Thread: Vortec 97 5.7 ..no fire at plugs
Results 1 to 20 of 31
    Aug 2009
    alabama
    96 4.3 vortec to 97 5.7 vortec in 96 Z71. 5.7 harness and computer completed during swap. Process went well, except no fire to plugs. Fire from coil, but not to plugs. Plugs are new, wires are good, new cap and rotor, and dizzy was set to gmc specs. All sensors check out good also. If we had spark to plugs, I think the 5.7 would start...This motor ran like a sewing machine before being pulled from rollover. Any ideas????
    1992 extended cab stepsid
    Dec 2008
    New Jersey
    Re: Vortec 97 5.7 ..no fire at plugs
    isnt there some sort of security on them trucks? that prevents spark?
    1992 silverado c-1500 ecssb , 5 spd, flush mount bed cover, 383 stroker, vortec heads, gm performance intake, long tube headers, true duals, high flow cats with dual flow master 40's, 5/7 drop 18" rims, tune time performance tune, comp cam 278/498 CCA-12-243-3,
    Aug 2009
    Dorion
    How did you set the dizzy to GM specs? No security till 98.
    Dec 2008
    New Jersey
    check your coil wire?
    Aug 2009
    alabama
    coil wire is good and TDC #1 and dizzy on # 8. No passloc
    Registered User 88Silverado25's Avatar
    May 2006
    If you have fire at the coil wire in the center of the distributer and no fire at the plugs it could mean the roter is not turning for some reason...broke distributor shaft or some crazy thing I have never seen a chevy do. I guess it would be possible for the gear on the end to shear the pin holding it on right guys? Maybe take the cap off and watch the distributor rotor turn while you turn the truck over to rule that out?
    L
    Feb 2007
    Louisiana
    Am I understanding this right - piston number 1 at TDC on compression stroke, but rotor directing spark to #8? That isn't going to work. Think you need to re-stab your distributor. Do you have spark at all to any cylinder?
    Dec 2008
    New Jersey
    lol did you forget to put your rotor back on?
    Dec 2008
    New Jersey
    oh actually i bought a dizzy with a cap and rotor of ebay (bad idea) then the contact pit was pressed up too far making it so the coil wire never got to the rotor check that out also
    Aug 2009
    alabama
    rotor does spin during cranking.
    Dec 2008
    New Jersey
    did you check your contact pin? that has to be it
    Aug 2009
    alabama
    got the new cap and new rotor from Advance Auto Parts. Comparing old to new, they match
    Aug 2009
    Dorion
    ACDelco?
    Dec 2008
    New Jersey
    how about checking continuity from the coil wire through the cap?
    Aug 2009
    alabama
    not sure on ac delco, wil have to ask.. son in law boughtthem new, and the continuity is good good from from coil wire to cap. Also have check each plug connection on cap as well..
    May 2006
    You getting fire to the plug wires at the cap? This might some how be a bad rotor still.
    L
    Aug 2009
    alabama
    we have tried 2 caps and 2 rotors...
    Dec 2008
    New Jersey
    maybe the contact point is bent down on the rotor that happened to my truck
    Aug 2009
    alabama
    we checked the contact on the rotor. It appears to make contact. We even took another spare rotor and bent it a bit upwards to make sure. No difference
    Thx 92
    May 2006
    So just to be clear, You have a spark from the coil wire to the distributor cap, and nothing comming out of the wire plugs on the cap? What method are you using to test this? Sorry to ask similar questions, just trying to help.
    L
