Thread: cam retard ?
Results 1 to 15 of 15
    May 2005
    sc
    cam retard ?
    1997 4.3L my cam retard is -10deg. is this right its skipping like a three legged dog and missing on seveal cyls ive changed plugs,cap, button,and wires. and the skip got worse. any ideas oh egr shows close when warm but tested good. thanks ave.
    :bowtie:HIGH SPEED DIRT!!!
    Registered User toomanyballs's Avatar
    Jul 2007
    north branch michigan
    Re: cam retard ?
    the cam should never be out of time i think you mean that the ignition timing is out and if so then all you need to do is losen th distributor and then adjust it to spec. with a timing light or you can just do it by hear till it sounds good enough for you. but i believe that the timing on those engines is controlled by the pcm so there shouldn't be any problems with timing, i would look in other directions
    May 2005
    sc
    Re: cam retard ?
    timing chain?
    Jul 2007
    Re: cam retard ?
    is it throwing any codes or just running shotty?
    Dec 2001
    nixa, Mo
    Re: cam retard ?
    Your cam retard should be -2 to +2 so yours is off and is probably why the truck is not running right. You will have to set the cam retard by hooking up a scanner that reads cam retard, loosening the distributor hold down clamp, and reving the engine up to 1500 rpms while turning the distributor until you get the cam retard into the range mentioned above. Tighten the hold down clamp and recheck the cam retard to make sure its still within specs.
    Wayne
    May 2005
    sc
    Re: cam retard ?
    Quote Originally Posted by toomanyballs View Post
    no codes sometimes i think it about to lay down.
    May 2005
    sc
    Re: cam retard ?
    Quote Originally Posted by wtd View Post
    Wayne
    i'll give it a try but why would it all of a sudden change?
    May 2005
    sc
    Re: cam retard ?
    Quote Originally Posted by ave View Post
    anyone else have ideas
    Jan 2007
    Missouri
    Re: cam retard ?
    timing chain loose and jumped a tooth
    May 2005
    sc
    Re: cam retard ?
    got a po300 this morning still dosent tell me much
    Jun 2002
    Wisconsin
    Re: cam retard ?
    whats the fuel pressure? Cam retard spec for the 4.3 is +/- 20 degrees
    Mar 2003
    Denison, Texas
    Re: cam retard ?
    Quote Originally Posted by JeremyB View Post
    Vortec V6 and Vortec V8 is +/- 2 degrees. My Chilton says the V6 dist is not adjustable, not sure about that.
    :nutkick:
    SE Michigan
    Re: cam retard ?
    10 degrees won't cause the issues he describes, but, yes, it should be corrected
    2000 Silverado 6.0 4L80E 2wd
    Jun 2002
    Wisconsin
    Re: cam retard ?
    Quote Originally Posted by dave89iroc View Post
    I agree that 10 degrees wont cause the problem, my 305 was at -11 for a while and was only slightly noticeable during one condition, over 45 mph on a slight downhill slope and it would misfire once in a while.
    It could be that the distributor gear is getting worn.
    The pictures of the 4.3 distributor in my service manual show that the hold down clamp is actually part of the distributor and it states that the 4.3 distributor is nonadjustable.
    St. Paul, MN
    Re: cam retard ?
    Quote Originally Posted by bwood View Post
    JeremyB is correct. The Vortec 4300 has a much wider spec for the cam retard then the V8's do.
