Thread: odd "popping" noise under dash...93 Yukon AC
Results 1 to 9 of 9
    Registered User 99redburb's Avatar
    Nov 2007
    Montverde, Florida
    Smile odd "popping" noise under dash...93 Yukon AC
    I am having a unique issue with my sons 93 Yukon. When you turn the truck on, or for that matter, shut it off, there is a popping noise over by the blower motor. It lasts for about 15 seconds and is very annoying.
    I know it isnt the blower itself, but it's right in that neighborhood. Almost like somthing is trying to open or close and can't.
    I would appreciate any help you may offer on this one.
    Shawn
    1999 GMC 4X2 Suburban...JVC Audio System w steering wheel controls, DVD and drop screen, Power Tune, Sirius and a lot more to come!
    Run GMC LaCeS OuT's Avatar
    Oct 2008
    SI, NY
    Re: odd "popping" noise under dash...93 Yukon AC
    I believe it might be the blend doors, I am not 100% though. My Jeep did the same thing and i always thought it was the blend doors.
    1999 GMC Yukon SLT HT-383E
    somewhere else
    Maybe some day this can be a sticky. ;)
    Edited to fix link since forum upgrade - http://www.fullsizechevy.com/showthr...=1#post3468132
    Richard
    Rest In Peace #3 intimidator4x4's Avatar
    Dec 2007
    Southeastern Indiana
    That's the problem, and follow someotherguy's instuctions and you'll get it
    V INTIMIDATOR has been SOLD V
    98 RCLB Z71 all stock
    somewhere else
    If you're not dead set on having a working recirculate/fresh air function, you can reach under there and unplug the actuator. It's not working anyway, and unplugging it will save you from having to listen to it knock every time you turn the key on or off.
    Richard
    HOT -N- READY 8{} g9m3c's Avatar
    Sep 2005
    Tuscaloosa, AL
    I have the same problem.
    I haven't played with it enough to figure out what a/c/heater functions trigger it, though. By reading your writeup, only the recirculate/fresh air actuator will make this noise?
    -Grant
    somewhere else
    Depends on the conditions. If it's happening each time you start the truck, and each time you shut it off, it's the recirc/fresh air acutator. The truck runs it at those times.
    It's a "dumb" acutator - the system has no idea where it's really positioned; just two wires to the motor. It operates off an assumed position. The controller powers it for a certain amount of time and hopes for the best.
    EDIT - it's easy enough to isolate; you can reach up in there and pop the harness off it and see if the noise stops. FWIW; I haven't seen the other two actuators fail, ever, though I'm not saying they don't. I think at least the hot/cold mix has control lines that report its position, though honestly I've never paid close enough attention. The only real failure I've seen on the vent position actuator is gummed up linkages that need cleaning/lube.
    Richard
    Dec 2007
    Our company truck (94 Chevy) had the vent position actuator mess up and had to be cleaned.
    Sep 2005
    Tuscaloosa, AL
    Thanks for clearing that up! That's exactly my problem.
    -Grant
