Thread: What temperature should my transmission be?
Results 1 to 20 of 23
    Aug 2008
    Seattle
    I recently installed a transmission temperature gauge in my Suburban, but I don't really know what the expected temperatures should be. It seems to run about 150 on side streets and drop to 125 after several miles on the freeway.
    I have a 96 K1500 with the stock trans cooler and 3.73 gears.
    Kentucky
    Re: What temperature should my transmission be?
    In theory it should be pretty much the same temp as the engine. Sounds kinda cool, which is certainly a good thing if it's right.
    Nov 2008
    Wisconsin
    Quote Originally Posted by shadowdub View Post
    My sending unit is in the pan, and my temps are identical to yours with my stock cooler. 97 x-cab 4x w/ 350.
    -Jared
    Registered User bigtfw2000420's Avatar
    Oct 2005
    south tx
    well i got the trans gauge in the test port and when gettin on it. would get up two 180-186 and just flipin through town 165-175
    now i bought a hayden cooler part #678 and now it stays around 145-155 with the cooler. also it get hot in the south. and i see your up north. but when your on highway it will go down a little and having AC on will make it go up too.
    :fsg: 98 k1500 5.7 Magnaflow exhaust BBK 80 mm throttle body AEM brute force CAI nelson performance tune 93 octane RC 6" 285/70/17 BFG KM2 4 14 bolt sf disk brakes 4l60e fully built
    AL
    As cool as possible, well, not freezing. The highest ive ever seen mine is 150 and its plumbed through the radiator (195). I have a tru-cool 40k gvwr cooler and it works great.
    When I saw the temps go 200+ on the stock cooler I said thats it, and bought the biggest one I could find.
    Aug 2008
    Seattle
    I am thinking I should upgrade my cooler as well. I have only towed my boat once since I put the gauge in but I was flirting with 200 coming up a ten mile long incline and I had a lighter load in the truck than I usually have when I cross the mountains.
    Oct 2005
    south tx
    my thought is if u have big tires u play in mudd or tow anything putt a tranny cooler on. rather spend 50 bucks now then 1000 later on transmission
    Aug 2008
    Seattle
    Will I be able to buy a larger cooler that will work with the existing lines?
    AL
    yep, mine came with 4' of hose that attached to the existing lines.
    Oct 2005
    south tx
    u will need a fitting for the factory tranny cooler
    I Hate You All, Equally.
    Hell, Frozen Over.
    I believe anything over 180 could mean death for the 4L60E. No matter what though, every auto can benefit from upgraded cooling. Your tranny will last longer and shift more consistently, which is a definite plus.
    Oct 2005
    south tx
    i know my buddy was laughing when his tranny got to 220 on the beach i told him just to spend 60 bucks than 1000 later
    Aug 2008
    Jackson, Missouri
    http://www.transmissioncenter.net/FluidChart.jpg i think this chart has been posted somewhere but here it is.
    Hell, Frozen Over.
    Quote Originally Posted by sw45 View Post
    According to that chart i was way off, but i'm pretty damn certain you want to have your 4L60E below 180 though. Worked with a guy who had his 4L60E blow up within 60,000 miles (90,000 kms). which was a 99 or 2000 RCSB 1500 with 4.3L. so it wasn't under too much stress really.
    Registered User haulinit's Avatar
    ottumwa,ia
    Anything over 210 start really watching it. For every 10 degrees of temp after 210 will shorten your fluid life by half. So 220 half, 230 now down to 1/4 of the life and ETC... If you did like I did before I had a temp gauge and cook it to where it puked out the vent tube then I feel your pain. I also agree anybody with a 4l60 should have a good cooler and temp gauge.
    98 silverado 4wd 3.73gears,5.7l,headers,under drive pulleys,78mm ported and polished tb, k&n fipk,catback, zz4 cam, roller rockers, lt4 valve springs, 411 swap tuning by me.
    Quote Originally Posted by Redneck Rebel View Post
    fsc demo derby time. Would've been a better disposal system than the Cash4Clunkers BS
    OBS 4X4 HOE! bai78's Avatar
    Dec 2008
    Rowlett, TX (Dallas)
    Anyone know the variance from having the tranny temp read by the OBDII versus a sensor in the test port or pan. IIRC, there is 10 degrees from the pan to the test port.
    1999 Tahoe LT: ProCharger, BBP Tune, 411 pcm.
    - In Progress: Marine Intake Swap with LS3 injectors
    2002 Denali Yukon XL: MP112
    ottumwa,ia
    No I have mine in the test port, I have often wondered that.
    Aug 2001
    New Jersey
    Anything under 200 is fine. :read:
    Aug 2001
    New Jersey
    Quote Originally Posted by bai78 View Post
    I doubt it. I believe GM gets the reading form the test port on the newer trucks. Not 100% sure though.
    Oct 2008
    Las Vegas, NV
    My Trans temp is identical to the engine temp. My 94 G2500 Van's factory cooler runs through the radiator, so thats no surprise. I run between 170-190. Iv'e attempted to heat it up with WOT for the bulk of a 6000' climb in elevation with no effect on temperature. Love my 4L60-E!
