Thread: 1989 454 specs & info
Results 1 to 6 of 6
    Registered User zapc's Avatar
    ny
    I was given a 454 out of an 89 suburban, gonna rebuild it, throw a carb on it and drop it in my 89 stepside. i know most of you are real negative on these later big blocks (no power) but i gotta assume that with a good set of aftermarket heads,cam,carb,
    & intake that i should get big time torque out of it. the bottom end of these motors should be fine, they were just crippled by bad heads & small cams. is that correct? I cant find any info on these motors . just earlier ones. looking for compression ratio, how many cc heads, when did the roller motors come out, i know on
    late 80's small blocks, most are machined for roller cams,are the big blocks the same? any info, and sites to go to would be a huge help thanx all
    Administrator 454ss's Avatar
    Jul 2001
    Staten Island, NY
    Re: 1989 454 specs & info
    Chamber configuration:119cc Open chamber
    Compression ratio: 7.9:1
    Intake valve diam.: 2.06
    Exhaust valve diam.: 1.72
    Go to http://www.454ss.com there is a ton of info there.
    click signature for pics
    90 454ss
    92 454ss
    08 Avalanche
    I wish people were like slinkys, fun to play with but when I get bored I can push them down the stairs.
    ny
    how different are the ss motors from the regular motors
    May 2007
    house
    if you rebuild it right i will be better then a vortec
    Jul 2001
    Staten Island, NY
    Quote Originally Posted by zapc
    90ss has the same HP, 91-93 had 25 more due to exhaust and intake.
    90 454ss
    92 454ss
    08 Avalanche
    ny
    the 454 came out of a 2 wheel drive suburban, going into a 4x4.
    will it have the correct oil pan? also ive been told that the 454 flywheel should have the 700r4 bolt pattern and the turbo 400, is that true.
    this is avery stout heavily worked 700r4. should survive a while with a stock 454.
