly get it close so that it will run just fine w/o codes, but I'm too OCD to not have it set correctly on my truck, Howard will agree with that I believe. :aniteef: .
    Australian Chevy
    Agree 100%. The damned things are so sensitive that just tightening the hold down clamp can throw them out a few degrees.
    Howard
    DUCT TAPE.
    Nov 2008
    USA
    cool, I'll let you know how it goes. Thanks for the help.
    Registered User CscottsSS's Avatar
    Dec 2004
    Lexington, KY
    fuel pressure regulator........
    1996 C1500 ECSB
    1988 Mustang GT vert'
    1996 BAJA 240 Islander
    Nov 2008
    USA
    So, got a new dizzy gear and noticed that the teeth were not the same as the original ones. They were a little more curved and thinner. I chose to install it anyway and holy crap that was a mistake. I heard a loud clanking while trying to start it. I pulled it back out and reinstalled the original which actually didn't look too bad. When I reinstalled the original I put it back in at TDC on the exhaust stroke. So had to reinstall it again in the real Top Dead Center, but couldn't get it to start. The timing must have been way off. I put it all back together correctly, and it would start but would just sit there "dieseling" (if that makes sense) no throttle response at all. Basically was not running. Had to get it towed to a local mechanic and will update you as to what the problem ends up being.
    May 2004
    florence alabama
    I have seen this more than once. Here is a GM TSB
    Subject: SES Light and P0300 when Towing, Cruisi #PIP3081: SES Light and P0300 When Towing , Cruising Uphill or on Hard Acceleration - kw 4.3 5.0 5.7 accelerate cruise cylinderhead DTC L30 L31 L35 LF6 LU3 P0300 P0301 P0302 P0303 P0304 P0305 P0306 P0307 P0308 - (Jul 23, 2004)
    Subject: SES Light and P0300 when Towing, Cruising Uphill or on Hard Acceleration
    Models: .
    The following diagnosis might be helpful if the vehicle exhibits the symptom described in the PI.
    Condition/Concern:
    The vehicle may exhibit a SES Light due to a P0300 and misfire. If the misfire is related to the information below, it will typically happen while cruising uphill, pulling a trailer or on hard acceleration and then stop misfiring shortly after returning to an idle. Typically, cylinders 3,4,5 or 6 will be the ones to experience this.
    Recommendation/Instructions:
    If the P0300 SI diagnostics did not isolate a concern, the following may help:
    Remove the valve cover, valve springs and valve seals on the effected cylinder or cylinders. A small wire tie or rubber bands can be placed in the valve stem keeper groove to prevent the valve from falling into the cylinder. Rotate the valve while moving it up and down in the guide to see if it binds. If a binding valve is found, remove both cylinder heads and use either of the following methods to increase the stem to guide clearance:
    Send the head out to a machine shop and advise them to increase the valve stem to guide clearance to 0.002 inch per guide.
    Hone the guide with a 9 mm hone, such as Snap On BCG249, until a clearance of 0.002 inch is obtained. This will usually take about 4 strokes of the hone.
    Reassemble the cylinder heads using new valve seals.
    Please follow this diagnosis process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed. If these steps do not resolve the condition, please contact GM TAC for further diagnostic assistance.
    Models:
    (96 - 02 Chevrolet Astro) and (96 - 02 GMC Safari) and (96 - 00 Old Body Style Chevrolet Suburban) and (96 - 00 Old Body Style Chevrolet Tahoe) and (96 - 02 Chevrolet Express) and (96 - 00 GMC Yukon) and (96 - 00 Chevrolet Old Body Style C/K Truck) and (96 - 00 GMC Old Body Style C/K Truck) and (96 -02 GMC Savana) and (96 - 99 P32 Cab and Chassis) and (96 - 02 Chevrolet S-10) and (99 - 02 Chevrolet Silverado with 4.3L V-6 Engines (96 - 02 GMC Sonoma) and (96 - 02 GMC Sierra with 4.3L V-6 Engine
    " Patton said it best " Wars are not won by dying for your country, wars are won by making the other poor son of a b#### die for his country! "
    Nov 2008
    USA
    So, I had to take my truck in to a mechanic, not to mention have it pulled from an underground garage and loaded on to a flatbed. Let me tell you, seeing that almost made me cry... Took it to a good mechanic and he told me that the #5 injector is bad. So he is replacing the whole injector spider with a new acdelco setup its going to cost me $1000 in all including diagnostic and reseting the computer to the distributer shaft, but in the end I think it'll be worth it. I've learned a whole lot about this beauty of a truck, pored my blood sweat and tears into it and now love it more than ever. Hopefully it'll run better too! I called the dealership and they told me it would be $1100 all together to replace the injector spider. I opted to do it with the mechanic because he was only charging me 809 for the whole injector replacement with the new updated MPFI injectors. I found this site (link below) that explains a little about Vortec CSFI to MPFI conversion. Look at it theres tons of clear pics...
    http://www.theautoshop.net/VortecMPFI.htm
    Nov 2008
    USA
    The truck is done! Runs really good compare to how it ran before. The price total from all work and diagnostics done was $993. Anyways they gave me the old injectors and they looked like crap. I'll take a pic before I toss them and post. The truck, however, still has a slight misfire... Pretty much when driving on the freeway under cruising load I can feel it missing. Sometimes it's worse than others. The check engine light only comes on if I drive it long enough and its the same code, P0300. I took it back to the shop and they say that there is nothing they can do. I think they are just screwing me over. Any Ideas?? Also, on start up about 50% of the time it misses then fixes itself. The other 50% it lights up just fine. Thinking dizzy gear now??? But if it were something like that (mechanical) wouldn't it be happening the same way constantly? It seems to me with the intermittent misfiring it's electrical of some sort. But what?
