Thread: Replace oil filter adapter gasket & o-ring
Results 1 to 4 of 4
    Registered User Hodges87's Avatar
    Sep 2008
    How to: Replace your Oil cooler adapter gasket & o-rings
    If your Oil cooler adapter is leaking like the one above don't worry its simple fix.
    Here are the item needed to replace the gaskets:
    Felpro gasket set # ES72671
    De-greaser (optional)
    Scraper to remove old gasket
    1/2 inch socket and ratchet
    Pick (if removing oil cooler lines)
    Flat head screwdriver
    Removal:
    Step 1: Clean and degrease the adapter and surrounding area. (Not always necessary, but I like a clean engine)
    Step 2: Drain the oil and remove the oil filter and drain for a few mins.
    Step 3: (This is step optional, I wanted to clean the oil filter adapter and replace the o-rings on the oil cooler lines) Carefully remove the plastic keepers and slide them back, then use a pick to pull the c-clamp off and pull the line out of the adapter.
    Step 4: Remove the 2 (1/2 inch) bolts holding the oil filter adapter on and separate the adapter from the engine
    Step 5: Remove the o-ring and scrap away the old gasket
    Installation:
    Step 1: Replace the o-rings inside the oil cooler line fittings on the adapter
    Step 2: Install the large o-ring and gasket (a little petroleum jelly will help the gasket stay in place)
    Step 2: Install the adapter with 2 (1/2 inch) bolts
    Step 3: Install the lines into the adapter.
    Step 4: Install a NEW oil filter & engine oil
    Finished! I hope this guide helped you fix your leak!
    |97 Z71 5.7L|F44|14 Bolt SF|Magna-flow cats|AD244 Upgrade|MSD Wires|Corvette Servo|
    Phoenix
    Re: Replace oil filter adapter gasket & o-ring
    I had to do this a few months ago because the oil cooler line adapter you have circled in green broke when I tried to tighten it a little. It didn't take much force to do it. So as a warning be VERY careful tightening that adapter.
    Registered User gravedigger472's Avatar
    Aug 2009
    Spring Hill, TN
    i had the same problem and this is what fixed it. mine was dirtier and more greasy lol
    2010 Silverado 5.3 project "white noize" slammed and cammed. 4/6 drop comp VVT cam
    SOLD:1996 4x4 ECSB. L31 with 95 f-body LT-1 cam. 'Vette servo, stall converter, Magnaflow. Lowered 4/6 via Belltech. BUILD THREAD
    richmond,va
    i have the adapter laying here to get rid of the whole piece but im not real sure what part number i need for the filter.anyone?
