Thread: AC condenser has a leak/hole
Results 1 to 14 of 14
    EFI Live
    Jan 2008
    Wolfpack Country
    so yesterday after leaving the lake i noticed my ac wasn't very cold and eventually was just room temp by the time i got home. so i go out today to start the truck up and go to a friends house and i hear this hissing noise, well turns out there is a puncture in the condenser and now im too scared to start it and drive it. i dont have the money to fix it now but my main question is will it be alright to drive around for a few day? sorry for the long post
    thanks- alex
    -Alex
    Thanks to:
    Dustin @ Diesel Addiction
    Rick @ Pro Fab Performance
    John @ Kennedy Diesel
    Probably on a rig. Colin B's Avatar
    Denham Springs, LA
    Re: AC condenser has a leak/hole
    as long as you don't run the a/c and lock up the compressor.
    1990 C1500
    1951 Suburban
    2007 Chevy Silverado Z-71
    2009 GMC Yukon
    Registered User fastfew's Avatar
    so cal
    you can unplug the a/c comp that way if you accidently push the a/c button on the comp wont turn on.
    SE Michigan
    once the a/c pressure drops to unsafe levels(for compressor life), the system won't turn on anyway, totally safe to drive
    2000 Silverado 6.0 4L80E 2wd
    EFI Live
    Jan 2008
    Wolfpack Country
    alright thanks guys. guess ill have to do with the windows down in the sweltering NC heat till i get $200 for a new one
    -Alex
    Thanks to:
    Lompoc, CA
    Quote Originally Posted by 01SilvyZ71 View Post
    The condenser price is not gonna be the big part of the expense. You will have to get the system evacuated and filled. You should also change the accumulator because it has the desiccant in it that should be changed every time the system is opened.
    KJ6LFD
    EFI Live
    Jan 2008
    Wolfpack Country
    Quote Originally Posted by Bob T View Post
    dangit lol. im installing the condenser but lettin the shop do everything else like a recharge and all that. how much do you suppose that'll run me?
    -Alex
    Thanks to:
    Appleton, WI
    Accumulators are not that badly priced, under $50 usually, probably wouldn't hurt to change the orifice tube as well, it divides the system between high and low pressures and has a screen that also acts as a filter, another cheap under $10 part. Just a little pm while you got the system open.
    Lompoc, CA
    Dunno what it would cost. In the area I now live A/C is not used much.
    KJ6LFD
    Registered User ojaijohn's Avatar
    ojai
    Just did this on my '89.
    Condensor was $180.00 (didn't change out anything else).
    Local shop charged $75.00 to vacuum and fill. Might be less for a pickup, my Suburban has rear ac which and takes more refrigerant.
    The crumple zone in my OOBS is the other guy's car.
    EFI Live
    Jan 2008
    Wolfpack Country
    Quote Originally Posted by ojaijohn View Post
    alright thanks for the info
    -Alex
    Thanks to:
    EFI Live
    Jan 2008
    Wolfpack Country
    oh and one more question, can i run the heat?
    -Alex
    Thanks to:
    Lompoc, CA
    If you pull the electrical connector on the compressor clutch, the A/C won't run; go ahead and run the heat. When you pull that little plug make sure it is in a safe place where belts/pulleys can't eat it. Maybe some zip ties.
    KJ6LFD
    EFI Live
    Jan 2008
    Wolfpack Country
    alright, thanks for all the help Mr. T!
    -Alex
    Thanks to:
