Thread: 1999 Tahoe Vortec 5.7 will not start....
Results 1 to 20 of 35
    Registered User mydropped92's Avatar
    May 2008
    Yakima,wa
    Exclamation 1999 Tahoe Vortec 5.7 will not start....
    My friend has a 1999 chevy tahoe. Vortec 5.7. The issue will not start. Here is what we have done:
    Checked Fuel Pressure: 63lbs cranking, will not start cannot measure it running.
    Checked Battery: New battery
    Checked Gas: Gas is in tank, lol.
    Fuel Filter: Brand New
    Fuel Injector: checked with "Noids" all lit up.
    Spark: yes
    I noticed truck will "backfire" like it wants to start.
    Am I forgetting anything?
    Quote Originally Posted by SloNlo350 View Post
    I was always under the impression that a Throttle Body spacer did about as much good as burning a $100 and sprinkling the ashes on the hood while reciting magical incantations... well apparently I was wrong. Still not gonna buy one though.
    I am sinner JWolfe75's Avatar
    Nov 2004
    NJ
    Re: 1999 Tahoe Vortec 5.7 will not start....
    was anything done to it recently? any codes?
    Cap/rotor/wires?
    '05 GMC 2500 HD LLY
    '07 TBSS AWD 3SS
    May 2008
    Yakima,wa
    No Nothing. It was running in tip top shape! He parked it one night, came out the next morning to go to work, would not start.
    Linesider
    Treasure Coast, FL
    That is what mine did when the fuel pump died. There are a couple other things to check. I forget what they are (it has been a while).
    Assuming there is a spark...
    1996 Chevy K1500 Z71 ECSB
    1985 Mercedes Benz 300D
    May 2008
    Yakima,wa
    Please read my post again, spark:yes.
    Minn
    will it start with starting fluid? if it does, its not getting fuel.
    I have had this happen and it acted like it flooded. would not start with starting fluid either. let it sit with the key off and the accelerator wedged to the floor for an hour and it would start then.
    '05 Tahoe Z71 (Bought 9/28/11) - 5.3 4L60e, 3.42 G80, Spectre CAI.
    '99 Silverado Z71 (Sold 10/25/11)
    '99 Suburban LT ( Sold 9/28/11)
    Trucknut coolgmc's Avatar
    Jan 2002
    Grand Rapids, MI
    Any fix to this? My dads 3/4ton suburban has been doing the same thing. One day it will start, the next it acts like their is no fuel. Had it towed to the mechanic and it worked fine, they kept it all day and worked fine. We had the fuel pump replaced and it still is doing the same thing again.
    -2006 1500 Chevy Silverado LT Crew Cab, CST Lift, Tint, Escalade Handles
    -1990 GMC - SFA, 8 inch BDS springs, 3 inch ORU brackets, 2 inch Bodylift, Westin Nerf Bars, 39.5's TSL's on 17x12 Weld Cheyenne 8's.
    May 2008
    Yakima,wa
    It will not start with starting fluid. I acts like it is backfiring.
    Registered User 86choptop's Avatar
    Dec 2009
    yarmouth ns
    is there a theft light flashing in the dash
    Minn
    Quote Originally Posted by mydropped92 View Post
    this is what mine does.. i was going to try cleaning the MAF and the IAT sensor to see if that helps.
    Oct 2009
    Massachusetts
    Same thing with my 1999 Tahoe, had to have it towed, the next day, it started right up for the mechanic, no spark, no start even with starting fluid. He recommends a new coil...
    May 2008
    Yakima,wa
    Update: It has fuel to the cylinders, spark plugs are wet. Ruled out fuel problem.
    It is has a orange dull spark. The timing is not correct, engine backfires.
    Would a bad crank sensor or camshaft sensor cause mistimed spark?
    The theft light is not flashing.
    Jan 2007
    Missouri
    check crank sensor.
    May 2008
    Yakima,wa
    I am gonna check the ohms on the crank sensor tomorrow.
    Nov 2008
    Canada
    Quote Originally Posted by coolgmc View Post
    It sounds to me like a bad ground wire on that comes off the fuel pump. Mine acted up a couple times I had to re-tap a screw into some metal for the ground wire as the old one was corroded.
    Jun 2002
    Wisconsin
    Check distributor cap and rotor for corrosion or wear, it sounds like it might be crossfiring, causing the weak spark and backfiring
    Dec 2007
    mn
    mine was doing the same as yours and it ended up being a bad dizzy cap! was running normal shut it of go to start it nothing but popping and backfire
    mi
    x3 on the cap nothing but ac delco
    May 2008
    Yakima,wa
    Update: He has changed the camshaft sensor and the dizzy and cap. Still nothing......We will check the ohms today on the crankshaft sensor. If not just replace it. I will get an update soon. BTW spark plugs were replaced too.
    Aug 2007
    mississippi
    I've seen bad ignition switches do this. The switch would cause the truck to go into anti theft mode. The Snap-on scanner didn't catch it either
