Thread: pulsing lights
Results 1 to 16 of 16
    Jan 2007
    florida
    pulsing lights
    have a 2005 reg cab silverado 1500. the lights started pulsing at night. it is almost like the truck has a heart beat. have changed the battery and the altenator says it's charging properly. any ideas guys?
    Lumberton, Texas
    Re: pulsing lights
    Quote Originally Posted by evanmcleod88 View Post
    My 2001 silverado does the same thing, well, every now and then the headlights will dim pretty good on a dark road. Doesnt seem to be related to the A/C kicking on or anything, and like you my battery and altenator are both good. I have no idea. It does seem like a heartbeat....or that may be wishful thinking
    Jan 2007
    florida
    Re: pulsing lights
    all my lights do it even interior lights.
    Lumberton, Texas
    Re: pulsing lights
    oh now thats weird. Have to research that a little
    Sep 2006
    Tennessee
    Re: pulsing lights
    I have a friend with an 05 S10 that does the same thing and it drives me crazy to ride in it! All the interior lights and headlights pulse. I figured it had to be charging system related, but he's never tried to fix it.
    Has anyone tried replacing the alternator? This has to be a fairly simple fix.
    Dec 2008
    nw indiana
    Re: pulsing lights
    my 94 does it.. i was told my alternator was putting out to much, i havent got a new one to see if it fixed the problem yet tho
    Jan 2007
    florida
    Re: pulsing lights
    ya altenator is a little pricey to just be changing out.. how i miss warranty!
    Aug 2001
    New Jersey
    Re: pulsing lights
    It's the voltage regulator in the Alt.
    Sep 2006
    Tennessee
    Re: pulsing lights
    Quote Originally Posted by CKTA View Post
    So you've experienced this and you're sure?
    May 2009
    Ontario
    Re: pulsing lights
    Could be BCM
    Mar 2003
    Denison, Texas
    Re: pulsing lights
    If you have a voltmeter, put it on the battery with the truck running. It should be no more than 14.4v and no lower than 13.5ish. Your pulsating lights could be the voltage regulator "bouncing" up and down, or running too low and bouncing up and down. Also check you battery connections and make sure you don't have a deteriorated connection. If you don't have a voltmeter, go to Autozone or a parts store that will come out and test your battery in the vehicle. Their tester will have a voltmeter as part of the test.
    :nutkick:
    THEBIGBLUE
    FLA
    Re: pulsing lights
    You have your sub's turned up too loud. Either tone down the boom boom or have a huge, neon painted, capacitor put on the positive feed. You could also try putting some "optima" stickers on the back window. lol! kidding!
    Aug 2010
    central oregon
    Re: pulsing lights
    I know this is an old post but maybe someone can shed some light. I have a 1989 3500 crew cab with a 350/tbi. My headlights started pulsing ( not all the time )
    and when they do it the alt gauge jumps back and forth along with the lights. I was guessing voltage regulator but welcome any input.
    thanks
    Dec 2010
    Oak Park Ca.
    Re: pulsing lights
    A lot of these phantom electrical problems can be related to bad connections. Connect a volt meter between the alternator output and the POSITIVE battery connection. There should be a low or no reading, if you get a reading at or above 12-13 volts there is probably a bad connection somewhere. Do the same thing on the ground side between the alternator case and the negative battery terminal. Also depending on where your negative cable connects, there can be a bad ground between engine and chassis, chassis and body etc. Basically the engine sits on rubber mounts the body sits on rubber mounts so all these things need to have proper ground connections. Again any significant reading on any of the ground connections probably indicates a corroded ground connection. Personally I would check all these things before throwing parts at it.
    Oct 2010
    north-central PA
    Re: pulsing lights
    x2 check grounds, but I'd say most likely you have at least one burned up diode in your alternator's rectifier bridge (possibly more). Alternator then only works 1/3 or 2/3 phases, so it still charges battery, but the current dips and voltage fluctuates between 12.5-14 at whatever frequency the alternator is putting out (more noticeable at low engine rpm).
    I noticed this on my 4.3 blazer at stop lights and just in general after some big stereo abuse (even when stereo was off). Upgraded to ad244 alternator =).
    You can maybe replace the rectifier yourself depending on comfort level. http://springhillautoelectric.com/ is the only source I've found...
    Sep 2011
    Watauga,TX
    Re: pulsing lights
    I know this is a old thread, but I was having the same issue with my 2005 Silverado 1500 Crew cab. I just replaced the Belt Tensioner. So far, no more pulsing.
