Thread: Gear oil leaking into brake drum
Results 1 to 17 of 17
    Registered User wickedss's Avatar
    Aug 2007
    Globe, AZ
    Well I went and got new tires on my 92 gmc ext cab 4x4 today and when they pulled off the tires they checked the brakes. Apparently there is gear oil leaking into the back brakes. Since I don't have the over 600 dollars they want, my question would be this.
    First, what NEEDS to be done to fix this and Second, what SHOULD be done since it will be taken apart anyway.
    I am pretty mechanically inclined just haven't had to do this type of job yet so I will need to know the name of the parts that I will need as well.
    Thanks
    Chandler, AZ
    Re: Gear oil leaking into brake drum
    You will need to replace the rear wheel seals and rear brake shoes. Everything will have to be cleaned well before re-assembly. If your axle shaft is worn at the sealing surface you will need an offset seal or a replacement axle shaft. Is it a half ton?
    Jeff
    2005 Silverado - CCSB 5.3L,3.73,Auburn LS,Rear Disc Brakes
    2000 Silverado - RCSB 5.3L,3.42,open,05 Front Brakes,SS lines,Flowmaster
    1970 Jimmy - 350,TH350,NP205,D60(welded),14FF(Detroit) 38" SX's
    Helping people achieve home ownership in the east valley
    Aug 2007
    Globe, AZ
    yeah, k1500
    Chandler, AZ
    Its an easy job, you'll remove the diff cover, remove the threaded pin retainer and pin, remove the C clips holding the axles in. Remove the brake drums and pull the axles out. The seals will be easy to replace. Inspect the sealing area on the axle and get the standard seals if the axles arent worn or the offset seals if they are worn. Put a very light coating of rtv on the new seal (outside metal edge to seal the metal to metal contact) and install seals by using a socket that fits the seal and drive it in gently and straight with a hammer. Lightly lube the rubber seal lip with oil and reinstall the axle shafts. Then reverse the procedure to finish the job. Make sure you buy a few cans a brake cleaner so you can clean everything up. Good luck!
    Jeff
    Averill Park, NY
    I need to do this asap. Mine's been leaking for a while now.
    Aug 2007
    Globe, AZ
    thank you guys for the help
    Registered User 1CLNY2K's Avatar
    Feb 2007
    New Freedom, PA
    Common sense but dont forget gear oil as well. Its easy to forget the common needed items.
    -Justin
    2006 Tahoe Z71/5.3/RC leveling kit/18x9 Pro Comp 7036 w/275-70-18 TOYO MT's
    1978 F150 SCSB 4WD/4.9/NV435/NP205/D44/9" locked/4" lift/33" BFG's
    Aug 2007
    Globe, AZ
    Thanks so much for the info guys...even the common sense stuff cuz I woulda forgot and had to make another trip for it. Now... will I need any specialized tools for this job? And will it be pretty obvious if the axle is worn?
    Appleton, WI
    Common hand tools are pretty much all you need, seal pullers help a little when it comes to pulling out the old seals. You don't need to pull all the brakes out to change the seals either, I just spray the shoes down and everything else down good with brake cleaner and call it good. Only need to replace the shoes if they are really badly saturated with gear oil. If you do replace the shoes, brake spring pliers make it easier as well. An you would tell if the axle shaft is worn if there is a heavy groove in the sealing surface of the axle shaft, you should be able to see it. Otherwise pretty straight forward, a chilton or haynes manual helps a little with this just for some of the pictures that they would show so you would know what to expect.
    Aug 2007
    Globe, AZ
    thanks....I went to autozone and they have 2 Wheel Seals. 9.5" and 8.5"...how do I know which one I need.
    Appleton, WI
    The 8.5 inch ring gear axle will have 10 bolts holding the cover onto the differential. Where the 9.5 inch axle will have 14 bolts. Just count how many bolts that you have and go from there, more than likely, you have the 8.5 10 bolt.
    st.louis mo.
    they are called repair bearings. the seal is made into bearing
    housing and you will have to take the race out to.
    these bearings are wider to. good luck
    Averill Park, NY
    Watching this one!
    Aug 2007
    Globe, AZ
    I now have a question about recalls. I found this and I'm wondering if I am eligible. Do I need to be the original owner, is there a time limit to these things, or should I just call the dealer.
    Number:
    RECALL92C01
    Date:
    08/28/1991
    9219chevy01
    IMPORTANT
    GMC TRUCK RECALL NOTICE
    CAMPAIGN 92C01
    PLEASE RETAIN THIS COPY FOR YOUR FILE. YELLOW CAMPAIGN BULLETIN AND OWNER LETTER WILL NOT BE SENT FOR THIS CAMPAIGN.
    THE FOLLOWING WAS SENT VIA DCS/EMS ON AUGUST 28, 1991 AND/OR SEPTEMBER 3, 1991.
    NUMBER: 92C01
    DATE: AUGUST 28, 1991
    GROUP: 4B - REAR AXLE
    SUBJECT:
    REAR AXLE SHAFT INSPECTION AND/OR REPLACEMENT
    MODELS:
    1991-92 C AND K 1/2 TON MODELS
    General Motors has determined that certain 1991-92 C and K model trucks built at Pontiac East and Oshawa Assembly Plants may have been assembled with improperly heat treated axle shafts. Premature bearing wear without loss of axle shaft integrity, and eccentric seal wear may result in possible oil leakage.
    To correct this condition, the existing axle shafts will be inspected and replaced where necessary.
    VEHICLES INVOLVED
    Dealer codes and vehicles involved are listed.
    SELLING SHIP TO
    DEALER CODE DEALER CODE VEHICLE IDENTIFICATION
    (List Sorted in Selling Dealer Code Order)
    Mundelein
    It can be a PITA to do these sometimes..ive done several and good luck finding the right axel shafts if u need em 3 times at NApa and the wrong one fianlly found em at a junkyard
    Chandler, AZ
    If your axle shafts werent heat treated properly you would have had an issue about 15 yrs ago IMO.
    Where in AZ are you?
    Jeff
    Aug 2007
    Globe, AZ
    Ok so it needed to been done back then? nvm I just reread that now that I have had my mornin coffee and I get what you are saying. hehehehe
    And I live about an hour and 1/2 east of you. In Globe.
