Thread: Sporadic bogging and sputtering 94 5.7 tbi 4l60e
Results 1 to 8 of 8
    NJ
    hey guys, first post here, i have a 94 chevy 1500 2wd, 5.7 tbi with a 4l60e , the truck is completely stock save for a monster performance rebuilt trans, it has a 1650 stall, my problem is that in overdrive between 40-50 mph when the truck is running like 1500 rpm's the motor just feels sluggish and bogs when you start to give it gas, if i run 3rd gear and shift manually into o/d at around 2000 rpm plus i have no problems, the truck pulls great, another problem is when im really getting on the truck and its at WOT, the truck sputters as its climbing in revs, this only happens when the truck is warm not cold, i have recently done a full tune up, and changed the fuel filter and air filter, when i replaced the trans i replaced the converter as well, i am wondering if my problem could lie in my stall speed, if perhaps i need a greater stall converter, my other idea was upping the rear gears to something like 3:73, i figure this will keep the motor out of that bad spot in the rpm range, it does not fix the sputtering rpm problem however, any info is appreciated, thanks
    G-FORCE FinalBreath's Avatar
    Milwaukee, WI
    Re: Sporadic bogging and sputtering 94 5.7 tbi 4l60e
    Check the fuel pressure.
    88 K1500 5.7 220K SOLD
    95 K2500 5.7 336k SOLD
    96 K2500 6.5 171K
    06 Trailblazer LTZ
    does the check engine light come on or flash briefly? if so you egr valve might be sticking open.
    Registered User HUMP's Avatar
    Dec 2009
    Arkansas
    Just something else that gets overlooked(I know from experience)the pickup coil on the distributor shaft can cause the same symptoms.I posted this somewhere else,but mine ran like the distributor was wet every so often or the tranny was going out until it just quit( chased it for 2 days).The nylon body of the coil that slips over the distributor shaft seems to twist some and gradually pull on the wires until they lose connection.Like I said,just throwing that out there.
    pickup coil is an easy check. set multimeter to ohms. disconnect pickup coil wires from module. should be between 500-1500 ohms.
    NJ
    fuel pressure is good, no check engine lights or flashing , ill check the pickup coil ......thanks for the tips
    Nov 2006
    CHEVY HEAVEN ,SUBZERO
    ummm you could also have a glitch in the TPS...this could cause the sputtering action your talking about..
    its also easy to test the tps sensor with a multimeter. set multimeter to dc volts. probe dark blue wire with red lead(needle probe, leave sensor connected). ignition on engine stopped. voltage should be around .5vdc. slowly open throttle, voltage should increase up to 5vdc at WOT. should be no flat or dead spots. also no erratic voltages.
