Thread: 14 Bolt Semi Float Conversion Questions
Results 1 to 14 of 14
    Erie, PA
    I have a '90 Chevy K1500 that has a 10 bolt with 3.73 gears. I want to convert to the 3/4 ton 14 bolt semi floater. I just bought brand new wheels and I wanna stay with 6 lug. I don't do any real hardcore off roading. Just some mudding and I wanna be able to go with 38" tires.
    My first question is what years do I search for the complete axle? I found an article that said 86-93 light duty 3/4 ton. Is that correct? I wanna hit the junkyards soon.
    Randy
    Registered User zraffz's Avatar
    Oct 2009
    Northern New Jersey
    Re: 14 Bolt Semi Float Conversion Questions
    Yup that sounds about right. My buddy's plow truck is a 88 and has a 6 lug 14 bolt.
    2002 Tahoe Z71 6" RCX lift, 315/70/17 Mastercraft MXTs. (Girlfriend's toy)
    2005 Chevy 2500HD Daily Driver
    1998 Chevy K2500 Work in progress/plow rig
    1994 S10 SCSB 2WD. Under the knife.
    Erie, PA
    Cool. Does he wanna sell the rear end? :)
    Are there any other years that will work for a simple swap?
    Registered User skylark's Avatar
    Oct 2008
    Grants Pass, OR
    If you want a simple swap the you need to stay within you body style. You need an 88-98 or a 99-00 classic (OBS) otherwise you will be changing spring perches and shock mounts. In that you have a 4wd then you need a 4wd rear as well, the 2wd are 3" narrower.
    89 GMC Stepside 2WD 4/6 drop, working on the stroker again!!!
    Y2K Chevy K3500 CCLB Dually 6.5, the Black Pearl.
    Erie, PA
    Ok so my question is which years do I need to stick with to have a direct bolt in? I want the perches in the same place and the total length to be the same. I heard some years are narrower and some are longer. So I also need to make sure I get a 4WD rear end as the C2500s are shorter?
    I'm thinking 88-93 4WD K2500 so far. What about the Suburbans? Same deal?
    Thanks to all
    Naples, FL
    just a heads up, plan on different u-bolts and a conversion u-joint
    97 K1500HD RCLB 5.7, 14 bolt, straight piped, Police Tahoe wheels
    90 'rado C1500HD RCSB 5.7, headers, flowmaster, kn intake, TBI and pod spacer, 14 bolt, G80...tons more...
    79 k10 RCSB 5.7, headers, straight piped, weiand intake, edelbrock carb, 4 in. lift, 35's, rear spiders welded
    Erie, PA
    Thanks, does anyone have a part number for the conversion u-joint and u-bolts?
    Bangor, ME
    Zumbrota Bearing and Gear iroc_zz's Avatar
    Jul 2006
    Minnesota
    Quote Originally Posted by RandyOrr View Post
    Thanks to all
    For a direct bolt in look for these
    1988-98 K1500 w/14 bolt cover (1999 old body w/5.0L or 5.7L also)
    1988-95 K2500 w/6 bolt axles
    Suburbans and the K2500 w/8 bolt axles used a different length housing and axle and a different width spring perch.
    (According to Hollander interchange)
    Erie, PA
    Guy at the junkyard said he has a '89 C2500 with a 14 bolt 6 lug axle. I told him I need a 4WD, he told me they are the exact same. Please advise on this anyone...
    Mar 2003
    high falls,ga.
    if i remember correctly my 14 bolt sf out of a 98 4x4 was 68"from wms to wms.
    Naples, FL
    Quote Originally Posted by Rain Man View Post
    pardon my dumbness, but what is wms?
    Naples, FL
    my 5 lug 14 bolt sf in my 90 is about 58" from backing plate to backing plate
    (yes i know that this is a 454ss rearend that was factory or dealer installed and no its not for sale) lol
    Registered User Silverad304's Avatar
    Jun 2008
    Southern, Md
    WMS= wheel mount surface....iirc. Just have measure the rear he has and compare it to yours.
    1998 K1500 Silverado DC 6.5 lift w/35" XTerrains
    Pro-comp 7089's and a SF 14 Bolt rear
