Thread: Replacing Universal Joints in 1990 Chev Pickup
Results 1 to 15 of 15
    Nov 2008
    Canada
    I have to replace my 2 universal joints on my 1990 chev 4x4, on the rear driveshaft.
    I doubt it will be hard getting the old ones out :).
    BUT putting the new ones in, do they just go in place easily on the shaft? Or must the cups be pressed in? or is it easy unboltbolt and replace?
    Seems the last guy that did them had a bit of a hard time and used a vice to push the new universals in? He later realized he had the wrong universals and it SEEMED to go easier after getting the right ones... Will I need a vice to press these in?
    Your response appreciated.
    From Mini to Fullsize.... Hotwheelz's Avatar
    Oct 2005
    Jasper, Indiana
    Re: Replacing Universal Joints in 1990 Chev Pickup
    a vice makes it 10x easier. use a vice and a socket that fits just inside u joint to press it in.
    2009 GMC SIERRA | SLAMMED 5/7 | 22" BOSS 330'S | ASE MASTER CERTIFIED
    Dec 2004
    Elkhart IN
    actually i put most of mine in, and remove them with an air hammer. takes a little finesse but its quick and easy.
    Bangor, ME
    I roll with the vise, plus hammer and socket method.
    I'd ruin it with an air hammer.
    2014 Silverado 1500 Z71, leveling kit, SOLD 8/2016
    2016 Silverado 1500 Z71, 6.2 V8, all stock
    Nov 2008
    Canada
    ANY Tricks to doing it so you don't end up with the pins/bearings all over the shop floor and falling out?
    Dec 2004
    Elkhart IN
    yeah, i've ruined a few in my day.
    as for tips... be careful, and pay attention to what you're doing.
    Registered User DirtyJoe's Avatar
    Dec 2008
    Florida
    Make sure you remove the inner clips before hammering...Do not ding or dent the drive shaft...and put a rag under you work area...A bad u joint is bad because the bearings are shot..I have seen them fallout all over like toothpicks and like fall out like dirt.....keep the new caps free from dirt.
    1996 Tahoe 5.7
    1995 Camaro Z28 LT1 Convertable
    1998 GMC Sonoma 4x4
    1996 Toyota Tercel ( The Frog )
    1987 Dodge Dakota 4x4 on Boggers
    Oct 2005
    Jasper, Indiana
    a couple tips:
    go slow and check often to make sure the joint still spins freely. if it doesn't, meaning it kind of catches every now and then, one of the bearings, or several are out of place. they come pre greased to help avoid them falling out. still be careful, because they will still want to.
    Nov 2008
    tenn
    I will usually add more grease to the cup to make sure the needle bearings dont fall out. Dont be shocked if you ruin at least one cup trying to get it in. To avoid the headache, I have a machine shop near by that will press both joints in for $15, BEST money I can spend.
    Bangor, ME
    x2 on adding a dab of grease and just being careful.
    You should be shocked if you ruin at least one cup. That's not right. I've never ruined one putting it together and I've done quite a few on the ground at off road parks and in driveways.
    Nov 2008
    Canada
    So the best thing to do is pound out the old Cup(s) with a socket...
    When I go to put the new one in, your best suggestions is to add a dab more greese inside the cup? Im going to be tapping it with a socket and a hammer, so I am going to guess the bearing needles will want to fly out.
    Any other suggestions?
    UNDER CONSTRUCTION.......
    Nov 2003
    indiana
    ive always used a press. makes it really quick and easy to do! if in doubt just take the driveshaft to a shop that has a press and have them do it. should be quick and cheap!
    using a press you dont have to worry much about the needles falling out since your not wacking it with a hammer, just slow pressure to slide right in.
    97 C1500 Extended cab 3rd door 5.7, 4/6 djm drop, 30bar billet grill
    need any OBS parts and some NBS parts PM me. im a junk yard whore and go all the time.
    tho please small parts for shipping
    Dec 2004
    Elkhart IN
    dont forget heat. i know my 92, as well as Black Sierra's 92 still had stock ujoints in them within the last year. you'll need to heat them up to melt out the factory injected plastic retainer. once its out, clean out the groove, and install your new joint.
    Nov 2008
    Canada
    Thanks guys for your help!
    Registered User chevy6490's Avatar
    Jun 2007
    Maine
    Mine went in to my 99 piece of cake, 20 minute job tops.
    2008 Silverado Z71 Max, L76 6.0, 4L70E, 14bolt Rear, BlackBear AutoCal, Intake, Actuated Strait Pipe, Leveled, LineX, Detroit TruTrac
