Thread: Can't bleed air out of brakes - 2008 Silverado...help!!
Results 1 to 11 of 11
    Jul 2004
    Fresno, CA
    I don't know what the problem is but we tried to bleed the brakes after changing to stainless steel brake lines...it's a 2008 2wd silverado. We bled the rear with no problems, but now the front is giving us all sorts of trouble. When we drive it, only the rear brakes work. When we bleed the front, the pedal never gets stiff and nothing but 80% air/20% fluid come out of the bleeder.
    Do you guys have any ideas?
    2008 GMC Sierra 4.8L Ex-Cab 2WD
    Torque Engineer SoCalZ28's Avatar
    Apr 2006
    Re: Can't bleed air out of brakes - 2008 Silverado...help!!
    Did you do any brake work at the same time? Also, if you used thread tape, maybe a clog.
    1994 Z71 - 6" Fabtech w/35's, MSD Ign., Headers, Memphis 12's :rocking:
    *New to the family* Traxxas E-Maxx :rocking:
    Aug 2001
    New Jersey
    By any chance, did you let the resovour get really low on fluid? If so, you may have air in the ABS?
    Registered User GCncsuHD's Avatar
    Sep 2005
    Raleigh/Cleveland NC
    Quote Originally Posted by CKTA View Post
    :word: if you don't keep it topped off while bleeding and this happens, the ABS must be electronically bled by the dealer or someone with a Tech2.
    Jul 2004
    Fresno, CA
    Quote Originally Posted by GCncsuHD View Post
    We kept the reservoir full...but we know that air got into the ABS. We cracked open the line going at the ABS unit to the front left caliper and it was full of air.
    Is there any other way to bled the ABS unit ourselves?? I'm pissed because we've bled tons of brake systems and this is the first time we've ever had an issue - and I'm positive the reservoir stayed full.
    G-FORCE FinalBreath's Avatar
    Milwaukee, WI
    If you kept the res full, How did air get into the abs unit?
    88 K1500 5.7 220K SOLD
    95 K2500 5.7 336k SOLD
    96 K2500 6.5 171K
    06 Trailblazer LTZ
    Jul 2004
    Fresno, CA
    Quote Originally Posted by FinalBreath View Post
    That's what I'm trying to figure out...it doesn't add up at all.
    Milwaukee, WI
    Leave the cap off the res full of fluid and open the bleeders. Let it gravity bleed for a while. Keep watching the res and keep it full. That should get most of the air out.
    96 K2500 6.5 171K
    06 Trailblazer LTZ
    Jul 2004
    Fresno, CA
    I'll give this a shot and see what happens.
    Aug 2001
    New Jersey
    That won't work as far as I know. To get air out of the ABS the dealer or Tech II has to do it.
    Jul 2004
    Fresno, CA
    I wish I knew someone with a Tech II...
