Thread: 2000 silverado 5.3 has no pulling power
Results 1 to 11 of 11
    Registered User Mr.Smiff's Avatar
    Nashville, Tn
    I got a 2000 Silverado 5.3 2wd with 97000 miles on it. It has a ruff idle and jerks when climbing hills. It doesnt have any power when pulling a trailer ether. The check engine light isnt on. I put new sparker plugs and fuel filter in it when I got it 2 years ago with 53000 miles. What do yall think is wrong with it?
    Its only money.
    Dec 2008
    North Carolina
    Re: 2000 silverado 5.3 has no pulling power
    Are you up to date with oil, oil filter, air filter, Basic tune-up stuff?? If it jerks when under a more severe load, but just has low power when under normal load, i would start by looking into your electrical system. Have your alternator checked(they have been known to cause vehicle to idle low, and respond jumpy) when they are starting to die. Also have your coils(little black box attached to every spark plug wire). If it is still driveable then try to check all you can before getting a mechanic to do it. Also does the situation get worse when it is wet outside? have you drove the truck through deep water?
    Registered User zebra86's Avatar
    May 2009
    nas pensacola
    44000 miles on a fuel filter is also not the best idea.
    is the air filter really dirty? that can also cause it to fall on its face when you mash the pedal.
    Nashville, Tn
    Quote Originally Posted by black5.3 View Post
    Yes I change my oil every 3000 miles and the air flter is good. I keep my vehicles well maintaned. how do you check the coils? It doesnt get worse when its wet. No I havent drove it in deep water.
    Its only money.
    Nashville, Tn
    Quote Originally Posted by zebra86 View Post
    I might change the fuel filter. But I dont think its it. The air filter is ok.
    Its only money.
    Nashville, Tn
    Do yall think it could be the catalytic converter?
    Its only money.
    rollin the nasty D's!!! Double Dueces's Avatar
    Apr 2006
    Minnesota
    get that bad bow chipped and unleash that hidden power, the the factory didn't let a know about!!!
    '01 XCSB a few mods done to it.
    truck parts http://www.supermotors.net/vehicles/...ry/10422/66312
    Registered User smokinsilverado's Avatar
    Aug 2008
    Washington
    Check your fuel pressure, run some fuel injector cleaner through it, check your fuel lines you may have a tiny pin hole in one of the lines
    Nashville, Tn
    Quote Originally Posted by smokinsilverado View Post
    I might try that.
    TTT
    Its only money.
    Registered User silverado_2000's Avatar
    NE
    Most of the ls engine coils hold up well. I've seen trucks with over 300k on them with the original coils in working order. You could also try replacing the fuel pressure regulator. They are known to go bad on these trucks.
    Registered User Z71Rado's Avatar
    Welton, Iowa
    You prolly have gobs of carbon in your intake and combustion chambers. My 2003 was like that when I bought it... it was obviously only run on 87 or bad quaility fuel and sat for quite a while before I got it(I live in the land of cheap 89). For me, I just ran premium fuel and fuel system cleaner for a month and it ran like new. Some guys here like Seafoam for that too. Spark plug wires also make quite a difference- mine went from a rough 'truck' idle to barely audible just with new wires, and restored some mpgs and torque.
    '03 1500 LS Z71 4x4. True dual 2.5" Borla Turbo muffs, x-pipe, Magnecore Competition wires, Bilstein HDs, Firestone Destination ATs. Stickers to make it go faster. 142k and climbing! Quiet until you give it gas...
    '87 Olds Cutlass Supreme. 403. 'Nuff said.
    '04 Grand Am SE. Wifey's car
