Thread: subwoofer amp turns on on start up then shuts off
Page 1 of 3 123 LastLast
Results 1 to 20 of 50
    EFI Live
    Jan 2008
    Wolfpack Country
    got a 1200 watt sony explode amp powering 2 12" subs. my problem is that when i turn the truck on the blue light on the sub indicating it has power will turn on for a good second or 2 then shutoff. this is 2nd 2 channel i've had to buy and im starting to get tired of wasting my money. help please??
    and also i went to best buy, where it was all installed, and too auto zone and they both said i have a power drain when the truck is off. when it was originally wired only one remote wire was used for both amps but i changed that today to two remotes.
    thanks alex
    -Alex
    Thanks to:
    Dustin @ Diesel Addiction
    Rick @ Pro Fab Performance
    John @ Kennedy Diesel
    AL
    Re: subwoofer amp turns on on start up then shuts off
    Where is your remote wire coming from?
    EFI Live
    Jan 2008
    Wolfpack Country
    the headunit
    -Alex
    Thanks to:
    AL
    and where is the accessory power to the head unit coming from?
    EFI Live
    Jan 2008
    Wolfpack Country
    umm which wire is that? lol
    -Alex
    Thanks to:
    AL
    the red one usually
    what im getting at is if your headunit accessory is connected to a constant power, then your headunit stays on, which means your amp stays on. But this doesnt sound like the problem at all. It sounds more like you either have the amp hooked up wrong so the impedence is too low (wired for 1 ohm or something), or there are some blown fuses in the amp.
    If you had power drain when the truck is off you would have a dead battery every day.
    EFI Live
    Jan 2008
    Wolfpack Country
    theres 2 40 fuses on teh outside of the amp, they're both fine, the one on the power wire is fine. my power and ground wires are both 6 guage. could that be the problem?
    -Alex
    Thanks to:
    AL
    6 is a little small, i would do at least 4, but I dont think thats the problem.
    If you disconnect the speaker from the amp and just turn the amp on, does it still do it?
    EFI Live
    Jan 2008
    Wolfpack Country
    well i got a 2 channel runnin the subs and a 4 channel runnin the speakers (dont ask me why its this way my brother did this back when he drove it)
    -Alex
    Thanks to:
    AL
    ....thats fine, but still doesnt answer my question above
    EFI Live
    Jan 2008
    Wolfpack Country
    sorry which amp and which speakers>?
    i cant even get the 2 channel to come on now.
    -Alex
    Thanks to:
    Why leave it stock? Polecat's Avatar
    Oct 2001
    Stillwater, Ok
    do you have voltage to the amp?
    If so, dis-connect the speakers, see if it stays on. This will eliminate blown woofer, or wired incorrectly. Just isolating if the amp comes on, and will stay on, without a load.
    giggidy
    Jun 2004
    Spartanburg, SC
    Agreeing with Polecat, a shorting speaker or speaker wire can and will make the amp shut off as it is. However, if it won't turn on at all now AND it was draining the battery, you could have a bad transistor on the power supply. That would cause both problems.
    EFI Live
    Jan 2008
    Wolfpack Country
    i disconnected the power cord that runs to the 4 channel and then the 2 channel wouldnt even turn on.
    im pretty sure its blown.
    -Alex
    Thanks to:
    giggidy
    Jun 2004
    Spartanburg, SC
    Just to make sure, did you disconnect power directly at the amp, or before a distribution block, or where?
    EFI Live
    Jan 2008
    Wolfpack Country
    unplugged it at the amp, turned the iginition, nothin so i disconnected it from the battery and still, nothin.
    -Alex
    Thanks to:
    giggidy
    Jun 2004
    Spartanburg, SC
    Quote Originally Posted by 01SilvyZ71 View Post
    Normally I'd say crack it open and see what's dead, may be easily fixable. However, if you do open it up, you may become depressed or angry when you see what's inside. So I'll just stick with its probably new amp time LOL
    EFI Live
    Jan 2008
    Wolfpack Country
    Quote Originally Posted by ibanender View Post
    damn, this truck has had 2 2 channels and 3 4 channels.
    this **** is gettin old. im thinkin ill just take out the subs, the box and just sell em cause i mainly listen to country anyways lol
    -Alex
    Thanks to:
    giggidy
    Jun 2004
    Spartanburg, SC
    If you're going through equipment like that, I think you need to look at your installation and what you're putting in there. If you keep putting crap in there, expect it to die. If something is wrong with your installation, expect it to die.
    EFI Live
    Jan 2008
    Wolfpack Country
    well the first 2 channel my brother touched the power to the ground (like a year ago) so i replaced it finally with the sony xplode back in may and we used to have a jl 4 channel but we got it used and it was old anyways so i replaced it with somethin i cant remember lol.
    all the stuff has been installed at best buy minus the first 2 channel amp
    -Alex
    Thanks to:
