Thread: how to install door speakers?
Results 1 to 7 of 7
    west chester, pa
    yes, I searched.
    I'm going to install new door speakers for 06 crew cab, both front and rear doors.
    how do you install?
    must you take off the door panels?
    what tools do you need?
    thanks,
    Jeff
    2006 Silverado crew cab LS, 2wd, leveled
    2005 GSX R750
    when I step out, I'm gonna do you in.
    Why leave it stock? Polecat's Avatar
    Oct 2001
    Stillwater, Ok
    Re: how to install door speakers?
    maybe a visit to a local dealer is in order.
    west chester, pa
    Do you take off the speaker grill
    or
    do you have to take off the whole door panel?
    2005 GSX R750
    Registered User Z71Nutty's Avatar
    May 2005
    MN
    The entire door panel has to come off. Its not too hard but it does take time. You should only need normal tools to do it. I did mine on a '06 ECSB. No way around it the panel has to come off. You will see the inside of the grill when you get it off and know way you had to remove the door panel to get to the speaker. Also go to Best Buy and get the GM adapter speaker wire plug in kit. That way your new speakers will just plug in and no hard wiring them :) Best of luck it will be worth it in the end stock GM speakers suck in these newer trucks. My new Infinity's sound 100% better!
    Red 2004 Silverado Z71 ECSB, 17" Alloys, 265 Dueler Revo's, Spectre Cold Air, No Name Dual Exhaust, TruXido Lo Pro, Westin Nerfs, OnStar, XM, TomTom, Bose, USA Spec iPod interface, Sprayed in bed liner and Valet Remote Start!
    west chester, pa
    thank you!
    how does it come off?
    2005 GSX R750
    May 2005
    MN
    There should be some bolt around the pad area, also take the cover off by the handle, pop the lock cover off too. Once you start in on it it should be easy to figure out. Sorry that I cant remember the exact process but it was not too bad just not that fun. Take your time and it will work out. I think I found "how to" on here or crutch field's site. There should be a guide on-line somewhere.....best of luck!
    west chester, pa
    thanks again. I googled it and printed out the directions.
    2005 GSX R750
