Thread: Truck is uneven, Bent frame, Maybe?
Results 1 to 14 of 14
    tn
    I'm really down guys, It looks like a got a lemon here with my
    new truck. I just noticed after washing it today that the truck is uneven, the tire on the right side is sticking out more than the left side. Same tire size on both. Also makes it look like the back bumper is curving to the left just a hair. I did notice the shocks are going opposite directions, is this normal? I took some pics, maybe you guys can help me out. I'm so pissed right now, I did a car fax on this truck and It come back fine. If the frame is bent , wouldnt it be filed as a total?
    Xcentric Customs Beyond Static©'s Avatar
    Jul 2003
    baton rouge
    Re: Truck is uneven, Bent frame, Maybe?
    The axle under those trucks never were perfectly centered, but I'd look under there to make sure all the suspension parts are tight. As far as carfax goes, a large percentage of the time things are not reported to carfax.
    2/4 drop, GMC 20's, 4:10 gears, Blackbear Tune
    Formerly White_Stealth Stealth HD's Avatar
    OKC/Moore, OK
    Just cuz a frame was bent, doesn't mean it classifys it as a total.
    X2 on what Beyond Static said. It can be as simple as the body/bed weren't centered on the frame from the factory, or after an accident where the bed may have been off. It's not as noticable on stock height trucks, but when they are lowered it can be more apparent.
    Backwoods Body derek6787's Avatar
    Norwood, Missouri
    Search chevy lean. You may have the chevy lean problem....There's tons of threads on here about what it is and how to fix it...... p.s. I'm hoping that those pics are of your front tires b/c in the pics they look turned. If those are the front tires and you diagnose your truck with the chevy lean I wouldn't worry about it b/c I have known my truck since new with no wrecks and the front left tire sticks out a lil further than the right as it rubs when the right one doesn't. After thought.....Is the truck bagged? What kind of notch if so. Bodydropped? Whoever built it could have gotten something a little off when building it. Could also be your leaning issue.
    1993 GMC rcsb stepside 5.7 5spd
    Ol' Skewl BS'er flotsamm's Avatar
    Jul 2007
    California
    Is the bed centered with the cab? Does it drive straight? Its odd that the whole axle is moved over to one side. Usually what happens is one wheel is moved more forward then the other on a bent frame which throws off the thrust angle and the truck crab walks. Take it to a frame shop or sometimes a good alignment shop can tell you what might be wrong. They can at least tell you if the thrust angle is off from the front.
    5.7L, 5-Speed, 4/6 drop on 245/45/18's
    tn
    The pictures are from the back.
    Registered User custm2500's Avatar
    Sep 2008
    Ohio
    I think you are way over reacting. Frame bent wouldn't cause what you are looking at alone. The bed gap would be off and there would be other problems. The axle is just off by a bit. Someone could have had it out, the bed might have been taken off and not centered.
    Should be rather easy to loosen the bed scoot it over a little bit and make a happy medium of bed to cab, and side to side evening.
    "01 GMC 2500 HD, Bagged, BB Tuned, Dumped exaust, and Race built trans with 2800 Stall
    95 C-1500 Ext. Silverado Bigg G's Avatar
    Maryland
    Looks and sounds pretty normal to me and the wheel sticking out further on 1 side is pretty common too. My Silvy has that same issue on the front passenger side plus I've seen a few trucks on this site as well as others with the same wheel sticking out further issue.
    It's my understanding that some trucks come from the GM factory like that for some reason or another but it's more noticeable when you lower or have your truck lowered.
    tn
    I feel better about it, thanks fellas. I will take it to a frame shop and make sure it has no big problems.
    1 Ton Mafia tylerj's Avatar
    new mexico
    buddy of mine had his axles coming out of his 1500 when he did a 9" swap crazy stuff there.
    Registered User 90Accord's Avatar
    Jan 2009
    illy-noise
    put a fender flares on that side no one will ever notice
    Hated by Most - Feared by None
    Maryland
    ^^^^^^ ahhhhh......you're joking right ????
    That kinda sounds like the **it will buff right out** line.
    I Hate You All, Equally.
    Hell, Frozen Over.
    I'd check to see if the leaf springs are sitting right.
    COLE@SPORTTRUCK
    It's a Chevy thing, you could have your shop do a 4 wheel alignment. It will most likely be just fine. Belltech makes 3/4" and 1" spacers for the "Chevy Lean" that they all have.
