Thread: speedometer problem
Results 1 to 16 of 16
    'Browning Edtion' thunderlite's Avatar
    Minnesota
    speedometer problem
    Hey I have a 1998 Chevy 1500 with the 5.7 and I am having problems with the speedometer, sometimes when driving the speedometer stops working, as in if your going 35 the needle will drop to 0 then back to your current speed then drops to 0, then after doing that for awhile it will act fine. Is this a common problem and how do I fix it?
    98 K1500 4X4 ecsb
    Dan-is that RUST on your doors
    Joe-yea. it adds character
    Quote Originally Posted by CountryChevy15 View Post
    *Warning FSC members are known to be and more than likely will always be smartasses*
    Registered User elee's Avatar
    Georgia
    Re: speedometer problem
    My dads 2004 1500 silverado had this problem too. His was fixed under a recall. But I'm not sure if yours is covered under the recall. Hope this can help!
    White Lightnin'
    89k miles
    2002 Chevrolet Z-71
    Tuned(Vengeance), 285 S/T's, Leveled, Polk door speakers, 3.73's, Black Delta Tool Box, CBE, Air Raid MIT, K&N Filter, Speedliner, De-Molded, Painted Emblems, Z71 Valance
    Minnesota
    Yea at this point I kinda anticipate it happening so its more a nuisance than a problem ya kinda gotta fallow traffic and pray the crime stopper doesn't get ya.
    98 K1500 4X4 ecsb
    Registered User Hodges87's Avatar
    Sep 2008
    I would get another gauge cluster and test it, their pretty cheep at a salvage yard, or someone here will have one. Does your transmission act up when your speedometer isn't working right? If your speed sensor is bad it will mess with all kinds of things including your transmission.
    |97 Z71 5.7L|F44|14 Bolt SF|Magna-flow cats|AD244 Upgrade|MSD Wires|Corvette Servo|
    Registered User mud slinger 55's Avatar
    May 2008
    My moms 05 speedo is like 60-80 mph faster than what you are going. Is there a recall on that year too? What could cause this?
    RC leveling kit/LPP longtube headers/ Blackbear 93 tune/Helo Maxx/Super Swamper M16
    1972 chevy c10, 350, RV cam, 4 barrel carb, 4bolt main, aluminun intake, tons of new parts. FOR SALE!!!
    Minnesota
    Quote Originally Posted by Hodges87 View Post
    No it doesn't the tranny acts normal when it happenes.
    98 K1500 4X4 ecsb
    OBS 4X4 HOE! bai78's Avatar
    Dec 2008
    Rowlett, TX (Dallas)
    Stepper motor maybe in the speedo? You are better off upgrading to a Escalade or Denali cluster. This way you get the 120mph speedo & aqua blue tint instead of the white with orange needles.
    1999 Tahoe LT: ProCharger, BBP Tune, 411 pcm.
    - In Progress: Marine Intake Swap with LS3 injectors
    2002 Denali Yukon XL: MP112
    EFI Live
    Jan 2008
    Wolfpack Country
    Quote Originally Posted by mud slinger 55 View Post
    yea take it to the dealership and they'll fix it for free, you should have had a letter come in the mail. at least they sent one when my dads 04 went out
    -Alex
    Thanks to:
    Dustin @ Diesel Addiction
    Rick @ Pro Fab Performance
    John @ Kennedy Diesel
    Sep 2008
    Does your odometer act up when it happens? I'm pretty sure its your cluster. I upgraded mine to the Escalade for $80 at a salvage yard. You should be able to get a good used cluster for under $40
    My Escalade cluster installed with my original odometer
    Minnesota
    Yea that looks similar except the 120mph which i should never need(not) so once I get one how do I install it? It hasn't acted up for a couple of days/whenever my dad is riding with.
    This is mine. Looks familiar eh?
    Also it seems that the gas gauge is moving kinda like vibrating. I don't mind it or the speedometer prob but for some reason the cops around here have been out in full force and stopping people for doing as little as 3mph over so I get a little excited when a roller is in front with the radar gun.
    98 K1500 4X4 ecsb
    Dec 2008
    It is a straight forward swap. You just pull the old one & drop the new one in place by pulling the dash/bezel out. Be sure to put the gear shift in 1st & adjust the tilt steering to help you get everything out.
    Minnesota
    Ok I'll have to look for one then try to swap it. But I need to find a salvage yard and a flat surface.
    98 K1500 4X4 ecsb
    Dec 2008
    Salvage yard, car-parts.com, or ebay. I picked mine up for $34.95 with free shipping off of ebay. It was from a wrecked 2000 Denaili versus an Escalade. The Escalade ones were going for $100 or so.
    Be sure to have torx screws so you can swap the odometer to maintain accurate mileage. While the cluster is out, you should replace or swap out the bulbs so you will not have to pull it again.
    Minnesota
    Thanks for the tips/resources and replacing the bulbs because the oil and the water pressure bulbs are out. Also why do I need to have it in 1st?
    98 K1500 4X4 ecsb
    Dec 2008
    It makes it easier because the gear shift will cause an obstacle in the bezel/cluster removal. You can always remove the shifter lever as an alternative.
    Minnesota
    Ah ok it did it again today on my way to trap I will look into replacing it.
    98 K1500 4X4 ecsb
