Thread: Front crossmember swap
Results 1 to 4 of 4
    Registered User mrchubz's Avatar
    Greeneville, TN
    Hey guys I have a fairly rust-free 70 C10. My question comes is what is involved in doing a crossmember swap from a 73-87 C10. My current front end is wore out to say the least the last time it was drove we found wear marks on the sidewall where the tires leaned so far. Any links to pics will be greatly appreciated. Thank you.
    Registered User billywilly92's Avatar
    Dec 2008
    Michigan
    Re: Front crossmember swap
    They aren't the same body style of trucks.
    1986 RCLB k15 mix - Restored
    PA
    Quote Originally Posted by mrchubz View Post
    Save for reaming two holes where they don't quite line up it is a direct bolt in
    I have a front crossmember from a 91 R3500 under my 70 C-2500 GMC
    Does your '70 have disc on the front ? If it is still drum I would swap crossmembers to get the disc setup , if it is already disc , save yourself the hassle and replace the worn components , if the truck is assembled it is a PIA to swap the crossmembers .
    Don't forget to swap to a disc M/C and proportioning valve if you are upgrading to disc brakes , and don't forget about the 6 lug rear you still will have .
    TOM
    1994 3500 Dually , 502HT ,264HR ,MPFI
    2006 Forest River 325RGT 5th Wheel
    2001 3500 8.1/Allison , HP tuners , Raylar, etc
    1993 K-3500 "Ex-diesel" , 454/4L80E
    1992 S-10 434 SBC/Tremec
    1984 S-10 Blazer BBC/700R4/205, SAS
    1980 Z-28 454 - 700R4
    1977 Olds 98 Regency 403/700R4
    1970, 71 and 72 GMC
    Registered User Malibob's Avatar
    Sep 2008
    Pittsburgh
    I have a '65 with a 73-87 front end on it. All I did was swap the control arms and spindles. I now have disc in the front 1" and I did this because of the location from the brake line to brake hose connection lines up perfectly with a monte carlo brake hose. If you use the 1.25" then you need to relocate that connection point. I did not have to bore any holes or anything like that. It went right in. You should probably note that the tie rods may be different sizes though so you may have to get an adapter. CPP sells them. Pretty simple for me though. I even have drop spindles on it now.
    This statement was made possible by a grant from this station and continued support from viewers like you.
    I took lots of pictures, here they are:http://www.flickr.com/photos/14721056@N05/
