Thread: I have bad gas what to do?
Results 1 to 16 of 16
    Registered User bigolblackie's Avatar
    Jul 2002
    Toronto Canada
    I have bad gas in my truck,it bogs and runs like crap when less then a quarter tank. When I fill up more then half way it runs better,which leads me to believe the slurry is at the bottom of the tank. Short of draining the tank,what should I do? Is it ok to put that diesel stuff in the tank,the stuff that gets water out of diesel. Is it ok to use that stuff in a gasoline motor? Maybe seafoam,what the best bet? Thank you.
    bigolblackie 1988 fulsize Blazer Silverado obs reg.cab 3500diesel Chev towtruck 1981 Lincoln Continental MK.VI "the black American dream car"
    Jul 2006
    Az
    Re: I have bad gas what to do?
    Gas-X?
    Fuel tanks from all years of vehicles suck up the fuel from the bottom of the tank first, despite how full it is.
    So you think have some bad gas resting below the good gas in your tank, if that were so your truck would suck the junk up first.
    What I would do if I were you is do a fuel PSI test with the tank full and than below 1/4 and compare, perhaps your just seeing a weak fuel pump and when fuel level is low the pump is working harder than when it's full and a low fuel pressure would make the truck run like crap, especially a diesel
    Natural born world shaker SpankyCSW's Avatar
    Oct 2009
    Sugartown
    Quote Originally Posted by 04SilveradoMykk View Post
    Gas-X?
    :LOL: I think he means Heet... But I'm with you Mykk, that shouldn't be the issue because fuel is coming from the bottom of the tank no matter how much is in there.
    Jul 2002
    Toronto Canada
    Its a 350tbi so its not a diesel. I was working in the junkyard and was getting free gas there from the gas tanks. One day I usually empty and fill the gas myself,but one day I trusted another guy working there to fill my gas containers and I think he fixed me. I really dont want to drain the tank and all that. I will try that gas x stuff. What damage to the motor am I facing? Will it eventually burn off and go away?
    Jul 2006
    Az
    Quote Originally Posted by bigolblackie View Post
    Dude, no no no. I was kidding with the Gas-X, gas-x is used for when you had really bad farts.
    You need to test fuel PSI like I stated above.
    Oct 2009
    Sugartown
    Gas - X is for indigestion... Like farts and burps.
    Jul 2002
    Toronto Canada
    LOL I googled that and was like wtf I will remember it though if beans are on the menu. I dont know how and I dont have equipment for testing fuel preasure.
    Jun 2008
    Union, Missouri
    Pepto FTW
    Jul 2006
    Az
    Than keep shooting in the dark man, or pay a shop to help you
    Jan 2007
    Nebraska
    x2 on possible weak pump
    Registered User whitelightnin92's Avatar
    delaware
    fuel filter
    69 C10
    http://www.fullsizechevy.com/showthr...y+project+pics
    72 C10 stepside RAT
    355/350/14bolt 3.73 posi
    92 k1500
    1/4 16.024 @ 84 MPH
    2006 ECSB 5.3
    1/4 15.588 @89.96 STOCK
    Sep 2005
    Southern Cali
    Are you sure that your fuel gauge is reading correctly? It may be displaying just less than a quarter tank but the tank many be almost empty.
    2000 Silverado Ext. Cab Z71
    2005 Nissan Titan XE
    1999 Suburban
    Jul 2002
    Toronto Canada
    I think if I change the fuel filter that might be the cure,along with fuel injection cleaner stuff. I bought some Motomaster gas treatment,and 30ltrs of gas and it seems to run a little better allready. What I wonder is how comes it runs like crap when then tank is near empty?
    behind the wheel
    Minneapolis, MN
    If you got a load of water, your gas will be floating above it. The only solution is to syphon the tank, or try to treat it with alcohol (heet).
    Jim
    2000 NBS Tahoe 5.3 4wd crap hauler
    Ported TB, MAF screen delete, Energy Suspension bushings (F/R), Detroit Locker
    Jul 2002
    Toronto Canada
    I changed the fuel filter today and its seems to be getting better,but not all the way. It shuts off sometimes when at low idle with the steering wheel turned,like when waiting to turn at a light or when parking.
    Feb 2007
    Elkton, MD
    I used to work at a salvage yard. I know about the free gas. Can't pass it up. You have water in your tank. When you have plenty of fuel in the tank, the water is mixed up, but still runs on the poor side, when you are down to the lower levels, there is more water than fuel, so its running poorly.
    Drop the tank and check it out.
